Questions about the Stage 1.X please
Old Jun 15, 2004 | 03:01 PM
rlfletch's Avatar
Moderate jerk
Clarity...
... As in: "Can we get some?"
There appear to be a lot of issues that we are not getting consistent answers to:
When are new maps from Canzoomer released and can this be posted here?
Should or should not people be snipping their resistors for coil longevity?
How are new units different?
Should, or can, older units be exchnged for new ones?
How come the rough idle when the unit isn't supposed to take action until 2000 rpm?
How about some definative anwsers to the horsepower question from the canzoomer?
I understand Canzoomer is busy and RX8friend has been very helpfull but I am tired of chasing all these questions down in different threads.
We need a complete update!
Old Jun 15, 2004 | 03:36 PM
meedi1's Avatar
amen to that...
Old Jun 15, 2004 | 03:51 PM
Velocity-8's Avatar
Whuumpha!!
Well???
Old Jun 15, 2004 | 03:54 PM
leegina's Avatar
Please!
Old Jun 15, 2004 | 08:53 PM
Omicron's Avatar
Give it a little bit folks, they're busy building units. I'm sure there'll be a response within a day or two.
Old Jun 15, 2004 | 09:57 PM
leegina's Avatar
But you would think they would address some of these issues before they have another 20-25 people upset that their units are not operating properly. I am probably going to pull mine and wait until they fix some of these issues- rough idle and coilpack burning up.
Old Jun 15, 2004 | 10:22 PM
Rotarian_SC's Avatar
Free Autographed Pictures
There has been no problem with mine, but I would just like to say that I think this thread should have a name with a little bit more...clarity, then if you get the answers I think it would probably turn into a sticky.
Old Jun 15, 2004 | 11:11 PM
h0rde's Avatar
CVRRVS CELER
we could eliminate a lot of the threads here in the first place and save maurice time posting answers if he just put all that info on his website and updated it frequently...an FAQ page alone would work wonders
Old Jun 16, 2004 | 01:43 AM
Spazm's Avatar
~~> Next 10 miles
Yes, some definitive answers would kill 90% of the posting in here.
Old Jun 16, 2004 | 09:51 PM
RX-8 friend's Avatar
"When are new maps from Canzoomer released and can this be posted here?"
Maurice will get the FTP site working eventually. He's still finishing up the latest map. It improves on the May 18 map. I'll let you know when it's ready.
"Should or should not people be snipping their resistors for coil longevity?"
Well, after finally getting my scopemeter we found "interesting" things. The main board is a little unstable - something I've never seen in a digital circuit before. It has noise in the output. The fix is to replace the resistors to ground with 0.1 microfarad capacitors. We will do this free for anyone who wants it done, but you will have to pay the shipping. All new units shipped from yesterday on will have them. This -may- improve the idle. The "M" flash has a rough idle, because the injectors are really too big. You can see this effect when the car is idleing - notice how it speeds up a tiny amount and then slows back down from time to time? The PCM keeps trying to adjust but can't at idle because the smallest amount of fuel it can inject is too much for idle. The resistors may load down the instability a bit, but it's not the right solution because they also reduce the coil drive pulse.
"How are new units different?"
They're better . Actually, the new units with the internal switch are the same, except the switch completely disconnects the Stage 1 electronics (except for power to it), whereas the one with the external switch leaves the ignition connected. You'd have to switch the internal dip switch to disconnect that (even numbers on = ignition controlled by Stage 1 - odd numbers on = stock ignition). Now the new units also have the capacitors on the output when the unit is "ON". When "OFF" it's completely stock. The new units are also slightly longer (to make assembly easier). We have also improved the RPM circuit (tach output) so it works better with the Stage 3. This will also be added to any unit sent back for update.
"Should, or can, older units be exchnged for new ones?"
If you have no problems with the older units I wouldn't worry about it.
If you suspect the poor idle is really caused by the unit (verify by removing it for a week and then using it for a week), return it and we'll update it free (except for shipping). We'll also ensure it has the latest map installed (unless you request it not be changed).
"How come the rough idle when the unit isn't supposed to take action until 2000 rpm?"
It isn't clear all cases of rough idle are caused by the unit. Some may be. See above. Maurice has rough idle from time to time, but it doesn't correlate to whether the unit is on or off. We are replacing his coils to see if maybe they are flakey. He tends to heat his car up nicely when testing maps. Heat is the enemy of the coils.
When I checked with the scopemeter I found the "off" voltage to be 0.8 V out of the main board, and after our ignition board 0.15 V. To me this means it's safe for the coils. The "ignition board" is where we condition the signal to the coils. The pulse signal was noisy, and the 0.1 microfarad capacitors fixed that.
So, if I had one would I send it in for updating? Well, I'm an electronics tech, so I'd do it myself as shipping is not cheap! If it was working well in my car I wouldn't bother.
It's a call each of you will have to make for yourself.
Same deal about whether to get the programming cable and program. I'd get it for sure myself. I'd also run the USB extender into the car to monitor the unit while driving with my laptop. I like to have too much info. Some of you are better off (and more comfortable) without.
If you want more detailed instructions/info. on any of this, please ask.
Old Jun 16, 2004 | 10:00 PM
guy321's Avatar
Humpin legs and takin nam
So you replaced the "snipped" resistors with caps? or are you talking about differnt resistors.
Old Jun 16, 2004 | 11:06 PM
Yes, the snipped resistors in essence are "replaced" with caps. Except the ones I've done so far were the new boards that didn't have the resistors. They were designed to be flexible component wise, so adding the caps was easy. If I were to update an old board I would remove the resistors and put in caps. We're using ceramic "plate" caps. 0.1 uF 50 V. Not polarized. The ones used on CPU motherboards for power filtration.
Old Jun 16, 2004 | 11:20 PM
Omicron's Avatar
Would you be willing to send those of us who are comfortable working with circuit boards the caps, and let us install them?
Old Jun 17, 2004 | 01:52 AM
Spazm's Avatar
~~> Next 10 miles
Thanks for the answers RX-8 Friend, but I think the question (yet unanswered) that is foremost in the prospective purchasers mind is, "What is the performance like with the M flash? In real numbers!"
Old Jun 17, 2004 | 10:00 PM
Yes, we can send the two caps. to those comfortable enough to install them - or you can just buy two from an electronics supplier - they are less than $1 each.
I keep seeing the question of how much HP the Stage 1 adds with the "M" flash. I guess lots just don't get what this unit does. It's -programmable-. You get as much HP as the map you have programmed in can give your car. This changes each time we change the map, and varies from car to car. In "Stage 1" tune optimized for one car, the unit will increase HP as much as 25 HP, but currently the map is turned down a bit to compensate for variations in cars. I would guess it could give around 20 HP in the right car. Some cars will see no gain. Some may see a loss. We are working on a way to compensate for these variations. We -will- find a way to give most of you the 25 HP this unit is capable of giving. Some cars may never respond well to it.
We are not going to claim it gives "X" HP in all cars! That would not be true. It -would- be typical for this market!
As for the rough idle - we did a lot more testing today. I put a switch in Maurice's test box to put the caps. in and out of circuit. Out of circuit there was a "chirping" noise (which I noticed before but didn't know what was causing it or where it was coming from). Caps in circuit the noise as gone. I then replaced the two suspect coils (leading ones) with new coils and moved the leading to the trailing position. Chirping was gone, even without the caps. Caps still stopped the noise seen on the scopemeter. Removed the unit from the car and checked idle without it. Replaced unit in the car (with caps switched in and out) and the idle was pretty much the same in all three cases, maybe a little better with the caps than without - but about the same stock as Stage 1 with caps. - sometimes it was smooth, sometimes a little rough. When hot, there was more noise without the caps. as seen with the scopemeter.
So, what can I say about all this? I'm happy with the caps. in circuit. I don't like the noise there - it could cause problems. The caps. seem to be harmless re drive levels and they don't mess with the risetime or timing. I think it's a good modification - no downside, perhaps an improvement. They seem to make the car more tolerant of "weak" coils as well. I have no idea if the coils I took out were weak. Other than the noise, I saw no difference - but I was just running the car idling. Maurice will probably be doing map work tonight, and he will be able to tell if the new coils help anything.
Old Jun 17, 2004 | 10:24 PM
leegina's Avatar
So these caps do you essentially solder them in where the old resistors were removed? Would you by chance be able to take a pic of the caps soldered in. I am not a tech but my friends are and have access to their knowledge. But a pic would help (ME).
Old Jun 17, 2004 | 10:46 PM
I found the best way is to remove the box from the car. Leave the ignition board screwed down in the box, and use a small soldering iron to heat each lead of the resistor (start with the longest one), and gently pull it out of the board. Then remove the other lead (and the resistor, of course). Trim the cap leads so about 1/8" would go into the board, and heat the solder filled hole and insert the lead. The holes are plated through, and are difficult to clear of solder, so this method works best. When you are done soldering, remove the board and trim/check the underside. They are nice PCBs, as the runs don't seem to lift. Good supplier! I'll do pictures in a day or two. Waiting for Digikey to deliver our production caps. (been working with prototyping caps and ran out). For those with the new boards, with the switch inside the box, it's more complex. I'll get to that in a day or two. You will need two diodes and two caps. Diodes are 1N4148.
As I said, if this scares you, we will do it for you as long as you pay the shipping.
I'll post pictures in a day or two.
Old Jun 18, 2004 | 11:46 AM
Genom's Avatar
Not so Super right now
Will these caps also aid for those of us blowing coils? Or is that part still a mystery?
Old Jun 18, 2004 | 09:10 PM
I don't know why you've been blowing coils. No harm in putting them in and seeing what happens. So far as I know only you, Maurice, and Mazdamaniac have blown coils with the unit. Later two did it before we began using diodes. Others have had coil failures without the unit.
If it starts idling poorly shut it off and remove the unit. That should keep you from going through another set, if it's an interaction with the Stage 1.
Old Jun 19, 2004 | 11:05 PM
leegina's Avatar
Installed the caps and it restored the idle and the car pulls good. It took a little bit for the ECU to relearn or adapt to the Canzoomer because it felt like it was surging going up hills in 5th and 6th when stock it did not do this but with more and more driving it went away and ran fine. The car as the ride went on felt like it was getting stronger by the mile. It feels good to have it operating correctly. Thanks RX-8 friend for your help.
Old Jun 24, 2004 | 03:00 PM
guy321's Avatar
So, are you still completely replacing the resistors with caps? or do we need to install the caps in the circuit with the resistors? I've heard rumors of the latter.
Old Jun 24, 2004 | 09:24 PM
Remove the two resistors indicated and add the caps (0.1uF 50 V ceramic multiplate caps). The picture below shows the older board used with the switch on the case and the newer board with the switch on the board.
On the older board you just remove the two 2k2 ohm resistors and replace them with the caps. I have also noted changes to the tach circuit needed if you intend to run Stage 3. We would rather you return your unit if you are ordering Stage 3 so we can ensure it's up to date - it would only cost you shipping one way as well, because it and Stage 3 would not cost much different than just Stage 3 for shipping - i.e. if you are ordering Stage 3 you are already paying for shipping from us to you. I included that info. so everyone knows some of what's involved.
The new board is a little more complicated. I took a shortcut when inserting just the diodes. To get the board to work with the caps. you have to remove two diodes (position shown), add two new diodes (leads on removed ones are probably too short to allow reuse), add two jumpers (shown), and install the caps. This would only apply to a few units, as not many were shipped without the caps.
See my previous message above on the best technique for removing and inserting re solder in plated through holes.
All units shipped from June 15 on have the caps installed, but you can check yours with the pic.
Old Jun 24, 2004 | 10:22 PM
I promised I'd let you know when the new map was finished. It was last night. Latest batch of units go out tomorrow, and they have it. I'll ask Maurice again tomorrow about the FTP site. He's pretty busy right now, trying to get things ready for his being away on vacation next month.
This map has been tested by several "problem" car owners and seems to be good. Fingers crossed!
BTW, some of you have been commenting on performance of previous maps. Here's a hint. If you experience a power drop (sometimes subtle, sometimes drastic), you are probably running -lean- at that RPM. Rich you wouldn't notice the power loss. It's too small. The problem area was 6000 to 7000 RPM with "M" and the previous map. What you experience is the car reacting to ping (protecting itself). If you persist with open throttle and it's lean enough it will trip a MIL and cut you back for 15 sec. or so. You can try removing aftermarket intakes to fix it (if you have them). We hope this new map will reduce the number of cars experiencing this.
Old Jun 25, 2004 | 12:11 AM
Omicron's Avatar
I have one of the "problem" cars, and have developed my own map that works. However, Maurice sent me two versions of the new map today, and I'll be trying them out over the next few days. I'll let you all know how it goes.
Old Jun 25, 2004 | 09:23 AM
Genom's Avatar
2 items. Can I get someone to send me this new map? Also, do you have a better pic? I see on the older board there's some 10K resistors but I cant make out what it says to do to them. Pic is just very low res. Can I get a higher res one? Going to go ahead and put the caps in and try the new map and see what happens I guess. If those other resistors are for stage3 though, dont worry. If it's just swap the caps in (I beleive my board had the resistors removed last time it was there), should take 2 minutes to do.
