Ignition Start Button Installed
Old May 13, 2004 | 01:18 AM
AWillsea's Avatar
Gadget Guru
Well folks, I think I finally might have something unique in my 8 in the US. I ordered the Ignition Start Button from Maurice (Canzoomer) and it showed up this morning.
The problem is...The mounting hardware is only setup for Right Hand Drive cars. After much internal debate I decided to mount the button in place of the cigarette lighter as I do not smoke.
I was thinking about mounting it centered on the blank plate for the MD player still not sure which is the best spot.
I will hopefully get a couple of pictures together so you can check it out. There is a definite "cool" factor with having a start button.
Old May 13, 2004 | 05:34 AM
Japan8's Avatar
Int'l Man of Mystery
They do sell plain start buttons, illuminated start buttons and security start buttons (requiring a button push sequence to start) in Japan... you could just mount one of them in a blank spot next to the DSC switch...
Old May 13, 2004 | 08:08 AM
AWillsea's Avatar
Gadget Guru
The appeal that the Mazda button had was that it is plug and play. Still a little difficult to install but NO WIRE CUTTING is the best feature. I would not butcher my ignition wiring harness just for a start button. I'll attach some pics next. What do you guys think (Lighter Replacement or under the Radio in the MD player spot?)
AWillsea's Avatar
Gadget Guru
Pic 1
Wozza's Avatar
hi
Japan8 you got any links or jpegs of the buttons? or where to get them?
Old May 13, 2004 | 08:09 AM
AWillsea's Avatar
Gadget Guru
Pic 2
Old May 13, 2004 | 08:10 AM
Wozza's Avatar
how hard is it to install your self I was st the japan parts site and
they say the instructions are only in Japanese?
Old May 13, 2004 | 08:11 AM
AWillsea's Avatar
Gadget Guru
BTW for those that didn't know...the round edge of the button lights up Red...
Old May 13, 2004 | 08:24 AM
AWillsea's Avatar
Gadget Guru
There were 2 issues with the install
1) I couldn't remove the button from the metal mounting brack which is quite big (It is the size of the coin holder) so I used a dremel cut off wheel to cut it just behind the backing plate of the button.
2) After I plugged it in, it didn't work. There are basically 2 plugs, a ground wire, and a pin replacement which all are very clear in the instruction pictures to hook up. The pin replacement goes into the connector for the gauge cluster (I am thinking that the left hand drive gauge cluster does not have the ground signal the unit is looking for.) I used a wire tap to bridge the wire going to the gauge cluster to the ground wire and it works great.
If it is done this way from the start, you save a lot of time as you do not have to remove the gauge cluster. Though the gauge cluster comes out surprisingly fast (Maybe 5 minutes to remove the gauges)
Old May 13, 2004 | 08:29 AM
Japan8's Avatar
I'll see if I can find a site on the buttons. I saw them today when I was at Jim's and Yellow Hat.
No wire cutting is necessary my man... use wire taps.
Old May 13, 2004 | 01:56 PM
mikeb's Avatar
100% Italian
very nice
that's the first one I've seen in a US car
what was the price??
Old May 13, 2004 | 03:09 PM
kidcas's Avatar
what's the cost of the part and what do u think the cost of labor would be if you has somebody install it for you?
Old May 13, 2004 | 03:41 PM
robertdot's Avatar
If anyone has heard of a biometric "security start button" for the '8, let me know. I'd love to have a thumb print system if it wasn't too difficult to install.
Old May 13, 2004 | 05:29 PM
Japan8's Avatar
I found the site... http://www.the-pivot.co.jp/product/flame-starter.html
The buttons are made by "Pivot" who also makes gauges and shift lights.
Below is the security button when the car is off.
Old May 13, 2004 | 05:32 PM
Japan8's Avatar
The security button/ illuminated button (looks the same) when the car is on.
Old May 13, 2004 | 05:50 PM
Japan8's Avatar
Distance view of the mounting of the button
Old May 13, 2004 | 05:51 PM
Japan8's Avatar
The install kit/parts for the security button...
Old May 13, 2004 | 05:52 PM
Japan8's Avatar
The install/parts kit for the illuminated button
Old May 13, 2004 | 05:53 PM
Japan8's Avatar
Regular Racing Button...
Old May 13, 2004 | 05:54 PM
Japan8's Avatar
Mounted view of the Racing Start button...
Old May 13, 2004 | 05:55 PM
Japan8's Avatar
Racing Start Button install/parts kit...
Old May 13, 2004 | 09:10 PM
AWillsea's Avatar
Gadget Guru
The cost of the kit was $225 from Canzoomer. The labor could be done inside of 1 hour. Depending on the shop rate that you bring the kit to, your total could be $300. It is a pretty easy install except for the mounting of the button itself. Not an issue if you have a RHD RX-8 though...
Old May 13, 2004 | 09:38 PM
liqiud's Avatar
Senior Member
thats tight...going to have to look into that one...i like the push button start...even better if it was fingerprint enabled.
Old May 14, 2004 | 03:10 AM
Wozza's Avatar
Hey guys
just got the start button kit from Japan parts
pics look pretty straight forward
Does anyone have or know the translation from the how to use page and trouble shooting flow chart just in case :D
cheers
Wozza
Old May 24, 2004 | 08:06 AM
kidcas's Avatar
just curious how do you turn the car off using these starter buttons? just press the button again?
