O2 Sensor removal
Old Jul 8, 2004 | 05:27 PM
Unhappy O2 Sensor removal
Spent about an hour under my car today trying to install the midpipe and highflow cat. Got the old cat and resonator out, and the new one assembled....and then ran into a problem. The O2 sensor after the cat wouldn't come loose from the stock unit.
I didn't want to break it so I had to re-intall the stock system. I think that I am going to buy a new one for the midpipe assembly. If I force this one out i will probably break it and need to buy another one anyway........
Does anyone know how much they cost??
OR
a way to remove the stock one??
Would it come loose if the Cat was hot easier??
Old Jul 8, 2004 | 05:30 PM
Jay Goldfarb's Avatar
I think they are in the $175 range. Same thing happened to me. We stripped the threads on the O2 sensor and had to tap the cat for use is I want to reinstall later on.
Old Jul 8, 2004 | 05:44 PM
PHANTOR's Avatar
does the high flow cat and resonator combo make much more noise than the stock cat. I already have a noise problem. what are the torque and horse speced increases?
Old Jul 8, 2004 | 05:49 PM
brothervoodoo's Avatar
RainMan is Back
From what I've read on this board, you will get an increase in noise. Canzoomer found that the the high flow cat needed a resonator because the noise was unbearalbe without. If you happen to have an aftermarket exhaust with the high flow cat and resonator it will be even louder still.
Old Jul 8, 2004 | 05:51 PM
I'll let you know when I get it installed :D
Old Jul 10, 2004 | 03:26 AM
went to the dealership today to get a new O2 sensor. Cost 150$Cdn. They said that it is very common for them to sieze, and that MNA has dropped the price due to this......I'm going to use high temp no sieze when I put on the new one. It's good to 2400F so should work OK. Putting in the midpipe tomorrow
yurcivicsux
192
Sep 12, 2017 10:54 PM
fistofmeat
Oct 7, 2016 12:15 PM
05rx8mazda
Nov 28, 2015 09:42 AM
yankeepicker
Sep 11, 2015 05:42 PM
