rotary RPM = piston rpm?
Old Feb 24, 2003 | 10:17 PM
ProtoConVert's Avatar
Hi,
when considering torque and HP curves,
does a rotary RPM = a normal 4-stroke RPM?
-joe
Old Feb 24, 2003 | 10:31 PM
wakeech's Avatar
mostly harmless
yup.
RPM is a measure of how quickly the output shaft spins. if you're asking "how fast do the rotors spin", then no: the rotors spin at 1/3 the speed of the output shaft. also, a single rotor'd engine will have twice as many power strokes per output shaft revolution (which is one power stroke per rev) as a 4 stroke single piston engine would (which is one power stroke per two revs)...
Old Feb 24, 2003 | 11:17 PM
so is it still legit to compare rotary dynographs to 4-stroke dynographs? My question basically stems from the Renesis' 9k rpm limit... shoudl I be as impressed with this as I am?
Old Feb 25, 2003 | 12:01 AM
Dilly's Avatar
Sure it is...why not? Power & torque are just what they are, and the crank speed is what counts.
Old Feb 25, 2003 | 12:02 AM
wakeech's Avatar
mostly harmless
absolutely... it's not as if the rotary is cheating to get those nine-thousand output shaft rpm. the torque per revolution and power at a certain rpm is directly comparable to a "regular" four stroke piston engine.
so in short yes, you should be that impressed when you see that the RENESIS is better than the Honda F20C (S2000 motor) in almost every respect: dimentionally smaller, lighter, higher redline, more peak power, more torque at every point in the rev range, flatter torque curve (no "on cam-off cam" behavior), at least competitive emissions-wise, and possibly even better on fuel consumption in a larger vehicle (by 200 lbs or so).
Old Feb 25, 2003 | 12:08 AM
Buger's Avatar
RE member
:D
Old Feb 25, 2003 | 12:45 AM
wakeech's Avatar
mostly harmless
i'd just like to admit that all of that stuff i posted i got from Buger :D he be da man.
Old Feb 25, 2003 | 02:33 AM
eccles's Avatar
Prodigal Wankler
Absolutely. In addition, a two-rotor rotary has two power pulses per crankshaft (eccentric shaft) revolution, just like a 4-cylinder reciprocating engine.
Old Feb 25, 2003 | 03:00 AM
wakeech's Avatar
mostly harmless
that's true, but i think because the power stroke lasts for 270degrees of output shaft rotation (the eccentric shaft or "e-shaft" for our friend ProConVert) as opposed to 180 degress for piston engines, the power strokes overlap more similarly to a six-cylinder engine than four.
to avoid confusion and explain the longer power stroke, i'll refer back to the fact that the rotor itself spins at 1/3 the speed of the e-shaft. the power stroke for the rotor itself lasts only 90 degrees of rotation, from TDC (combustion side) to BDC (expiration side), which translates into 3 e-shaft degrees for every 1 degree of rotor rotation: that equals 270 degrees of e-shaft rotation per power stroke.
Old Feb 26, 2003 | 08:03 PM
PsYcHo_Pilot's Avatar
Basically, the Renisis is a damn good ratary, and the new porting is the main reason, the longer the stroke, the more power, and as has been mentioned because of the 1 combustion per 3 revs, u save fuel , and get a higher redline and a good compression ratio which all adds up to good Hp :D
Old Feb 26, 2003 | 09:31 PM
wakeech's Avatar
mostly harmless
uhhh... i lost you after "the Renisis is a damn good ratary"...
Old Feb 26, 2003 | 10:53 PM
HAHAHAHAHAHAHAHAHAHHAHA
sorry dude lil typo there
ROTARY ROTARY ROTARY ROTARY (a thousand times)
RevMeHarder
Jun 1, 2026 02:30 PM
gwailo
May 14, 2024 06:57 AM
WranglerFan
May 31, 2022 07:51 AM
DVerdeyen
Sep 13, 2015 11:19 AM
rxwilly8
Sep 2, 2015 02:42 PM
