It's like they got to the third display in the instrument cluster
Old May 1, 2004 | 08:04 PM
flatso's Avatar
I'm Tantalizing
and ran out of things to put in it. Why does the third ring in the intrument cluster display only have oil pressure and odometer? You would think they could have fit a normal speedometer or maybe volts or something.
Old May 1, 2004 | 08:26 PM
neit_jnf's Avatar
what do you want volts for? what they need is real water and oil temp gauges and real oil pressure gauge. I wouln't mind an optional boost gauge
Old May 1, 2004 | 09:15 PM
nosubstitutec4s's Avatar
9000 RPM Viagera
a boost gague for what?
Old May 1, 2004 | 09:30 PM
Baller's Avatar
Chicks dig me!
For the flux capacitor.
Old May 1, 2004 | 09:47 PM
went_postal's Avatar
Online too much.
Uh... wouldn't you need a turbo for that guage to be useful?
Old May 1, 2004 | 10:19 PM
fietguy's Avatar
hahahahahaha.......classic
Old May 1, 2004 | 10:54 PM
bluesunlion's Avatar
my other car is blue
Thank you, Captain Obvious
Old May 1, 2004 | 11:01 PM
flatso's Avatar
I'm Tantalizing
I am not saying they need anything, it just seems like a lot of wasted space for a oil pressure gauge.
Old May 1, 2004 | 11:20 PM
neit_jnf's Avatar
EXACTLY!! :D
Old May 2, 2004 | 02:25 AM
Nubo's Avatar
Lubricious
Even more of a waste when you consider it's not a "gauge" at all and a 3mm LED would be more effective. If any of real oil gauge you Mazda designers real oil gauge are out there real oil gauge lurking, you should really real oil gauge stand up for a REAL oil gauge. Take the bean counters real oil gauge out for lunch and get 'em drunk real oil gauge or something.
Old May 2, 2004 | 01:13 PM
BillK's Avatar
I suspect it won't happen anytime soon, and I'll tell you why: stupid customers.
It's obviously a completely different class of vehicle, but the Jeep Wrangler had a real oil pressure gauge from 1997-2002, but as of MY 2003 the gauge is an idiot light.
Sensor costs too high? Does it make wiring easier somehow? Nope.
Too many warranty claims for oil pressure concerns that aren't. People who don't realize that oil pressure changes with temperature due to viscosity and so, for example, it's perfectly normal for your oil pressure gauge to read really, really low when sitting at a stop sign after coming off a freeway on a 100 degree day, or just that you're going to see your oil pressure drop as your car warms up (sigh...)
Old May 2, 2004 | 06:06 PM
Deslock's Avatar
WWFSMD?
Yeah, Miatas stopped using real gauges years ago too
What would it take to swap a real oil gauge into the RX8? I assume it's too much trouble to be worthwhile...
Old May 2, 2004 | 06:10 PM
zoom44's Avatar
the radiator idiot light is also there. saw it light up a couple of times yesterday when i was reving the hell out of it.
Old May 3, 2004 | 03:04 AM
BillK's Avatar
I can't speak for the 8, but if it's anything like the Jeep, the oil pressure gauge is not driven by a sender per se but rather by the car's ECU, which tells the gauge what it should read.
This means, on the Jeep, if you install a real oil pressure sender there's still no way to have the ECU tell the gauge the proper reading to display.
If the 8's the same way, it means there's no way to get the stock oil pressure gauge to read, but rather you would have to add a third party sender and gauge...
Shankapotamus3
Mar 14, 2021 03:53 PM
JimmyBlack
273
Feb 10, 2020 10:23 PM
nadodave
Aug 28, 2019 05:55 AM
vapor2
Jul 9, 2016 07:35 AM
Learners_Permit
Sep 27, 2015 07:38 PM
