Tire Pressure Warning
Old Jun 10, 2004 | 04:39 PM
dsorx's Avatar
My tire pressure warning light has been coming on for 2 days straight, even though the tire pressure is fine. Car is at the dealer now for diagnosis.
Also getting 1st oil change (1500 mi.) and the M flash
Can't wait to get it back!
Old Jun 11, 2004 | 12:34 PM
Mr M's Avatar
Evolution of REvolution
Aftermarket Car-navi installed?
Old Jun 11, 2004 | 12:58 PM
dsorx's Avatar
Nope. Dealer called and said tires were over-inflated. Weird since when I checked it, 3 tires were 32 psi and 1 was 30 psi. But he said the light did not come on after pressure correction and test drive.
Oil change is done and flashed! Going to pick it up this afternoon. I am anxious to see if the flash really does anything noticeable.
Old Jun 11, 2004 | 01:07 PM
SMigneco's Avatar
I had the light on when I picked up my car from the dealership. I found they were at 42 psi per tire. I dropped them to 32 psi per the book and the light stayed on. I inflated them to 38 psi per tire and the light has not come on since. Just in FYI. I think the light comes on below 32 psi and above 40 psi but I am just speculating.
Old Jun 11, 2004 | 01:42 PM
sohcpunk's Avatar
If the tire pressure light is blinking, it means that the car is not getting a signal from the sensors. If it stays on, then the pressure is wrong. I had so much trouble with the TPMS that the dealers have to replace both the unit in the car and the sensors in the wheels. For some reason they said there wasnt a signal. But its fixed now After going back to the dealers 5 times!
Old Jun 11, 2004 | 03:59 PM
dsorx's Avatar
The technician said that 2 tires were over-inflated and 2 tires were under-inflated setting off the sensor. I check the pressure and the tires were fine. Anyway, at least the light does not come on anymore.
The PCM flash is very noticeable. When the car shifts from 1st to 2nd gear, the rpm's don't drop as much as before and there is much more power.
Old Jun 11, 2004 | 04:04 PM
HeelnToe's Avatar
Just a quick note... I swear I read something in the manual about the sensor not resetting itself until you reach a certain speed. Meaning, simply changing the pressure won't make the light go off. Ya gotta drive it first. I think..
Old Jun 11, 2004 | 04:06 PM
loco4rx8's Avatar
BSG 75
You are checking the pressure when the tires are cold, right?
Old Jun 11, 2004 | 10:34 PM
rx8cited's Avatar
Senior Member
Good info on how our TPMS works can be found in the Tire Pressure Monitoring System Service Tips service bulletin.
rx8cited
Old Jun 11, 2004 | 10:38 PM
rx8cited's Avatar
Senior Member
Originally posted by SMigneco
...I think the light comes on below 32 psi and above 40 psi but I am just speculating.
TPMS light comes on if pressure is not between 26 to 49 psi. Stock (summer) tires should get 32 psi cold, snow tires get 34 psi cold.
rx8cited
hppy4u
Gulf For Sale/Wanted
9
Dec 3, 2015 09:11 PM
OnebaddRx8
Oct 17, 2015 10:05 PM
CMRine04
Sep 17, 2015 10:04 AM
fireishot34
Sep 5, 2015 06:45 PM
