View Full Version : ease of installing B&B?
SilverTrigger
06-04-2004, 12:34 AM
How difficult would it be for someone without a lift to install the B&B exhaust? How much room would I need under the car to work? Would just a set of ramps work?
BoxerGT2.5
06-04-2004, 01:30 AM
Ramps is all I used to install my borla.
SilverTrigger
06-04-2004, 01:42 AM
Was it fairly easy? I may get my brother in law to help. He has all the mechanical know-how, not me.
JeupRX-8
06-04-2004, 02:41 PM
All I did was jack it up on all 4 corners, and it took roughly 20-30 minutes. The only hard part is getting the exhaust off the rubber hangers.
TRoy J/
Kain
06-04-2004, 02:42 PM
any tricks/tips for getting it off>?
RolenImportsRX8
06-04-2004, 02:43 PM
use cooking spray and a long flat head screwdriver.
AKBen
06-04-2004, 04:19 PM
I just installed B&B on mine and it's about the loudest thing in town. I ditched the caddy and used their race pipe as well. Do you have to worry about emissions where you are at?
SilverTrigger
06-04-2004, 07:18 PM
I said screw it and had it done by professionals. They had a hard time with the rubber hangers also. This thing sounds great! Emissions is no problem in Arkansas.
spddmn01
06-04-2004, 09:57 PM
hey if you have lyk pb blaster or some wd 40, spray it on the hangers and just use a long flat head screwdriver to pry it off..it should come off easy..thaz what i did with my borla too..
God of Thunder
06-07-2004, 10:05 AM
Easiest way to get one off the hangers is to lube them (WD40, cooking oil, whatever) and use a pair of channel locks. Just put one end on the end of the metal rod attached to the exhaust, the other on the opposite end of the rubber hanger and squeeze.
