Tran/Diff oil change and Tranny noise?
Old May 11, 2004 | 11:33 AM
Atacdad's Avatar
I've read several threads on the benefits of changing the Trans and Diff oils (Red Line lubes seem to be the way to go). One thing I didn't see was any mention of wether the transmission gets quieter in its operation. I have the much maligned rollover noise at idle in neutral, and I understand the issues/controversy there. But, I also have a lot of gear noise in 5th and to a lesser extent in 6th at low rpms (2.5 to 3K rpm cruise). The car is new at this point ( ~550miles) and I'll probably change the trans and diff oils around the first engine oil change.
Can I expect any benefit in noise reduction?
TIA
AT
Old May 11, 2004 | 12:11 PM
MazdaManiac's Avatar
Exclamation NONSENSE
GOD D*MN IT!!
How many times is this misinformation going to get repeated?
THE NOISE YOU HEAR IN NEUTRAL IS NOT THE RELEASE (THROW-OUT) BEARING !!!
A bad TB will only make noise with the clutch DISENGAGED - ie, with the pedal depressed.
Please people, stop with this already.
Old May 11, 2004 | 12:25 PM
snap-on's Avatar
TRANMISSION GEAR ROLL-OVER NOISE
Applicable Models
Model Starting S/N Ending S/N
2004 RX8 00000000 ZZZZZZZZ
Some customers may complain of a whirring noise from the transmission while at idle N in neutral. The noise may also be described as a light rattling when the AC compressor cycles on. This noise is normal N no repairs should be made. Confirm the gear rollover noise by depressing the clutch pedal, the noise should be eliminated. Compare noise to another vehicle to verify this is a normal characteristic. 1. No repairs should be attempted on vehicles with gear rollover noise.
Can we lock this thread?
Old May 11, 2004 | 01:11 PM
Someone will only ask the same question or make the same assertion without searching.
This noise has been atributed to the TB over and over again despite that TSB being a sticky elsewhere in this forum.
Old May 11, 2004 | 02:00 PM
Atacdad's Avatar
As I mentioned...I am aware of the rollover noise TSB. I was specifically asking about excessive gear noise in 5th/6th at low RPM's... as in cruising down the highway at 60Mph in 6th gear. I get alot of annoying transmission noise...similar to the rollover whirring, but loud enough to be heard over the road noise. Its mildly annoying.
Just wondering if, post break in period, it would be worth going to the synthetic lubes for this reason (other reasons being acknowledged).
AT
Old May 11, 2004 | 02:03 PM
epitrochoid's Avatar
Riot Controller
dont run synth oil. waste of money, and burns to hot to be effective in the motor
Old May 11, 2004 | 02:04 PM
Atacdad's Avatar
Umm, different thread....
Old May 11, 2004 | 02:21 PM
JoeRX8ter's Avatar
Somebody that has the service manual should post a pic of the throwout bearing and clutch assy. A lot of people who have never changed a clutch themselves probably don't have a clue about pressure plates and throwout bearings. One post I read was actually talking about the throwout bearing being inside the transmission case. Maybe I'll be able to throw up a pic if I ever receive my service manual from ebay.
Old May 11, 2004 | 03:25 PM
zoom44's Avatar
THIS PIC OK? I MEAN, BESIDES BEING HUGE?
Old May 11, 2004 | 03:30 PM
Atacdad's Avatar
I have revised my posts to more correctly state my question. I apologize for torquing off Maniac....
AT
Old May 11, 2004 | 06:11 PM
Riot Controller
he said he was switching to synth fluids, so i reminded him to keep using dino dung for oil.
Old May 12, 2004 | 06:52 AM
JoeRX8ter's Avatar
The transmission and the bell housing are integrated. I guess if you explode a clutch you may need a whole new tranny. I know I'm showing my age but my track experience came from running a 67 chevelle with a punched out small block. I know that back then running at Englishtown for certain classes you were required to run a blow proof bell housing and a drive shaft loop to prevent broken components from entering the car.
Old May 12, 2004 | 07:03 PM
oi812's Avatar
I switched both the trans and diff to synth.
I did not notice any noise reduction, but my trans was not very noisy to begin with. I just have the slight whirring at idle, no "gear" noise before or after the trans and diff oil change.
I did notice smoother shifting and have seen about a .3 mpg average jump on the last 3 tanks of fuel since the change. MPG change could be the change to summer fuel though, it's too early to tell.
Skyl3r
Dec 2, 2019 04:51 PM
Silver_Excalibur
23
Jun 6, 2019 07:23 PM
BigMikeATL
May 26, 2016 12:31 AM
RotaryRider
Jul 20, 2015 07:05 AM
