Preacher
06-05-2004, 12:05 AM
Whaddaya' think?
http://www.escortradar.com/gtimer.htm
View Full Version : Cool New Toy from Escort,the G-Timer Preacher 06-05-2004, 12:05 AM Whaddaya' think? http://www.escortradar.com/gtimer.htm Omicron 06-05-2004, 01:13 AM These are cool, but have been around a while. It's Escort's answer to the GTech Pro you may have heard about. They definitely have their uses... Preacher 06-05-2004, 08:37 AM Dammit,and I thought I kept up with these things :D I like the GTech Pro Competition,it seems to flog the Escort in $ value-wise in features....am likely gonna' go with the GT Pro C and give 'er a rip. **Btw,the Original GTech's only $139,but imo doesn't compare to the newer unit. Genom 06-05-2004, 10:40 AM You can get original G-techs on E-bay for 50 bucks. MrWigggles 06-05-2004, 04:10 PM Originally posted by Genom You can get original G-techs on E-bay for 50 bucks. For the original, I would say that is overpriced. -Mr. Wigggles Genom 06-05-2004, 10:05 PM True. But it's better than 139 :D smrx8 06-05-2004, 10:32 PM i was about to buy the gtech pro ,is it really worth it how accurate is that? Preacher 06-07-2004, 06:10 PM There are gonna' be a LOT of calibrations....go to GTech's website and read the tech manual,it's about a 40-step setup process,and you need,for best results,to know the EXACT weight of your car (and many,many other things) as well as test on dead-FLAT ground....seems like a bit of hassle for reg. road f'ing around.... In short,it's prolly' accurate if you autocross at level air force base lots or wal-mart parking lots,but with normal driving conditions some of its' readings won't be spot-on.....that's what I was able to discern....and I don't,at the moment,autocross.... I'll likely get one at some point,but the units'll be available much cheaper later in the year,so will likely wait....after reading the fine print I'm not as enthusiastic as I initially was.... |
