Gas Cap causing check engine light
Old Jun 16, 2004 | 09:10 AM
Blue Demon's Avatar
Twice I have had the check engine light come on and both times my gas cap had come loose. This morning I tried several times to get it tight but it will just not lock in place very tight, guess we're headed to the dealer to have him check it out.
Anyone else had this problem?
Roy
Old Jun 16, 2004 | 09:35 AM
Omicron's Avatar
Some people here a while back had a problem with a CEL due to a loose gas cap, but were able to tighten it and make the problem go away. If you tighten yours until it clicks, and it continues to loosen itself, then I'd definitely take it in to the dealership.
Old Jun 16, 2004 | 11:12 AM
zoom44's Avatar
actually many of the early "cel light for gas caps" werefrom a software glitch. this was corrected. if you have at least L you should not be getting a false leak detection. so yes you should definetly take it in and have them pull the codes and check for leaks.
Audio Concepts ATL
Sep 26, 2021 01:59 PM
vapor2
Nov 3, 2020 03:38 PM
marc2820
Jul 26, 2015 10:47 PM
netrovers
Jul 20, 2015 03:32 AM
