Vibration when braking hard?
Old May 23, 2004 | 06:52 AM
et381's Avatar
Hi All,
Just asking if anyone experienced any vibration of the car under hard braking in a straight line? The rear end feels like it vibrates a lot, almost wobbling. What could cause this? Could my brakes be faulty or warpped? I've only driven my car to and from work and done a few cruises, didn't think I was giving my brakes such a hard time.
Old May 23, 2004 | 07:03 AM
Gomez's Avatar
Shifty Bastard.
Check the wheel nuts first.....!
sco's Avatar
sco
Can't say I've had this problem.
Was braking so hard that ABS kicked in? Does the car steer in a certain direction when you brake hard?
Old May 23, 2004 | 07:10 AM
et381's Avatar
Gomez, will check the wheel nuts, but I haven't touched them since I've got the car.
Sco, doen't feel like ABS, it is more a vibration side ways. It was just a long straight road. And there was a bit of vibration right from the steering as well, as in pulling left and right.
Old May 23, 2004 | 07:17 AM
sco's Avatar
sco
Hmm... not good... might be time to visit the dealer.
Could be anything from suspension problems to loose wheel nuts. Only other thing that springs to mind is tramlining due to a really bad road.
Old May 23, 2004 | 07:23 AM
et381's Avatar
Will have to test it again next weekend on a different road. If it is still the case it is going back to the dealer.
Old May 23, 2004 | 08:02 AM
sco's Avatar
sco
Tramlining is probably unlikely. Don't risk your own safety. If it's bad, take it in ASAP.
Old May 24, 2004 | 06:04 AM
ypwpat's Avatar
Maybe a balancing or wheels allignment should fix it
Unless your disc brake is stuffed and need to be resurface.
It happen on my Nissan Patrol, and they have to resurface the disc brake.
This usually happen from Braking Too hard when the Disc brake is Hot. When the Disc Brake is Hot the Metal tend to Weaken therefore easy to bent or change shape.
Maybe someone might correct me if i'm wrong.
Cheers
Old May 24, 2004 | 06:52 AM
Gomez's Avatar
Shifty Bastard.
Man, your sig is way too big,
So long it looks bought on credit,
And although we see how much you dig it,
Maybe it's up for a Hymee edit?
Old May 24, 2004 | 06:58 AM
ypwpat's Avatar
sorry this better?
Old May 24, 2004 | 07:00 AM
Gomez's Avatar
Shifty Bastard.
That is the minimalist approach....:D :D
Old May 24, 2004 | 07:19 AM
sco's Avatar
sco
Bummer... there goes the chance to convince the CFO of he need for a 17" LCD that rotates into portrait mode.
RevMeHarder
Jun 1, 2026 02:30 PM
Trancemission
RX-8 Multimedia/Photo Gallery
46
Dec 2, 2015 07:26 PM
patriotjj
Sep 13, 2015 08:09 AM
TheRedRotor
Sep 12, 2015 07:42 AM
