Pinging Problem? Solution?
Old Jun 27, 2004 | 10:56 AM
RX-8 friend's Avatar
Well, we discovered a simple way to reduce the propensity of a given car to ping.
Car in question was a local "problem car" for the Canzoomer module. Had a real tough time stopping it from pinging. It even pinged sometimes stock!
Maurice put in the new "8" heat range leading plugs (available from your Mazda dealer).
No more pinging!
Sorry, I can't keep track of the exact plug number - I'm sure one of you will know that and post it. Use the same number your current leading plugs have, just replace the 7 with an 8.
Remember, the leading plugs are the lower ones. They can be easilly changed from the top. First get a zip tie and secure all those silly hoses out of the way by loosely tying them to the A/C pipe close to the firewall.
Those of you living in colder climates should change these new plugs out for the hotter ones when the weather changes back to winter.
Digitz0070
55
Jul 25, 2017 08:40 PM
Zube6115
Sep 30, 2015 12:57 PM
tommy26Germany
Sep 29, 2015 10:33 AM
Evan Gray
Sep 26, 2015 12:30 PM
