how to change front blinkers?
Old Apr 10, 2004 | 03:38 PM
kellybrf's Avatar
is there a trick to accessing the bulbs? i think i can reach the drivers side one but the passengers theres no well in hell. am i missing something here, or do i just need bird arms and tiny hands?
Old Apr 10, 2004 | 06:03 PM
elgueroloco's Avatar
you know that your supposed to replace them from the wheel well, right? its not too difficult if you get the whole cover off, just make sure you turn your wheels all the way to get more space to work with. i got mine in and it wasnt too much work, just looked at the owners manual and followed instructions
Old Apr 10, 2004 | 06:46 PM
whosyourbaba's Avatar
yea, agree I did mine. Just go under the wheel and get most of the twisty screw things off and then just get it off. THe same method you can reach the highs beams and HID. For a quick note. CLICK THE BULB IN TIGHT! I dropped one of mine in the light housing. TOOK HOURS TO GET IT OUT! Just a heads up. But its pretty easy. IN manual also.
Old Apr 10, 2004 | 10:01 PM
kellybrf's Avatar
hmm, i initially thought thats where you access it from but after further inspection thought differently. i mustve not looked close enough, ill have to check again. thanks guys
Old Apr 15, 2004 | 02:04 AM
rx-81688's Avatar
from what i've been told, that u can also do it from under the hood, and on the pass side u have the remove the ecu cover, which way is easyer? anyone thanks
Old Apr 15, 2004 | 05:45 PM
kellybrf's Avatar
i originally took the ecu cover off and theres no way in hell im going to be able to reach that passengers blinker
motohegg
Aug 23, 2015 08:14 AM
RXeckless
Aug 16, 2015 12:51 PM
MarkX
Jul 31, 2015 07:50 AM
