View Full Version : Cd-r
TODreamer
05-01-2004, 05:48 PM
Have any of you experienced your CD player screwing up as a result of using burned CDs?
I have an Accord and this happened to me. At first I had no clue what was wrong...stick a CD in and I hear clicking and then the player just spits out the CD. I took it to an audio shop and the sales rep told me that hes seen this before and that can happen when trying to play burned CDs in a factory deck....the deck literally breaks.
Spin9k
05-01-2004, 06:51 PM
Mine works fine w/CD-Rs. Try recording at maybe x10 to x16 speed instead of the normal max drive speed. Seems to work better when playing back in an audio only player.
TODreamer
05-01-2004, 07:02 PM
ok thanks....
It doesn't change the fact that my deck is busted, but I'll remember that for future reference.
mysql101
05-01-2004, 07:04 PM
I can't see how a read only drive could break reading a disk. It's got to be something else.
I've been using burned cd-r's since I got mine... no clue what speed my laptop (winxp) burned the disks at though.
loco4rx8
05-01-2004, 08:33 PM
I had a 2000 Accord before my RX-8 and never had a problem with burned disks. I mostly used Yamaha CDRs. In the RX-8, I've used the same Yamaha's and also some Verbatim "Digital Vinyl" CDRs with no problems at all.
bureau13
05-01-2004, 11:50 PM
I don't see any way it can break your deck. Some CD players (usually but not always older models) do have trouble playing CD-R or CD-RW however.
jds
RotorManiac
05-02-2004, 09:08 AM
My RX-8 has the BOSE 6-CD changer and has no problems with CD-R at all. I use samsung 'black' CDs which are nice (car is black too so I love it :cool: ) AND I use also CD-RW as audio CDs!! Everything works much better than I thought...
DreamWarrior
05-03-2004, 01:13 PM
Sounds like the salesman was well adept at audio voodoo.
There are absolutely no reasons a well manufactured deck should break soley due to the use of CD-R (or even CD-RW) discs. They will either succeed in tracking the disc, or fail trying to read the calibration track and reject the disc.
If the deck broke, it was because it was a POS, not because you used a CD-R.
ZoomZoomH
05-03-2004, 01:25 PM
most new OEM head units should be able to read CD-R/RW with no problem.
older OE stereos, that's another story...
mikeb
05-03-2004, 03:11 PM
almost all of my cd's are burned and I've had no problems
KrustyKlown
05-03-2004, 05:40 PM
A CD player is a CD player (as far as the general components are concerned, type and quality of the laser can vary a lot.). I am not sure who make the honda units but alpine used build fords higher end head units. BTW I am talking about units that can actually read CDR media not comparing ones that can to ones that can't.
Maybe the CD was warped a little wobbled when it was spun and the wobble struck something inside?
livitup
05-06-2004, 12:53 PM
Why not take it to the dealer and show them the problem? I am sure they would replace it under warranty.
I've been playing CD-Rs in mine since I bought it and it's fine.
I'm installing the MP3 player this weekend, so I'll have an extra base CD unit... :)
---A
