AIr Filter Change Problem
Old Apr 17, 2004 | 06:34 PM
TRZ750's Avatar
Angry AIr Filter Change Problem
Trouble Removing stock air filter. The clips are easy, but couldn't open the box easily to remove the filter. The Owners manual has you disconnect the connector, but that will not help without disconnecting all the harness clips. Anyone have a trick? May be I was just being too careful and had to push harder.
Old Apr 17, 2004 | 08:38 PM
red_rx8_red_int's Avatar
There's a trick to it, try doing a search. I had a difficult time when I first checked mine to make sure there wasn't any oil there and have forgotton the trick, so I'm holding off on removing the filter completely to test if an aftermarket intake will work or not. I think there's a good description in a thread about the oil problem.
Old Apr 18, 2004 | 02:10 AM
Zedcaster's Avatar
If you find the trick, post it here.
I've tried to look at the air filter due to some oil underneath that appears to be dripping out. I can't get the airbox open.
Tried yanking and pulling and...nothing
- it's the airbox I'm talking about...
- get your mind out of the gutter...
Old Apr 18, 2004 | 10:28 AM
Omicron's Avatar
Here's what worked for me.
Removing the factory airbox:
  • Disconnect all vacume tubing and electrical connectors connected to the airbox
  • Loosten the clamp on the acordian tube and push the tube as far back as you can
  • The airbox has 4 "posts" on the underside of it that fit into holes underneath where it mounts. Using a pry bar, pop the top two posts (corner of the airbox by the front edge of the hood) out of their holes.
  • Slide the pry bar down along the underside of the airbox (down and toward the rear of the car) and applying gentle leverage, pop the bottom two out of their holes
  • Leave the pry bar in place to prevent the posts from going back into the holes, grasp the airbox from the sides and lift it to the rear of the car and up. You have to fight against the tension of the accordian tube a bit, but with patience and a bit of a struggle, it will eventually come out
Hope this helps... it's what worked for me. If someone has a better/easier method, please post it up here.
Old Apr 18, 2004 | 03:36 PM
sferrett's Avatar
Whaaaa?
There is a thread on how to remove the airbox cover, with pics, somewhere here...
https://www.rx8club.com/showthread.p...pen+air+filter
I believe I used that method (pushing the filter box assembly back out of it's grommets) when I was checking my filter for oil (which there was none) and it wasn't too bad.
Old Apr 18, 2004 | 04:34 PM
Yep, that's the thread. Thanks sferrett!
Old Apr 18, 2004 | 07:22 PM
Now with clear instructions, I did two runs, one normal, and one with the filter removed. It could just be expectations, but the run w/o filter seemed better and I think my car may benefit from an aftermarket intake. Now which one?
Old Apr 18, 2004 | 09:19 PM
rx8miami's Avatar
typhoon baby!
ironj221
36
Jan 20, 2026 08:28 PM
Audio Concepts ATL
Sep 26, 2021 01:59 PM
uZu
Dec 30, 2015 12:35 PM
GK1707
Dec 2, 2015 10:01 AM
MrORAN6E
Jul 24, 2015 09:32 AM
