Stability problems
Old May 18, 2004 | 01:19 PM
Marcus's Avatar
Stability problems
My RX8 have stability problems. Every little hole or crack on the road make my car goes left or right (dangerously). I went 3 times at the dealer they try 3 alignment settings but I still have the problem. Anybody have experience the same problem?
Old May 18, 2004 | 02:12 PM
Potent's Avatar
Yeah occasionally when im braking up to a light or something if the roads rough it pulls me a bit to one side. The car just grips really well and tries to stick to the road. Id rather it pull a bit on a rough road than have sloppier susp. though.
Old May 18, 2004 | 02:26 PM
brothervoodoo's Avatar
RainMan is Back
read this:
https://www.rx8club.com/showthread.p...t=uneven+roads
If you exibit the issues above, it happens mainly at very low speed and on uneven roads, not an issue.
Old May 18, 2004 | 02:30 PM
RainMan is Back
Marcus, you usually get better results if you just make 1 post instead of the 3 that I found.
This also makes the SEARCH button more effective in finding pertinent info.
Old May 18, 2004 | 02:43 PM
Seenitall's Avatar
All wide, lowprofile tires show some tendency to follow irregularities in the road. I am referring mostly to grooves that run in the same direction the car is travelling. The BMW I had was WAY worse than the RX8.
If you are talking about potholes or bumps causing your car to dart in one direction or the other, you might have a bad ball joint.
theblinkof
Oct 4, 2023 05:24 PM
Shankapotamus3
Mar 14, 2021 03:53 PM
Zube6115
Sep 30, 2015 12:57 PM
tommy26Germany
Sep 29, 2015 10:33 AM
kody59
Sep 28, 2015 03:43 PM
