uninstall front rotary accent
Old Apr 8, 2004 | 10:39 AM
JY-8's Avatar
Question uninstall front rotary accent
hi guys,
i have the front rotary accent installed on my 8, and i just ordered the front air dam few days ago.
So i have to take the front rotary accent out before installing the front air dam.
my question is: how easy to take it out without breaking anything???
thanks
Old Apr 8, 2004 | 10:46 AM
my10ae's Avatar
Moderator
JY-8:
I just installed my front rotary accent this past Sat. The thing to watch out for is removing those 2 little push screws that help hold the accent in place. I would remove both screws in the rear upper corners of the accent. I would then use a hairdryer to heat the accent to soften up the double-sided tape and then just pull the accent off. Cleanup the leftover sticky stuff from the tape with goo-gone and you should be good to go.
Not sure if those 2 push screws are really necessary to hold the accent in place, but if they break, you still have the double-sided tape to hold it in place. Hope this helps...
Old Apr 8, 2004 | 02:19 PM
BIU's Avatar
BIU
The air dam doesnt allow the use of the front rotary accents?
Or just that ou have to remove it inorder to install the air dam then install the accent back?
Old Apr 8, 2004 | 02:52 PM
XeRo's Avatar
Normality is Obscene
wait you shouldn't have to...i don't think...if it's the Mazda App pack air dam then it should go on with no problem...
Old Apr 8, 2004 | 08:54 PM
JY-8's Avatar
thanks for the info
wow! you need to take the bumper off when installing the air dam...?!
i just ordered the frt air dam, so i don't know the instructions, but i believe that i have to take the accent out before installing it.
Old Apr 8, 2004 | 10:01 PM
JY-8's Avatar
i'll take it to the body shop (i have the whole appearance package to put on), i hope they will do a good job for me....
thx for the information
Old Apr 8, 2004 | 10:02 PM
Spin9k's Avatar
Momentum Keeps Me Going
Wow - Nothing is simple - one thing leads to another and another...
MsKingRotary
Apr 23, 2016 05:45 PM
RotisserieEngine
Sep 26, 2015 12:57 PM
dancingdan42
Aug 19, 2015 09:29 AM
AussieGray
Jul 16, 2015 03:58 AM
