Questions on 6 speed manual?
Old Jun 29, 2004 | 12:10 PM
kazson's Avatar
The last time I drove manual was back in the 70'. A VW with 4 speed H type shifting. Only 4 gears to play, easy. Now with
the 6 speed, I find it a little intimidating shifting thru all the
gear to get thru the highway to cruise. This may be a stupid
question, but, can I go 1st to 4rth, then shift to 6th? In the
same token, can I shift from 6th to 4rth or 3rth? , bypassing
some gears in the middle? I realized that we have to be at
the right rpm, or else there is going to be this "jerking" motion and over reving. I've read some folks had been cruising on
4rth, thinking they're in 6th? Can this guy shift from 4rth
to 6th??? and be done with it.
Old Jun 29, 2004 | 12:12 PM
willhave8's Avatar
Yes to all you asked.
Old Jun 29, 2004 | 12:13 PM
mysql101's Avatar
You can. A lot of people skip 5th gear completely.
I do skip gears sometimes, but I usually shift through them all.
When you need speed, it isn't uncommon to go from 6th down to 4th. It will be easy once you get used to knowing how fast you can go in each gear.
Old Jun 29, 2004 | 12:49 PM
blue flash's Avatar
my easy driving is 1st -2nd to 4th then 4th to 6th .when i need to get some where fast 1st 8500rpm's-2nd 8500rpm's 3rd 8500rpm's 4th 8500rpm's then whatch for popo 5th 8500 rpm's
Old Jun 29, 2004 | 05:18 PM
John Corbitt's Avatar
Hey Blue Flash. You are missing 700rpm in each gear. The rev limiter kicks in at 9300. I do the same thing except it is on the track where there are no popos ecxept for ones doing the same as me.
John
Old Jun 29, 2004 | 06:09 PM
takahashi's Avatar
I am traditional and shift one by one... I hate to miss a gear and lost momentum
Old Jun 29, 2004 | 06:17 PM
Dr. Rx's Avatar
I also drive traditional style, shifting through each gear when upshifting. I'll skip gears when downshiting from time to time.
Old Jun 29, 2004 | 08:23 PM
Rotarian_SC's Avatar
Free Autographed Pictures
I only skip gears if I am going from accelerating to cruising or if I am downshifting sometimes. I wouldn't be too woried about it if I was you.
Old Jun 29, 2004 | 10:08 PM
zoomed's Avatar
My general approach is to 1-2-3-6. Hammer it throught the first three gears -- which have a very fluid feel -- and go directly to 6th for cruising.
Old Jun 29, 2004 | 11:18 PM
Jeffjett's Avatar
Many times I go 1st to 3rd to 5th, especiallty if I am in city traffic and drinking coffee. If you rev it to around 4000 RPM, then skip a gear, it does not lug at all. Of corrse, you are traveling pretty conservatively.
That's the amazing thing about the 8, you have so much variation in the gearing, depending on the RPM's you run.
Old Jun 29, 2004 | 11:22 PM
Adamrotor's Avatar
Sonic the Hedghog
Neutral, I drive however im comfortable with.
Old Jun 30, 2004 | 08:29 AM
blue flash's Avatar
i hit my rev limiter the othe day got a little road rage with all the as/hole tourist driving 35mph on a friday afternoon going to the beach .it smelled like hot antifreeze when i got done dont know why but i backed off and drove easy all the way home no damage was done, is this normal
Old Jun 30, 2004 | 06:40 PM
khoney's Avatar
FX8TED on my RX-8
1-2-6 much of the time (usually onramps). I make 65 in 2nd, then cruise in 6th. Sometimes 1-2-4-6.
drebbrnator
Dec 27, 2018 07:02 PM
foxyRoXy8
Aug 18, 2015 10:26 PM
cschoeps
Aug 6, 2015 12:44 PM
AussieGray
Jul 16, 2015 03:58 AM
