Authorized Mod
Old Apr 22, 2004 | 04:35 AM
thew's Avatar
Thews8
Authorized Mod
My new 8
build date 06/03 has a sticker under the hood that says
Autherizd Modifactions
campaign # 1064b
dealer code 42063
does any one know what this is?
what is the modifaction ??
Old Apr 22, 2004 | 08:11 AM
kellybrf's Avatar
probably either the airbag or dynamic dampener recall
Old Apr 22, 2004 | 01:25 PM
zoom44's Avatar
with a build date of 6/03 it could also be the port work that was done. the cat longevity tune that was done at the ports and/or the dipstick replacement.
Old Apr 22, 2004 | 02:29 PM
Doctorr's Avatar
Ricer is Nicer.....
Cool Mod.....
Mine has an 'EPA/CARB' approval sticker for the 'L' flash.
doc
Old Apr 22, 2004 | 02:31 PM
thew's Avatar
Thews8
ok i found out it was the air bag.. but this means that i still need the heat shield , new oil pan, and the ecu flash. right ?
and are they going to send me a letter telling me to take it in for all of this ?
Old Apr 23, 2004 | 01:02 AM
kellybrf's Avatar
not the heat shield, as thats not a recall. whats the oil pan thing?
ps- anyone know the heat shield tsb number?
Old Apr 23, 2004 | 01:08 AM
91vert's Avatar
The heat shield is a recall. It is #1704B.
Old Apr 23, 2004 | 03:03 AM
thew's Avatar
Thews8
i have only the 1604 b sticker.. so mine still needs the shield cause its in that vin series... but could the dealer let me take it off there lot if so ?
Old Apr 23, 2004 | 03:12 AM
thew's Avatar
Thews8
the oli pan issue is talked about here as well.. they replace a sensor to stop givving fals oil levle readings
Old Apr 23, 2004 | 03:18 AM
thew's Avatar
Thews8
http://www.finishlineperformance.com...er_recall.html
this says its a recall.. the dampner issue.. Mine does not have this mod sticker .. should i be concerned
Old Apr 23, 2004 | 03:20 AM
thew's Avatar
Thews8
http://www.finishlineperformance.com.../01_027_03.htm
91vert heres the oil pan tsb
gwailo
May 14, 2024 06:57 AM
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
Prescription 8
Non-Rotary Swaps
117
Feb 14, 2018 12:07 PM
Brokegang
Jan 3, 2016 12:45 PM
FubarI33t
Sep 28, 2015 08:45 PM
