View Full Version : weird idle
rx8grl
05-31-2004, 07:04 PM
lately, when i start my car it idles kind of weird. it goes up and down from 1k to 3k. it only seems to do it after i get out of work when it's only been sitting for 6 hours or so. havent noticed it at all in the mornings when i first start it. anyone know what the deal is?
cgrx
05-31-2004, 07:14 PM
It should only idle high from the start and gradually idle lower as the engine warms up. Make sure that your car has the latest"M" flash. If your VIN # is in range.... Here is the bulletin :
http://www.finishlineperformance.com/rx8/docs/01-011-04-1273d.pdf
Print it out and take it to the dealer.
Mr M
06-01-2004, 01:18 AM
1. Check air box for oil and a contaminated MAF sensor
2. Remove any aftermarket intake components or piggyback ECU's you may have.
3. Have a dealer (or anyone with an ammeter) check your front O2 sensor.
4. Just a shot in the dark, check your clutch and neutral switches. They provide input for idle speed control.
