Which Windshield washer/wiper Fluid?
Old Apr 23, 2004 | 09:18 AM
TORacing's Avatar
My windshield washer fluid ran out and I need to refill it what kind should I re-fill it with and where can I get it? Thanks guys.
Old Apr 23, 2004 | 10:44 AM
nt5k's Avatar
Check out pep-Boys. I think Mobil-1 makes a synthetic fluid now. Costs a little more but well worth it. Make sure to refill the rotary fluid as well..
Good Luck!
Old Apr 23, 2004 | 11:57 AM
Parmer8's Avatar
Use water. If you want to spend the extra cash, go to Walmart/Target and get a gallon of washing fluid for $.99.
Old Apr 23, 2004 | 12:26 PM
blue flash's Avatar
Originally posted by nt5k
Check out pep-Boys. I think Mobil-1 makes a synthetic fluid now. Costs a little more but well worth it. Make sure to refill the rotary fluid as well.. rotary fluid?
Good Luck!
Old Apr 23, 2004 | 12:44 PM
greese's Avatar
use distilled water.
greese
Old Apr 23, 2004 | 12:49 PM
Doctorr's Avatar
Ricer is Nicer.....
Cool Summer.....
Now that summer's here, fill it with the red bug cleaner formula from Walmart or Pep's.
doc
Old Apr 23, 2004 | 06:01 PM
Nubo's Avatar
Lubricious
I use some of the distilled bottled water that we use for drinking (CA tap water generally sucks). For a gallon, I mix in just 3 or 4 drops of "squeegee soap" to help deal with any oily film or bug guts. This works well enough as long as freezing isn't an issue or you don't have severe bug problems.
Tap water will leave mineral deposits, depending on how hard your water is.
Old Apr 23, 2004 | 07:39 PM
Superfan's Avatar
Member
I use filtered water or distilled bottled water, a couple of drops of soap, and a splash of isopropyl alcohol.
Old Apr 23, 2004 | 07:51 PM
neit_jnf's Avatar
I use Rain-X washer fluid
Old Apr 23, 2004 | 08:06 PM
D MENAC 7's Avatar
Moderator with a mycocardium
This is the best stuff because it applies Rain-X every time you use it. They now have a bug removing formulation out too. I never had any freezing up the entire winter with mine.
Old Apr 23, 2004 | 09:09 PM
red_rx8_red_int's Avatar
Huh? Didn't know this product existed. I will start using it. Rain-x is good but I never reapplied as I should so it usually sits around until I have a "detail" day (once a yr avg). Unless it's totally outrageously priced, it looks like a no brainer.
Old Apr 23, 2004 | 09:48 PM
Chief's Avatar
Shoot to Thrill...
I use the RainX stuff too, it's all premixed, just pour it in.
However, it seems to leave some residue around the cap...maybe I just filled it too full, oh well it wipes off easily
Old Apr 24, 2004 | 09:17 AM
nt5k's Avatar
Originally posted by blue flash
rotary fluid?
Don't tell me you never check your rotary fluid..
Next you'll be telling me you never check your exhaust bearings either..
Old Apr 24, 2004 | 10:04 AM
affenage's Avatar
I don 't check my rotary fluid - I just wait until the light comes on to top off. Tha's what idiot lights are for right?
duh
Old Apr 24, 2004 | 10:22 AM
D MENAC 7's Avatar
idiots :D j/k
Old Apr 24, 2004 | 10:23 AM
D MENAC 7's Avatar
Oh yeah, do not forget to check the headlight filters too.
Old Apr 24, 2004 | 10:30 AM
flatso's Avatar
I'm Tantalizing
Tastes just like mom's home cooking
here is the recipe I use:
2 cups
(500 ml) rubbing alcohol
70% isopropyl alcohol mixture
1 cup
(250 ml) household ammonia
2 Tbsp
(20 g) dishwashing liquid
3+ quarts
(3000+ ml) water to make
1 gallon
(or 4 liters)
hint:
use your Mr Clean on filter mode to fill the jug with water
theblinkof
Oct 4, 2023 05:24 PM
airlive
Jun 28, 2020 07:46 AM
XianUnix
Sep 29, 2015 03:48 PM
