PHANTOR
07-08-2004, 07:04 PM
Just wondering, what are the recommended plugs, if you were to replace your plugs with aftermarket plugs?
Brand name, etc...
Brand name, etc...
View Full Version : Replacing Plugs PHANTOR 07-08-2004, 07:04 PM Just wondering, what are the recommended plugs, if you were to replace your plugs with aftermarket plugs? Brand name, etc... Tony Orlando 07-08-2004, 07:31 PM There are no known aftermarket plugs. Use the Mazda OEM. 86rx7 07-08-2004, 11:08 PM The stock plugs are pretty damn nice, they physically look EXACTLY like the 11.5 heat range ngk race plugs alot of high hp/ race rx7's use just a lower heat range. Nice plugs. wakeech 07-09-2004, 01:32 PM NGK is the only company that manufactures plugs for the Mazda wankel rotary. the OE plugs are already iridium, so what do you think you're gonna gain by going to a different material?? man, every day at work, i have to teach someone else about spark plugs, the benefits of different designs and materials, and whatever... it never ends. quit believing the advertising, seriously. StealthTL 07-10-2004, 12:39 PM My old RX-3 had an appetite for plugs, and I went thru quite a few sets, Champions, NGK, Denso, etc. A plug seized in the housing, then broke off at the gasket, leaving the threads to be drilled out...... :mad: My old rotary mechanic knew his Mazdas, and he knew his plugs too - I will never forget the chuckle when I explained what had happened (in finest Bavarian accent) "It vas a Champion - ja?" "How did you know that?" "Ze Japanese vons, zey are very strong, zey don't break!" NGK for me, from then on.... S |
