brillo
06-28-2004, 07:41 PM
Anyone used it? How'd it work? Any special rotary issues? Figure the RX8 could use all the cooling help it can get.
View Full Version : Redline Water Wetter - Thoughts? brillo 06-28-2004, 07:41 PM Anyone used it? How'd it work? Any special rotary issues? Figure the RX8 could use all the cooling help it can get. Rotary Titus 06-28-2004, 09:10 PM I put in some and have noticed the temp guage never even reach the mid point even when I turn on AC sitting in traffic in hot weather. But it works best with a coolant mix that consists of more water than glycol since the way it works is it decreases the surface tension of water and let it have more contact with the radiator/let air bubbles boil off faster (it has no effect on glycol so more water, less glycol antifreeze = more effectiveness). I have 50/50 glycol/water mix since we get subzero temps in Canada. If you live in a warmer place you can put in a lot more water and have a more dramatic decrease in temp. Xavier296 06-29-2004, 09:47 AM alrighty then, the car never heats up, ever! big rad, lots of oil coolers, nice and cool. Put water wetter in an old car, works very well, keeps both my triumph spitfires cooler. Actually kept the car with the six cylinder 10-15 degrees cooler in the city. Good stuff, just not necessary on your 8. derwankel 06-29-2004, 10:02 AM Here is some comments on the product: http://e30m3performance.com/myths/more_myths1/Water_Wetter/water_wetter.htm dcfc3s 06-29-2004, 10:49 AM Works well, and works well on rotaries. With the '8s idiot light temp gauge, you probably won't see a difference, but it's good stuff. Dale Overport 06-29-2004, 12:50 PM I have used Redline Water Wetter in my 2004 Yamaha YZ250F dirtbike, and it works wonders! I live in Vegas, so coolant in my cars and my bikes have to be top-notch. I HIGHLY reccomend Watter Wetter, use it on your RX-8 like i did, you will NOT regret it. It keeps your engine cool no matter how hot it gets. Reeko 06-29-2004, 01:01 PM Originally posted by dcfc3s Works well, and works well on rotaries. With the '8s idiot light temp gauge, you probably won't see a difference, but it's good stuff. Dale I thought the temp gauge was an actual analog gauge. Seems that way to me, you sure you aren't refering to the oil gauge? mysql101 07-17-2004, 07:52 PM I just bought some and the temp guage doesn't reach the mid way point anymore. Considering how hot the rotary gets, this seems like a good investment. Cost me $6.50 for a bottle at discount auto parts (the yellow auto store, whatever it's called) bureau13 07-17-2004, 11:03 PM My temp gauge never quite hits the mid point even with the additive. Not sure what the temp gauge means anway...has anyone characterized the behavior of this thing? Dale referred to it as an idiot light, but I haven't seen any actual proof of this. I know the 3rd gen was famous for its nonlinear-to-the-point-of-useless gauge response to temp. jds kellybrf 07-18-2004, 01:03 PM ive used it in both my 8 and my computer and it works very well :) rx8spiritR 07-19-2004, 06:36 AM so did you guys drain all the coolant out before you put the water wetter in or do you just put some in and mix them? dcfc3s 07-19-2004, 10:14 AM Only having test-driven an '8, I can't say for sure, but I had thought that someone discovered that the water temp gauge was an idiot light like the 3rd gen. I really hope is is a linear gauge - that temp gauge on the 3rd gen killed a LOT of motors, IMHO. The oil pressure gauge isn't that big of a deal. On a rotary, either you have good oil pressure or you don't - if you have a problem, put a mechanical gauge on and do some testing. Low oil pressure isn't that common of a problem, really, or at least not that severe - there's not many points of failure for oil pressure. Dale davefzr 12-16-2004, 10:57 PM OK. Here are some tests that I did regarding how well water wetter works. I am not that satisfied with the test that I did with water wetter so I will do one more. The conditions were not exactly the same and I also started with a warm car. Here are my graphs that I got from a CANScan... I'll try again when the conditions are better but here are the graphs for now. davefzr 12-16-2004, 10:58 PM It looks like it actually hurt haha.. It took less time to heat up and more time to cool down.. thats not good :) Like I said though.. I'll give it one more shot, but if I get the same results the second time with same conditions, I am flushing my coolant haha.. :) dannobre 12-16-2004, 11:40 PM If it increases thermal transfer...I would expect it to heat up quicker, and to reach operating temp quicker....and cool down quicker. Seems to be what is happening in the graph....although the curves look very similar. What are you doing when you graph. Mine runs at about 183 deg warm at idle, and loww RPM cruzing. I have to really drive it hard to get the temp up over 210deg? ZoomZoomH 12-17-2004, 12:36 AM IIRC water wetter works best if put in ALL WATER cooling system, something like 50/50 water wetter/water, for racing application at least. davefzr 12-17-2004, 12:52 AM When the car reached 210 degrees it was at an idle for the amount of time from when the temperature rose to when it started to fall (around 3 to 4 minutes). The graph to me looks like it heated up faster to 210 and cooled down slower from 210... Anyone else have any comments? TyrellCorpNexus8 12-17-2004, 01:35 AM I think you are right, Dave, but the rate of decrease may or may not show a significant difference. I think you have to do several more samples, trying to insure the conditions are about the same for each time. Unfortunately, you weren't able to do multiple samples for your baseline (ie. control group = without Water Wetter). Z00M RX8 12-17-2004, 09:39 PM The slopes of the lines during heating and cooling look the same to me on that graph, the only difference that I can see is an offset in time which could be accounted for by the different start temperatures. Can you record data while driving? It would be a better test if you could put the engine under load (perhaps by driving up a hill) you would also need to record the outside ambient temperature for each test. dannobre 12-17-2004, 09:50 PM I watched mine on a drive into town today (40 min) and the temp was between 183 and 186 all the time. It doesn't hurt that the ambient temp was 10 deg C :D It must be warm in San Dimas .............. kellybrf 12-17-2004, 10:47 PM youre all missing the point of it, water wetter does not cool the water. it keeps it "wetter" by increasing the boiling point, so at those times when your car is running very hot and the water is inclined to turn to vapor it will not mysql101 12-17-2004, 10:52 PM youre all missing the point of it, water wetter does not cool the water. it keeps it "wetter" by increasing the boiling point, so at those times when your car is running very hot and the water is inclined to turn to vapor it will notActually, I think it works by lowering the surface tension of water. This gives it the more favorable cooling properties. kellybrf 12-17-2004, 11:11 PM could be. i wasnt given the technical explination, but was told that when its running through the engine and exposed to the extreme temps regular coolant can turn into vapor at times, and water wetter will stop this. mysql101 12-17-2004, 11:21 PM I'm pretty sure it doesn't raise the boiling point of water. Your coolant already does that. However because water wetter allows your cooling system to function more efficiently, it's effect would be to stop your radiator from getting as hot. dannobre 12-17-2004, 11:40 PM All you ever wanted to know about Water Wetter....but were afraid to ask :D rx8spiritR 12-19-2004, 05:01 AM well, i've put in the entire bottle, so far ( 4 months), i don't see any different , nothing happend, everything were just as normal as before. mysql101 12-19-2004, 08:31 AM How would you notice a 5-10 degree drop in your radiator? TyrellCorpNexus8 12-19-2004, 09:02 AM By, as in the butt dyno, using the butt thermometer. Ewwwwwww. speedweasel 12-19-2004, 09:14 AM You guys kill me!!!! Go back to school and take a good thermodynamics class. I think you are deluding yourselves into thinking your thermostat on the cooling system will react differently with one chemical mix vs another. Your system will always attempt to normalize around 180 degrees. Only when you have exceeded the heat capacity for your system will the temp go above the thermostat full open setting. And then you will notice the temp fluctuating with RPM and forward speed. Since I have not read a post yet where the 8 overheats (chime in Aussie guys!)...you guys are just wasting your money!!!! If you still insist on buying it, I have another product for you! Guaranteed to boost your horspower by 30+ at the wheels! It makes the air airier! Made from genuine cow farts collected midday from a Texas cattle ranch! Its the airiest air on the planet!!!! Only $30 a bottle and a direct replacement for your NOX system!!!!! Just send me $30 and Ill hook you up!!!! :D Doctorr 12-19-2004, 12:10 PM The temp gauge is not just an idiot light, it works. I had a cooling fan problem, watched the gauge go up, up, and away! :eek: Works pretty well! . . . doc Nubo 12-20-2004, 11:47 AM You guys kill me!!!! Go back to school and take a good thermodynamics class. I think you are deluding yourselves into thinking your thermostat on the cooling system will react differently with one chemical mix vs another. Your system will always attempt to normalize around 180 degrees. Only when you have exceeded the heat capacity for your system will the temp go above the thermostat full open setting. And then you will notice the temp fluctuating with RPM and forward speed. Since I have not read a post yet where the 8 overheats (chime in Aussie guys!)...you guys are just wasting your money!!!! Sure, from a system-level things will be the same, but do you discount the alleged benefits of reducing localized hot-spots? Gomez 12-21-2004, 06:40 AM fluctuating with RPM and forward speed. Since I have not read a post yet where the 8 overheats (chime in Aussie guys!)...you guys are just wasting your money!!!! True, to the best of my knowledge, no-one has overheated an RX-8 in Australia.....and it gets pretty hot here. 105 deg is not uncommon in Summer. sco 12-21-2004, 07:57 AM .. and we only have one oil cooler... not that it would have a direct affect on coolant temp (only indirect). ZoomZoomH 12-21-2004, 10:10 AM i think the stock cooling system is more than capable of handling a stock Renesis. just keep the coolant fresh and topped off and you should have no problem. rotaryboy 12-21-2004, 03:30 PM I used it in my 3rd gen. and it seemed to work. No more steam from the overflow tank on hot days FWIW. No scientific data, however. |
