G-tech runs w/ stage 1.1 with l flash
Old May 3, 2004 | 02:33 AM
mqandil's Avatar
I bought ny stage 1.1 from hard 8 10 days ago. Finally I get to have a little fun. Let me start by saying that hard 8 is a wonderful person, and it has been my pleasure to deal with him.
First impression with stage 1 is the car is much smoother. It does appear faster at higher RPM, but can not really tell. I ran few runs this weekend to see if it made a difference. Well it did.
You have to remember guys I do not want to ruin my transmission, so my starts are only with 2000 RPM launches. A quick cluch release and anot a full dump. My inital runs with K flash I avareged:
0-60 7.2
0-1/4 mi- 15.3
After flash to L
0-60 7.8
0-1/4 mi 15.4
With stage 1
I can get
0-60 below 7.0 s easily please see results attached. I actually had a run at 6.4 but i can not downlaod from G-tech it say corrupt set. Remember I launch normally, and shift normally. I bet you I can shave 1 second easily if I tried
0-1/4 mi below 15. in the runs attached I shifted to 4th before reaching 1/4 mi, and I lose precious time in the slow shift...big mistake. In the same run I did 6.4 above I also did 14.46 when I held in third. I will do some more in the next few days.
One more observation the peak horspower with stage 1 have shifted to a lower RPM (just below 8000 RPM). I may experiment with my shift points.
Again this is only was done for myself and only to compare stage 1 with the results from before. The car is capable of doing much better numbers than these.
Mark
Old May 3, 2004 | 02:37 AM
mqandil's Avatar
Enjoy
Old May 3, 2004 | 02:45 AM
mqandil's Avatar
lets try this one more time
mqandil's Avatar
For some reason the image does not want to show on my screen. Can you see it on your screen? Please let me know
Mark
Old May 3, 2004 | 02:50 AM
mqandil's Avatar
file
Old May 3, 2004 | 09:43 AM
RX-8 friend's Avatar
Looks fine Mark. Glad you like the box.
RevMeHarder
Jun 1, 2026 02:30 PM
JimmyBlack
273
Feb 10, 2020 10:23 PM
