Anyone with Tein CS Coil Overs?
Old May 22, 2004 | 11:56 PM
Everett's Avatar
Hi all!
How's the Ride?
Softer than Stock?
Thanks,
Everett
Old May 23, 2004 | 01:40 AM
Mikelikes2drive's Avatar
ahh theyre expensive! thats all i know... wouldnt coilovers make the ride stiffer and harder?
Old May 23, 2004 | 01:47 AM
Everett's Avatar
Hi:
The Tein CS Coilovers are designed to be for Comfort.
Here is some information
TEIN Type CS damper was designed to give comfort to sophisticated drivers.
We adapted a hard rubber upper mount for noise proofing and mono-tube type shell case to heighten road holding.
* Improved ride comfort over original shock absorbers.
* A hard rubber upper mount is used for noise proofing.
* 16 levels of damping force adjustment (compression and rebound together).
* Ride height adjustable.
* A mono-tube design and increased shell case diameter allow for 30% more oil capacity,
as compared to OEM shock absorber, to handle the upsizing of wheel with lower profile tires.
* Available for overhaul.
So my questions stands.
How comfy is the ride in the RX8 with de CS's?
Anyone has them?
Thanks,
Everett
Old May 23, 2004 | 10:42 PM
IZoomZoomI's Avatar
Boost needed
how much? i was thinkin about coilovers too but mucho deniro
Old May 23, 2004 | 10:49 PM
oh sorry i guess it wouldnt make the ride stiffer then, but still expensive!
Old Jun 11, 2004 | 01:54 PM
sohcpunk's Avatar
Did Tein ever come out with coilovers for the 8 yet?
Old Jun 11, 2004 | 02:31 PM
Everett's Avatar
Yes
http://www.tein.com/mazda.html
Everett
Old Jun 11, 2004 | 08:48 PM
Kel Rx8's Avatar
if your not 1st your last
i wanted the ten cs
but at time didnt want to spend the money
i happy with my tein stech springs.
but would of loved to do coils..
p.s great pix of the st,eco chasing you. :D
Old Jun 30, 2004 | 10:07 PM
new comer's Avatar
Talking tein flex
hi all.
saw your post about tein cs, from what i have hear, the TEIN CS coil over r pretty soft, cos i have just installed a set of tein flex coil-overs, n they r not to hard, with front 7kg, rear 4kg.
the ride is just a little firmer than stock, but i have front 9kg, n rear 6kg springs coming.
with the rear of the car much more firmer n if u like over steer, this is the way to go, cos is a lot more easyer to control now.
post some pic, when i have them.
RA32425
Series I Engine Tuning Forum
10
Sep 8, 2015 08:53 AM
talonhart2
Aug 26, 2015 04:14 PM
RXeckless
Aug 16, 2015 12:52 PM
RXeckless
Aug 16, 2015 12:51 PM
