Tanabe NF springs w/ 1 coil cut
Old May 8, 2004 | 10:56 AM
RX8on19s's Avatar
Thumbs up Tanabe NF springs w/ 1 coil cut
I installed my Tanabe NF (Normal Feel) springs and they ride great. It's completely true what they say. It rides like if the car was not dropped. The springs lower the car about 1.4 in the front and 1.2 in the rear.
I was not happy with 1.4 drop in the front so I cut the top base of the spring. This is exactly one coil. The cars now sits about 1 inch lower in the front & still rides great. I feel it corners a lot better now.
Here are some before pictures.
Old May 8, 2004 | 10:57 AM
RX8on19s's Avatar
Before Pic #2
Before Pic #2
Old May 8, 2004 | 10:58 AM
RX8on19s's Avatar
Before Pic #3
Before Pic #3
Old May 8, 2004 | 10:59 AM
RX8on19s's Avatar
After Pic#1
After Pic#1
RX8on19s's Avatar
After Pic#2
After Pic#2
Old May 8, 2004 | 11:00 AM
RX8on19s's Avatar
After Pic#3
After Pic#3
Old May 8, 2004 | 11:29 AM
djmano's Avatar
RX-8 Pilot
damn.........the m-sports have a pretty nice lip in the rear. what offset and widths is that setup?
Old May 8, 2004 | 11:53 AM
RX8on19s's Avatar
djmano,
The offset is 35 and the width of the rear is 9.5. The tire size is 275/35/19.
Old May 8, 2004 | 11:59 AM
MazdaManiac's Avatar
Originally posted by RX8on19s
djmano,
There is no way that rear offset is 35mm.
Old May 8, 2004 | 12:26 PM
RX8on19s's Avatar
Cucumber,
Yes way. Go to the following URL http://www.adrwheels.com/wheels/?sfID1=12&sfID2=22 and read it for your self.
Old May 8, 2004 | 03:01 PM
Kel Rx8's Avatar
if your not 1st your last
btw how many miles you have on the springs ?
Old May 8, 2004 | 03:02 PM
Kel Rx8's Avatar
oh yeah
sorry car looks great
Old May 9, 2004 | 01:58 AM
IZoomZoomI's Avatar
Boost needed
if you wanted it dropped more how come you never went with coilovers? Is cutting the springs safe? looks awesome but doesn't seem like you have much clearance...
Old May 9, 2004 | 12:05 PM
Yes, I see what the spec is stating, but it isn't physically possible.
The stock wheel is 208mm with a 50mm offset, leaving 156mm or 6" of wheel beyond the hub mating surface.
A 9.5" rim is 240mm. If you subtract the 35mm offset, you get 205mm.
That is 8" - the entire original width of the stock wheel!
There is NOT 2" of additional clearance beyond the stock wheel width, so someone, somewhere has the wrong specs (i.e. ADR).
Old May 9, 2004 | 08:57 PM
darkducati's Avatar
That's not how it works. The offset(positive or towards the outside, in this case) is measured from the centerline of the wheel. So the original would be 208/2=104 104-50=54 54mm of wheel width past the hub. The aftermarket rear would be 240/2=120 120-35=85 so the difference is 31mm, or about 1.25 inches. Which is totally feasable.
Old May 18, 2004 | 02:40 AM
leegina's Avatar
RX8on19s sent you a PM! Thanks
Old May 18, 2004 | 03:09 AM
wayneside's Avatar
looks nice...
Old May 18, 2004 | 09:42 PM
leegina's Avatar
One more PM sent. Thanks
Old May 31, 2004 | 04:58 PM
310Guy's Avatar
4AT poor mileage king
What color are those ADR's? Silver or Hyper Black?
Thanks.
Old Jun 1, 2004 | 03:01 PM
monzter's Avatar
Damn nice looking car...saw it in person the other day while driving down your street ( live close by). Car looks awesome.
Rob
Old Jun 15, 2004 | 08:32 PM
RX8on19s's Avatar
They are hyper black......
Old Jun 15, 2004 | 08:34 PM
RX8on19s's Avatar
What color is your 8? You live by Westchester?
Old Jun 17, 2004 | 07:47 PM
CaRisMa_AF1RX8's Avatar
i did the same thing and cut.. it rides okay for now.
here's the pix
Old Jun 17, 2004 | 09:28 PM
-8-'s Avatar
-8-
looks pretty good, though not sure cutting them is the best for the spring in the long run.
