Food Warmer ?
Old Jun 17, 2004 | 07:27 AM
kgoh2262's Avatar
Food Warmer ?
Has anyone who got their cars recently have this problem...got mine a couple days ago. I think console is OK but the ashtray box was hot ! Luckily I did not turn that into a candy tray..
FRONT CUP HOLDER / CENTER CONSOLE BECOMES HOT
Applicable Models
Model Starting S/N Ending S/N
2004 RX8 00000000 40113124
Some customers may complain of the front cupholder area of the center console becoming hot after extended driving, causing cold drinks to warm. Due to the heat from the exhaust system (catalyst), the center console (cup holder area) becomes hot. This is due to insufficient insulation between the floor panel N cup holder. A insulation pad is available to reduce the heat transfer to the center console. 1. Remove the upper panel, hole cover (cigar lighter) and storage box from the vehicle. (See WSM 9-17-8) 2. Remove the six screws from the upper panel and remove the rear console. (See WSM 9-17-8,9) 3. Attach the heat insulater pad to the bottom of the front cup holder in the rear console removed at the above step #2. NOTE: Be sure to attach the heat insulator pad so that the bottom of the cup holder is wrapped. 4. Re-install the parts reverse order of removal. Parts information: F151-55-161 Heat insulator pad
Old Jun 19, 2004 | 09:46 AM
tategoi's Avatar
Surprisingly, why this was not done during the manufacturing process?
Old Jun 19, 2004 | 10:15 AM
KT.'s Avatar
KT.
Perhaps for cars with S/N after 40113124 will this factory insulated?
btw, great forum, learnt a lot from the FAQ section and has started reading up on all the technical contributions.
Audio Concepts ATL
Sep 26, 2021 01:59 PM
yurcivicsux
192
Sep 12, 2017 10:54 PM
groll69
MW RX-8 Forum
Aug 17, 2015 04:21 PM
RX8Bliss
27
May 11, 2004 05:14 PM
