ECU cover HELP!
Old Apr 2, 2004 | 10:16 PM
BIU's Avatar
BIU
ECU cover HELP!
Ok i am trying to take out the ECU box and i've followed the exact instructions from this picture by removing the three bolts...
https://www.rx8club.com/attachment.php?postid=216830
but the cover still wont come off?!
It seems like theres still something holding onto the cover on the side with the one bolt.
Need help !
Old Apr 2, 2004 | 10:47 PM
Tony Orlando's Avatar
Bored thread resuscitator
You need to release two small clips holding the box cover on. I recommend a small probe with an angled tip. Slide it uder the clips, and gently move them away from the bottom half of the box. Gently is the key word, since they are plastic.
Look between the fender insulation and the box, and you'll see 'em.
Old Apr 2, 2004 | 10:53 PM
seikx8's Avatar
Is this title ok?
The side clip near the fender side is a pita to get off with out proper tool.
Old Apr 2, 2004 | 10:58 PM
seikx8's Avatar
Is this title ok?
And here is the detailed diagram from the shop manual
Old Apr 2, 2004 | 11:04 PM
BIU's Avatar
BIU
thanks for the replies guys... but i still dont get it...
when im looking down on it like the picture....
do i PUSH the tabs on the clips? or PULL?
Thanks.
Old Apr 2, 2004 | 11:20 PM
seikx8's Avatar
Is this title ok?
It's hard to push the tab. The best way I found was to insert a small flat head screwdriver from the side/edge of the clip and prive the outer tab (connecting to the top piece) out from bottom/inside piece
If you have a small hand, then you may use your finger to grab the outer edge of the tab and pull outward; I tried but not successful without a tool.
Are you trying to instal/modify something?
Old Apr 3, 2004 | 03:58 AM
Speed-ER doc's Avatar
yes, I bite
I just pulled really hard until the damn clip broke. Try it, it works! And it's barely even noticeable. :D
Old Apr 3, 2004 | 05:11 AM
BIU's Avatar
BIU
well im trying to change my parking lights....
but is taking off the wheel well piece easier?
Old Apr 3, 2004 | 10:06 AM
Omicron's Avatar
Yes, it is. Even with the PCM cover removed it's still almost impossible to reach.
Old Apr 3, 2004 | 10:32 AM
shebam's Avatar
Bebop driver
Re the side clips on the ECU cover, softening up with a little WD40 helps in prying up with an angled probe. Also, if you grab the cover and slide it towards the fender a bit it can help persuade them to let go. (Ulitmately, plastic tabs do break off as they do on the battery cover if you're not careful.)
Jst4fun
Apr 17, 2021 07:43 AM
Oct 3, 2015 09:51 AM
SimonT182
Oct 2, 2015 10:33 AM
Evan Gray
Sep 26, 2015 12:30 PM
