Installed - Espelir springs
Old Apr 20, 2004 | 02:03 PM
Potent's Avatar
Just a few shots of the ride height now that they seem to have settled. Overall I like them a lot. Not too agressive but you def. feel the road more and reduced body roll.
Old Apr 20, 2004 | 02:04 PM
Potent's Avatar
another
Old Apr 20, 2004 | 02:07 PM
Potent's Avatar
last one...
Old Apr 20, 2004 | 02:08 PM
Potent's Avatar
oops, forgot the front angle..
Old Apr 20, 2004 | 02:27 PM
Omicron's Avatar
Looks good. :D
Old Apr 20, 2004 | 04:03 PM
mlino01's Avatar
Talking
Looks good , a very similar drop to the Tein H or are the Espiler a bit lower?
Old Apr 20, 2004 | 04:21 PM
BIU's Avatar
BIU
the Htechs = 1" front 0.5" rear
the Espelirs = 1.4" front 0.7" rear
hope that helps.
Cheers
Old Apr 20, 2004 | 04:31 PM
Potent's Avatar
The espelirs I purchased through vividracing were a 1.2 inch drop front and back. Maybe they have 2 different sets not but the ones installed above did a 1.2" front and rear.
Old Apr 20, 2004 | 04:36 PM
pret's Avatar
AbsolutelyNothingHappenin
vivid
sangrine_dark also purchased his from vivid racing. his drop is comparable. i thnk he got 1.25 front and rear. he can clarify if i am mistaken, however, the drop looked good.
Old Apr 20, 2004 | 04:41 PM
BIU's Avatar
BIU
Theres just one set of Espelir springs for the 8..
Vividracing origionally said it was 1" front and back
but maybe its 1.2" after its settled.
Old Apr 20, 2004 | 05:30 PM
Sanguine_Dark's Avatar
Vivid Racing Test Monkey
According to the listings I've seen the espelir's are a 30mm drop and I would have to say that's pretty close to my drop. I love these springs too. Potent, Glad everything worked out with your install.
Old Apr 20, 2004 | 05:45 PM
Potent's Avatar
yeah its all better now.. thanks again for helping out
Old Apr 20, 2004 | 07:57 PM
Ned M's Avatar
So what was wrong with the spring install? You were getting some severe jarring over bumps out of one of the rear corners.
Old Apr 20, 2004 | 08:53 PM
Potent's Avatar
Well what happened was the shop I took it to get installed, they assembled my right rear passenger side shock together wrong. Made some LOUD noises over bumps until we found what they did wrong.
Old Apr 20, 2004 | 09:32 PM
XcelR8's Avatar
When in doubt XcelR8!!!!!
Looks good. Very much like the Tein S-tech on my 8.
Old Apr 21, 2004 | 01:09 AM
fietguy's Avatar
Hey potent, could you pleae describe this situation more carefully,
just for us who decide to install springs we know what to look and listen for if there was a mistake in installation...
im afraid if i just heard a bump over some bumps, i would just assume it was because of the bumps! and not because of the installation...
thanks for an elaboration
Old Apr 21, 2004 | 06:37 AM
Potent's Avatar
As long as you take your time there shouldnt be any problems. Its actually a very east install but I didnt have access to a lift so I decided to take it to a customs shop to get them installed. After they "completed, I took it for a test ride before I paid them and I hit some railroad tracks and it literally sounded like someone hit the side of my car with a sledge hammer. Wasnt a subtle noise at all and was quite obvious that someone did something wrong. After we took it apart and put it back together a few times. (we orginally thought the spring wasn't seated properly) We finally took the whole assembly apart and found that one of the bushings inside the shock was misplaced. Just take your time and its a easy install especially if you get a couple buddies to join in on the fun.
BTW its normal to hear a few noises over bumps when you first get them in, its just the springs settling. Nothing loud though just normal suspension noises that'll stopp after you put some miles on them.
Old Jun 18, 2009 | 07:12 PM
bobtom115's Avatar
wonderful! thanks for the info..
pret personnel
RXFEVER
Aug 29, 2018 10:14 AM
yurcivicsux
192
Sep 12, 2017 10:54 PM
RXFEVER
Sep 11, 2016 02:51 PM
Sakebomb Garage
Sakebomb Garage
Oct 22, 2015 04:28 PM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
