Yokohama - AVS ES100
Old Apr 15, 2004 | 09:50 AM
RX8-TX's Avatar
Senior Geek
Has anyone tried them? I am looking for tires, and there are not too many options with 225/45/18. And I wouldn't like to get lower profile tires.
So in my search I came acrosss these AVSES100 Yokohama's. My problem, I have never used them. If anyone has any experience, I am all ears..
http://www.yokohamatire.com/TireIntro.asp?TireID=9
Old Apr 15, 2004 | 10:34 AM
Omicron's Avatar
Actually, Tirerack.com shows 8 different tires in that size... check it out, here.
As for which tires to pick, first decide what you want them to do. Max summer/dry road performance, max winter/slick road performance, or best compromise between the two extremes. Then based on what you want, start reading the customer reviews on Tirerack about the specific tires that fit your needs, and pick the one that you like the sound and look of the best. It's also a good idea to look at the treadwear number, as some tires (numbers below 200) will wear out quickly.
Finally, I'd also suggest you don't limit yourself to just the one size you listed. Lots of different widths/sidewall heights will fit on the RX-8's stock wheels, and if you go with a different size, it expands your selection in tires quite a bit. For instance, while the stock size is 225/45-18, I went with 245/40-18s, and they fit (and look) great! Spend some time hunting around in this forum to find out what sizes fit.
Coupla more things, now that I think about it...
First, a great tire size calculator that allows you to actually see what the different sizes look like on the wheels is here. The same site also has a great explanation of what all the sizing info means, here. And finally, if you want Ultra High Performance all-season tires, I can highly recommend the (oversized, 18") Pirelli PZero Nero M+S tires that I went with. You can read about them, here.
Hope this helps!
Old Apr 15, 2004 | 10:42 AM
Genom's Avatar
Not so Super right now
I have been doing a lot of research and it looks like those tires are soon to be on my car as well Omicron. I dont need to worry about snow over here, but they also got great dry and wet handling as well as a good tread life. Cant be beat for 150 bucks each.
Old Apr 15, 2004 | 10:43 AM
flatso's Avatar
I'm Tantalizing
They are a very good tire for the money. This is from feedback on the Roadfly Z3 board I have never used them myself.
Old Apr 15, 2004 | 11:14 AM
Omicron's Avatar
Yes, they are indeed excellent tires. :D
Old Apr 15, 2004 | 03:16 PM
livitup's Avatar
Twisties for 1000, Alex
I used these exact tires, though in a different size. I had AVS ES100s on my Mitsubishi 3000 GT in 225 / 55 / 16.
I loved those tires. They were excellent, both as sport tires when carving up twisties, and in the rain. I would highly recommend them, especially at the price they cost.
---Andrew
Old Apr 15, 2004 | 07:10 PM
RX8-TX's Avatar
Senior Geek
That's where my quest started....and I spotted the Yoko's awhile back on a R&T ad.
I guess Im looking for some good replacement for the stock rubber. As you said: a good compromise between performance and durability/reliability.
The Pirellis have 220 I think, I couldn't find rating for Yokohama.
I thought about supersizing. The only thing I don't want to do is mess with the tirewall height.
Hope this helps!
I read your thread awhile back. I guess I'll check into them...but they are slightly more expensive than stock rubber / Yoko (Yeah! I am a cheap bastard!)
Old Apr 15, 2004 | 07:11 PM
RX8-TX's Avatar
Senior Geek
Are you referring to the Yokos or the Pirellis Omicron was talking about?
Old Apr 15, 2004 | 07:14 PM
RX8-TX's Avatar
Senior Geek
---Andrew
How was tread wear on them? Did they hold up together w/abuse included?
Old Apr 15, 2004 | 07:21 PM
flatso's Avatar
I'm Tantalizing
Yokes
Old Apr 15, 2004 | 07:57 PM
Omicron's Avatar
Actually, the Pirelli's have a treadwear of 400, not 220. Significant enough improvement to take note of.
Happy I was able to help. Be sure to let us know what you get!
Old Apr 15, 2004 | 08:54 PM
rx8cited's Avatar
Senior Member
...I couldn't find rating for Yokohama.
Yokohama AVS ES 100 - Treadwear: 280, Traction: AA, Temp: A. Please let us know how you like them if you get them.
Also, you may be interested in the AVS ES 100 data sheet off the Yokohama URL you posted.
Old Apr 15, 2004 | 09:06 PM
09Factor's Avatar
Original Turbo 'd Auto !!
how is the noise level on the AVS Es 100's?
I drive a lot a freeways.
Old Apr 15, 2004 | 09:18 PM
RX8-TX's Avatar
Senior Geek
Thank you!
Thanks Omi!
Thanks everyone!...will soon have to make a decission since the Potenza's are close to expire.
Old Apr 15, 2004 | 09:47 PM
Omicron's Avatar
Happy to help. :D
But, if yourPotenzas are close to expiring, I'd be curious as to how many miles do you have on them?
Old Apr 15, 2004 | 09:49 PM
RX8-TX's Avatar
Senior Geek
Happy to help. :D
I am about to cross....only 10K miles. I guess I haven't been nice to them. I think I can get another rotation (5K miles more) and change if I push it. But.....I don't want to have nasty surprises while driving.
Old Apr 23, 2004 | 08:35 PM
rx8miami's Avatar
my brother switched to yokos on his s2000 from dunlops and they are awesoem for the $. they are great minimal road noise great tread life and stick like glue. nice tires.
Old Sep 1, 2004 | 09:58 PM
John00GTP's Avatar
Talking
https://www.rx8club.com/showthread.php?t=38107
I have a set of them for sale right now!
Still available too!
:D
Old Sep 1, 2004 | 10:25 PM
RX8-TX's Avatar
Senior Geek
UPDATE: I am way past 16K miles and the friggin' Potenzas still have plenty of thread. I really really want to switch tires :D
Old Sep 1, 2004 | 11:18 PM
Cam's Avatar
Cam
this space for rent
As long as were talkin tires, When my Potenza's wear out (gonna be a while), Im going with something like the BFGoodrich g-Force T/A KDW 2. Specs- 300 AA A.
Old Sep 1, 2004 | 11:46 PM
Fanman's Avatar
I'm looking at BF Goodrich Comp TA KD tires (no need for the all weather of the KDW) or the Michelin Pilot Sport 2's Both are pretty much the best tires out there. I will probably go to 245/40/18
Old Sep 2, 2004 | 09:03 AM
RX8-TX's Avatar
Senior Geek
245/40s should give you almost exactly the same overall diameter, right?
Old Sep 2, 2004 | 10:21 AM
rx8cited's Avatar
Senior Member
Try the calculator you quoted in this post of yours https://www.rx8club.com/showpost.php...35&postcount=7
Diameter Difference: 1.01%
Since the 245/40 is wider, are their any rubbing problems with it?
rx8cited
Old Sep 2, 2004 | 10:30 AM
John00GTP's Avatar
225/45R18 - Overall Diameter: 25.97 in 659.63 mm
225/40R18 - Overall Diameter: 25.08 in 637.03 mm
245/45R18 - Overall Diameter: 26.68 in 677.67 mm
245/40R18 - Overall Diameter: 25.71 in 653.03 mm
Hope that helps!
Old Sep 2, 2004 | 10:40 AM
RX8-TX's Avatar
Senior Geek
rx8cited
What I meant is:
I assume you will use stock wheels. The stockies are 8" wide.
With the 225/45/18 & stock rims, you get an overall diameter of 25.97" - If you go from 225 --> 245 & 45 --> 40, the overall diameter of the tire won't be affected that much. Why? the aspect ratio is lower, but width is greater. One compensates for the lack of the other....
Anyways, here is a good read:
http://www.enjoythedrive.com/content/?id=25824
And I don't think you'll have serious rubbing problems...the big issue is when you upsize your wheels as well. If you keep the stock ones (8" wide) & the 245s fit....no drama.
