LCD Display all screwy (or the aliens are coming)
Old May 24, 2004 | 11:51 AM
MadRonin's Avatar
Just after I got my RX-8 I noticed that sometimes when it was cold outside, the LCD display for the radio would not show properly. The characters would flash on and off and sometimes do this Matrix-type scrolling. This only happened a couple of times, and only after the car had sat overnight. Usually the problem would go away once I started to drive.
Fast forward to now. We are having summer in May here in the northeastern US, and my LCD display is doing the same thing. Only this time, it's not going away. It started yesterday afternoon on my way home from shopping with the wife, and it hasn't stopped.
I wish I had a picture to show everyone what I'm mean, but I don't have a working camera right now. I did a search and did not find anyone else with this problem.
Has anyone experienced a problem like this?
Btw - I called the dealership to make an appointment so I will let everyone know what comes about from that conversation.
Old May 24, 2004 | 12:00 PM
v300's Avatar
I sort of have the same problem. Mine occurs only when I try to wipe off dust from the LCD. The "smear" eventually subsides and everything is ok.
Old May 24, 2004 | 02:23 PM
MEGAREDS's Avatar
Goh Mifune
Havn't seen that problem yet on the 8, but my telescope has a similar screen and I see that type of problem at low temperatures or when the batteries are low...
BTW, isn't it an LED screen? I think the LED display is a weak-point in the interior design -- it's just not in keeping with the "modern" look. As one of the UK reviewer's noted, it's a throw-back to the first-ever digital watches. "Yech!"
Old May 24, 2004 | 02:41 PM
MadRonin's Avatar
You are correct. It is an LED screen. I should know better. Thanks.
Old May 24, 2004 | 03:40 PM
DJ Freon's Avatar
Um, I'm pretty sure it's LCD, and MadRonin was right. LED can't "smear" when you wipe them because they are a solid state light. It's actually a reverse LCD backlit screen. So it can respond slower in cold weather because LCD are definately affected by temperature. Somebody correct me if I'm wrong, but my screen really acts like an LCD, not LED.
Old May 24, 2004 | 04:12 PM
John Paradise's Avatar
I used to live in Park City Utah and my Truck radio LED or LCD (whichever) would always have this same problem whenever it got really freaking cold, however I don't know about the heat. Had the same truck in Texas for several summers and never experinced the same problem.
Old May 24, 2004 | 09:51 PM
jtimbck2's Avatar
It's backlit LCD. This "smearing" effect is common in cold, but not in warm weather, though it will do it some if you put any pressure on it (such as wiping it).
Old May 24, 2004 | 11:59 PM
GiN's Avatar
GiN
ロンリードライバー
Liquid Crystal Display is similar to those found in most calculators. Light Emitting Diode displays are similar to those used in scrolling marquees (with the individual light bulbs and all).
Old May 25, 2004 | 09:43 AM
MadRonin's Avatar
LCD, LED, whatever it is it's all screwy right now. Yesterday afternoon the ambient temp was 195 degrees according to the RX-8.
I called the dealer and the earliest they could get me in was next Tuesday. Seeing as how it wasn't a major problem, I didn't push the issue.
Old May 25, 2004 | 10:55 PM
GiN's Avatar
GiN
ロンリードライバー
Well if it was 195 degrees out I think a most displays would be working improperly. Cell phones, calculators, computers.. Perhaps you were nearing the boiling point of the display's inner materials?
Old May 26, 2004 | 08:54 AM
jdaled's Avatar
Several others have posted this same problem (including me). It's not a 'smearing' effect, it's a scrambled display. It has to do with connections between the piano black panel and the display. When I press in certain spots on the black panel (like the bottom center of the CD opening) the display will clear up.
JimmyBlack
273
Feb 10, 2020 10:23 PM
Kahl
NE For Sale/Wanted
21
Aug 5, 2017 02:49 AM
Randolph Alvarez
Sep 14, 2015 04:25 AM
projectr13b
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
