Valentine 1
Old Apr 14, 2004 | 03:44 AM
HiTMaNN's Avatar
RX-8s Official Cool Guy
Valentine 1
anyone know how i can hardwire this thing to the car instead of the stupid ciggerate lighter in my way?
Old Apr 14, 2004 | 04:17 AM
AdictiveRx's Avatar
Install of Valentine 1 radar
Its pretty easy, i just did it. The unit should have come with a part that has two "jacks" and two wire leads. If you have it than keep reading...
On the right side, open the fuse box panel. The 3rd fuse down (20A) is the one for the accessory outlet. Splice into it either from the back of the fuse block (i think its the neon green wire) with the positive lead on the Valentino power block part thing. Find any ground wire and splice into it with the black lead.
Install the power block behind the fuse block.
Since the Radar uses a phone line type wire than any phone cable can be used.
Start by mounting the unit wherever you chose. Then pluck in the phone type cable to the unit FIRST and begin running it along the crease between the window and the dash (run it left obviously) Then along the left side and finally down to where the fuse block is, tucking the wire anywhere it is not seen or disturbed. Under the rubber seal worked for me.
That should do it.
Good Luck!
Old Apr 14, 2004 | 04:18 AM
AdictiveRx's Avatar
correction...
The LEFT side fuse box (my bad)
Old Apr 14, 2004 | 08:03 AM
WHealy's Avatar
Mr. Blue Man
HitMann,
Looks like AdictiveRx has given you some solid info. If you want additional info, check out this thread started by Attack. Lot's of stuff and alternatives there.
Old Apr 14, 2004 | 08:08 AM
flatso's Avatar
I'm Tantalizing
how do you get behind the fuse box?
Old Apr 15, 2004 | 01:14 AM
AdictiveRx's Avatar
Valentine 1
the fuse block is on clips. just pull, GENTLY!
-good luck
surfsecret
112
Mar 10, 2007 01:08 AM
LoKnLoD
Feb 11, 2005 10:56 AM
nshb
Jun 6, 2004 10:21 PM
