View Full Version : DIY: Lowering Springs Install
synthtk
03-17-2004, 07:59 PM
After a long hiatus of messing with the RX8 because of my Eclipse I had a chance to finally install my Tanabe GF210 springs.
Here is a short write-up/pictures of the process. This is my first how-to so sorry if it’s a bit rough ;)
Ill try to get a full side shot this weekend after I wash the car
### IMPORTANT NOTE ###
If you don’t want to read the whole thing it goes pretty much like any other spring install or syntrix's JIC install how-to but with one catch....
Before tightening the upper front control arm bolts (but after screwing them in most of the way) put the car back on the ground so the suspension gets preloaded and then tighten it down
I even took a quick trip round the block before tightening them down
synthtk
03-17-2004, 08:00 PM
### Before ###
Pretty Orange....
http://www.tiora.net/~chris/rx8/tanabe_springs/DSC00225.JPG
Before Front
http://www.tiora.net/~chris/rx8/tanabe_springs/before_front.JPG
Before Rear
http://www.tiora.net/~chris/rx8/tanabe_springs/before_rear.JPG
## NOTE ## when retightening the bolts I used pretty much hand tight plus some, if anyone has a factory manual and can chime in with the proper torque specs for the various bolts that will be great.
## NOTE ## passenger side is same as drivers side except where noted
synthtk
03-17-2004, 08:01 PM
### Rear Springs ###
1) Jack up the rear of the car, i jacked under the rear diff and placed jackstands under each side of the rear to secure it
http://www.tiora.net/~chris/rx8/tanabe_springs/DSC00226.JPG
2) Remove the wheels
3) Under the car mark the lower control arm alignment bolt so you can return it to the same setting, mark the front and back of the bolt (bolt and nut side)
4) For driver’s side, remove the 10mm nut that holds the lever to the headlight adjustment control
5) Undo the 14mm nut to the swaybar link and swivel the link out of the way
6) Remove the 17mm alignment bolt for the control arm
7) Wiggle the control arm until it drops out of its bracket
8) Remove the 12mm bolt near the top of the strut where the strut goes into the trunk area
9) Pop the trunk and undo the tabs holding the side carpet, pull the carpet back to expose where the strut is
10) remove the 2 14mm at the base of the strut and the 2 14mm bolts into the gold bracket, to make it easier i also removed the 2 14mm nuts and pulled the bracket off
http://www.tiora.net/~chris/rx8/tanabe_springs/DSC00227.JPG
11) You can now pull the strut out; if it seems to get caught on the suspension you can try rotating it like a screw until it becomes free
12) It is recommended you use a spring compressor while undoing the struts so the parts don’t shoot everywhere... but if you don’t have one you can take the strut/spring assembly out where you can undo it without hitting anything (do not point it at other people, cars or property) a front lawn or driveway is good for this.
13) Carefully undo the 17mm(?) at the top of the strut assembly, the assembly will pop apart when it comes off so be careful and remember to gather up all of the pieces if they fly out.
14) Get the rear springs (they will be the slightly longer ones, if you are unsure look 1 or 2 coils under the GF210 badge there will be a part number that reads something like 0312 SE3PR the R stands for rear.
http://www.tiora.net/~chris/rx8/tanabe_springs/DSC00230.JPG
The assembly will look like this
http://www.tiora.net/~chris/rx8/tanabe_springs/DSC00228.JPG
I also trimmed the bumpstop about 1", I would however recommend calling Tanabe and asking if this is necessary and if so how much exactly should be cut, this was a Sunday so I was unfortunately able to call
http://www.tiora.net/~chris/rx8/tanabe_springs/DSC00231.JPG
15) Reassemble the rear strut, if you do not have spring compressors, have a friend thread on the nut while you press the assembly down to expose the threaded end of the strut
The assembled rear strut
http://www.tiora.net/~chris/rx8/tanabe_springs/DSC00229.JPG
Basic order is: nut, washer, donut, strut hat, gold sleeve, bottom donut (has a lip that faces up), bumpstop, spring, strut
It helps if you first put the bumpstop on then the spring then slip the sleeve into the bottom donut and place that on the strut then slide the hat donut washer and nut on
16) The reinstallation is the opposite of the removal, I had a bit of difficulty lining up the bolts that go into the body from the strut assembly so 2 people will definitely help
Screw in the 2 14mm nuts from the top and then the 12mm from the bottom.
17) Reinstall the gold bracket and its 2 14mm nuts and 2 14mm bolts
18) Reinstall the side carpeting
19) Reinstall the control arm in its bracket and slide the alignment bolt back in place, tighten this back down to where your original alignment marks were
20) Reinstall the swaybar link and tighten its 14mm nut
21) If driver’s side, reinstall the arm to the headlight level control and secure with its 10mm nut
Installed rear strut/spring assembly
http://www.tiora.net/~chris/rx8/tanabe_springs/DSC00232.JPG
22) Reinstall the rear wheels, remove jackstands and jack.
synthtk
### Front Springs ###
1) Jackup the front of the car, I slide the jack under the front cross brace and jacked up there, install jackstands to secure the car
2) Remove front wheels
3) Pop the hood, and remove the engine cover
4) Remove the strut tower bar (3x12mm on each side)
5) On the lower control arm remove the 17mm bolt that holds the base of the strut on
7) Remove the two upper control arm 14mm bolts
8) Remove the 3 upper hat 14mm? nuts, after this the strut assembly should drop down a bit and you should be able to angle it out (top first) by moving the control arms it out and remove it from the car,
9) It is recommended you use a spring compressor while undoing the struts so the parts don’t shoot everywhere... but if you don’t have one you can take the strut/spring assembly out where you can undo it without hitting anything (do not point it at other people, cars or property) a front lawn or driveway is good for this.
10) Carefully undo the 17mm(?) at the top of the strut assembly, the assembly will pop apart when it comes off so be careful and remember to gather up all of the pieces if they fly out.
The front spring is much more compressed so be careful as the parts will fly everywhere so keep it clear of everything.
Stock front strut assembly
http://www.tiora.net/~chris/rx8/tanabe_springs/DSC00233.JPG
Blown apart front strut assembly
http://www.tiora.net/~chris/rx8/tanabe_springs/DSC00235.JPG
11) Get the front springs (they will be the slightly shorter ones, if you are unsure look 1 or 2 coils under the GF210 badge there will be a part number that reads something like 0312 SE3PF the F stands for rear.
12) Reassemble the front strut; if you do not have spring compressors, have a friend thread on the nut while you press the assembly down to expose the threaded end of the strut, this will be much more difficult than the rear strut
13) The reinstallation is the opposite of the removal, first slide the strut assembly back through the upper control arm and under the fender
14) Screw on the 3 14mm bolts for the upper hat
15) Reinstall the 17mm bolt through the base of the strut
16) Screw in the 2 14mm upper control arm bolts but do not tighten them all the way.
If you tighten them now when you rest the car down the front will be excessively high and the rear will look squatted like in a weight transfer, dont ask me how I know this :o
Front strut assembly installed
http://www.tiora.net/~chris/rx8/tanabe_springs/DSC00236.JPG
17) After both sides are complete reinstall the strut tower bar 3x12mm on each side, and reinstall the engine cover
18) Reinstall the wheels
19) Lower the car down and let the car settle on the front suspension, I took a quick drive around the block
20) Rotate the wheels so you can tighten the upper control arm bolts.
21) Enjoy your new springs :D
synthtk
03-17-2004, 08:02 PM
### AFTER ###
After Front
http://www.tiora.net/~chris/rx8/tanabe_springs/after_front.jpg
After Rear
http://www.tiora.net/~chris/rx8/tanabe_springs/after_rear.jpg
success07
03-17-2004, 09:10 PM
Probably won't attempt this little project myself but awesome work!!! Thanks for sharing and taking the time to do step by step! That adds an extra couple hours or more to the project I'm sure. Especially the write-ups!
You should probably put this in the DIY Section as well.
P.S. How about some pics of the whole car also.
mdw33333
03-17-2004, 09:46 PM
My dealer wants $220 to install my Tein springs, and I think I'll pay it.
SDFLY
03-17-2004, 09:51 PM
Yeah dude, whole car pics! And where did you order yours and price?
jerrymac
03-17-2004, 10:43 PM
Outstanding synthtk, thanks for taking the time to photo and write up the directions. Now we all need a side shot of the entire car.
Omicron
03-17-2004, 11:14 PM
Very nice job! :D
synthtk
03-18-2004, 01:56 AM
http://www.iapdirect.com/ $165 + shipping which was about 18 bucks if i remember right
PICS!
Ill see if I can get one tomorrow dont blame me if the car is horribly dirty tho! ;)
-Chris
synthtk
03-18-2004, 07:51 PM
Some after pics as requested, thanks for all the compliments on the writeup, ill see if I can do some more, I think I have some pictures from my XM and shift knob install
http://www.tiora.net/~chris/rx8/tanabe_springs/DSC00924.jpg
http://www.tiora.net/~chris/rx8/tanabe_springs/DSC00926.jpg
http://www.tiora.net/~chris/rx8/tanabe_springs/DSC00927.jpg
http://www.tiora.net/~chris/rx8/tanabe_springs/DSC00928.jpg
http://www.tiora.net/~chris/rx8/tanabe_springs/DSC00929.jpg
synthtk
03-18-2004, 07:55 PM
Ok, why arent the images showing now?
Sanguine_Dark
03-18-2004, 08:08 PM
Very nice job. I didn't have the patience to do a step by step. Your post is extremely informative!!
Good luck with them.
S_D
310Guy
03-18-2004, 09:28 PM
GREAT DIY !!!
I like the drop a lot. Nice "balanced" look (rear doesn't look dropped more than the front due to wheel well design).
:cool:
XeRo
03-19-2004, 09:33 AM
Very nice job for a first D.I.Y., congrats your ride looks great!
PUR NRG
03-19-2004, 11:46 AM
Good article. Mentioning the size of each bolt is something easily overlooked but makes it much easier to follow. The only recommendation I could make is to have pictures with arrows indicating each bolt so there's no mistake or problems with identification.
What about torque values for each bolt? Is there a recommended value or is it just "gutentight"?
lilbigman
03-19-2004, 11:53 AM
Wow thanks for the play by play :)
Great looking ride !!!
synthtk
03-19-2004, 04:10 PM
I wish I knew the proper torque specs, but I dont have the factory service manual, I basicly tried to put them back as tight as it felt when taking them off, non were really tight so i just did hand tight with a 3/8 drive ratchet + some
Like i said in the 2nd post if anyone with the proper torque specs from a factory service manual or something please chime in ;)
Next DIY ill add the arrows ;)
SDFLY
03-20-2004, 11:55 AM
Nice job synthtk....After giving up on waiting for the Tein, I am expecting the Tanabes to show up Monday and with any luck I'll have rims by next weekend too....the car looks "right" now.
XDEEDUBBX
03-20-2004, 12:12 PM
thats a nice drop...really clean...didn't notice too much of a camber change...how much were the springs and where did you order it from?? sorry if it was posted already..im just lazy to look back..thanks
synthtk
03-20-2004, 05:16 PM
XcelR8
03-21-2004, 09:47 PM
Great D.I.Y....and just in time.
Tein S-tech springs on order and should be arriving beginning of the week. Called all over last Thursday and found out that Tein has them backordered until late April. Found two sets at OptionImports for $174 including shipping. There web site is www.optionimports.com if anyone want it. Will post picks after installed.
synthtk...did you have it alligned after the install? If so, was it off much?
SDFLY
03-23-2004, 11:09 PM
Originally posted by XcelR8
synthtk...did you have it alligned after the install? If so, was it off much? [/B]
Mine going on Thursday...any input on alignment after install?
XcelR8
03-25-2004, 05:59 PM
Received my Tein S-Tech springs yesterday. Looked over the directions and I am so glad for this forum. The supplied directions are not great. Went on-line to tein and pulled off better ones, but the pics will help. Thank you. My only suggestion is that anyone attempting to do this themselves should use spring compressors. I rented them from an autoparts store by my house for FREE. Only had to put a deposit down that will be returned. I have heard stores of people getting seriously hurt from not using the proper tools for this job. I am planning on installing them in the next couple of days.
XcelR8
03-25-2004, 06:01 PM
BTW...another tread in the parts section for vividracing stated that you should have the car alligned after about a week so the springs have a chance to settle.
sup3rbad
04-16-2004, 06:57 PM
Nothin but praise goes to synthk thanks to this write up I figured out why my front springs didn't settle as well as the back. But thanks to his adive on not tightening the upper control arms i was able to take half an inch off the ride height in less than 30 min. Thanks again synthk
JeupRX-8
04-17-2004, 12:23 AM
Get DIY, I will be doing this in the next couple weeks, as well as new rotors, and powder-coated calipers. It is really amazing how much lowering springs make a differance, we put them on my dad's BMW and it made a huge change as well as my friends 350z. I would recommend this mod to everyone on this board.
Troy J.
dcfc3s
05-10-2004, 10:07 AM
To reiterate, make SURE you get your car aligned soon after installing springs. When you change the suspension geometry that much, the toe changes quite a bit, and you can wear out tires VERY quickly. I installed some springs on a buddy's 2nd gen RX-7 once and he didn't bother getting it aligned. He wore a new set of Dunlop SP8000's down to nothing in like 3-4 months.
Not to mention when you take the suspension apart and reassemble it, you change the geometry. Most fasteners on suspension have some wiggle room and slop - you probably won't get it put back in exactly the same position as it used to be.
Dale
VividRacing.com
06-01-2004, 07:59 PM
To save space, loading time and band width I'll just put the link up to another version of the spring install. This install was done by the forum's own Sanguine_Dark (AKA: Vivid Test Monkey). Please read carefuly if you are planning to install springs on your own. Any questions regarding the install you can contact me directly or PM the Test Monkey and he'll be happy to help you out.
Espelir Spring Install (http://www.vividracing.com/index.php?src=news&prid=238&category=Install%20Tips%20and%20Tricks)
adrian-1
06-30-2004, 09:10 PM
I'll be installing the mazdaspeed springs/ shocks this weekend. All the factory torque specs can be found here. (http://www.cox-internet.com/adrian-1/images/RX8/suspension/)
Sometimes gutentight is too tight. Always follow the torque specs.
RonD-NM
09-02-2004, 01:01 PM
I am going to try installing my Tein-S springs this weekend. But have a question about cutting the bumpstop. Is 1" enough? Has anyone cut more or less?
-Ron
adrian-1
09-02-2004, 01:16 PM
Go to this thread (http://www.rx8club.com/showthread.php?t=27541&highlight=tein+bump) . He cut 3 inches off.
I didn't cut any off since mine are Mazdaspeed and only lower the car about 0.8 to 1 inch.
brillo
09-02-2004, 01:48 PM
I've done the Tien springs, I would follow there advice, which If I remember correctly is 1'' up front and 3/4'' in the rear. Bens car after a week rides great with no issues.
The_Bean
09-02-2004, 01:56 PM
.8 in the front 1 in the rear but about 1 inch on both works.
RonD-NM
09-02-2004, 08:59 PM
Thanks, I found the cut sheet at the bottom of the box. I will follow what they have.
Thanks again,
Ron
ShowandDriftRX8
10-29-2004, 03:13 PM
Just to add to the post, I installed the Tein Flex suspension on the 8 last night and shot a few photos of the rear install. I appologize for not taking photos of the front. I used my stock jack to lift up the suspension to get the sway bar links out and my larger jack to keep the car lifted. After completion the rear seems to sit higher than the front. I will be raising the front up a little to look even with the rear.
09Factor
10-30-2004, 12:15 PM
It may be just my 8, but the Lower Control arm nut/bolt is a 19mm.:confused:
Can anyone else confirm this, like it really matters BTW nice writeup. Nice Coilovers ShowandDrift
Genom
02-03-2005, 04:29 PM
I know this is an old DIY, but pay attention to the front control arm part, and the text about not tightening them while the car is in the air. I didnt :P
Dammit! At least it's easy to fix :D
xrider
02-11-2005, 09:09 AM
I am going to install my tein s techs next week, and had a question. Upon marking the bolt and nut on the rear lower control arm. Do you make a mark just on the bolt and nut? Or do you have to make a mark on part of the lower arm where they would meet(what is the purpose of this step)? Also I suppose you don't have to do this on the front install, since it wasn't stated in the DIY? One more question, why if you completely tighten the upper arm in the front will the car not lower properly? I just wanted to clarify those things before I attempted this DIY
Low Fly'n 8
02-11-2005, 09:07 PM
You are extending the line from both the bolt & the nut onto the control arm in order to be able to return it to the exact position it was in before you removed it. a little dab of paint works too.
You do not have to do this on the front.
If you tighten the upper a-arm bolts (19mm) with the suspension hanging, the rubber bushings will be "preloaded" in this position. I got mine finger tight and then took the car for a quick ride around the neiborhood to make sure everything was settled. The bolts are easy to reach with your torque wrench if you turn the wheels full lock. Good luck with your install. It took me about 6-1/2 hours by myself with no air tools. That *#@% spring compresser! I also got a 4 wheel alignment about 2 weeks after the install.
The car looks and drives awesome with H-Techs. Enjoy!
09Factor
02-12-2005, 02:25 AM
Q about your Alighnment. Did you have the shop Zero out the settings , or did you have them set it back to the stock settings?
xrider
02-12-2005, 08:15 AM
Very nice ride low fly'n, thanks for the clarification on my questions, greatly appreciated.
Low Fly'n 8
02-12-2005, 07:51 PM
Check out this thread. Only the toe settings were out of spec on mine.
http://www.rx8club.com/showthread.php?t=49423&highlight=alignment
modena
04-20-2005, 11:54 PM
Did the spring mod...
Man that rear one were a pain in the ass.
Fronts where no problem..
Pictures are here for those who want to see....
http://www.verlinden-productions.com/wim/Springs_RX_8/index.html
Now I need new wheels.....
MadDashRX8
05-28-2005, 10:12 PM
Just installed my Tein S-Techs last night and this morning. Huge kudos go to Synthtk for his detailled DIY instructions. They convinced me. See details and pics HERE (http://www.rx8club.com/showpost.php?p=895784&postcount=1) :D
M-ster
07-01-2005, 02:46 AM
Can some one please enlighten me.
Why the need to trim the bum stop? Me got the RB spring, don't the spring itself already lowered the car? or need to trim the bum stop to lower the car?
MadDashRX8
07-01-2005, 06:41 AM
The factory strut/bumpstop setup is designed for longer springs. When you install shorter springs, the inner distance from the base of the spring to the end of the bumpstop decrease as well. If you do not trim the bumpstop, the suspensions range of motion will decrease. We're only talking about an inch, but that could be enough to create some issues with wheel travel/articulation. Hope that answers your question. :D
mmats69
07-01-2005, 03:52 PM
Just remember to disconnect the abs sensors before you do it. Got my springs installed yesterday and they ruptured the speed sensor on drivers side. Dealer said it will cost around $600 to fix cause there is so much equipment involved.
M-ster
07-04-2005, 11:32 AM
Thanks MadDash! That's pretty clear explanations!
Thanks mmats, will take note of the sensors!
Thank you guys!
Jump120MPH
07-08-2005, 07:53 PM
I just got my Tein springs today. Ill be putting them on Sunday.
Jump120MPH
07-16-2005, 12:04 PM
Im putting my springs on. How tight does that 17mm nut on top of the strut assembly have to be? Can I tighten it too much?
MadDashRX8
07-16-2005, 08:12 PM
For torque specs, look here (http://www.rx8club.com/showpost.php?p=433899&postcount=31) Post some pics after your done! :D
Jump120MPH
07-17-2005, 08:50 PM
Here are some pics
hondasr4kids
09-25-2005, 10:20 AM
Have any of you look at what the manufactures manual says on how to remove the rear shock? No need to remove the lower control arm. But it does requiere to disassemble the shock while it is in the car. I did mine like that and it took me 30 mins to do the rear. Once the car is in the air the rear springs don't need to be compressed to be removed. The manual tells you to remove the caliper and the hand brake stuff but I didn't do that. But this doesn't apply to coil overs though
MadDashRX8
10-01-2005, 11:03 PM
Wouldda been nice to know a few months ago. Thanks, though. :D
cleoent
12-22-2005, 09:50 PM
wow this is such a pain in the ass, how he hell do i put this damn strut back in, i'm ready to kill something.
cleoent
12-22-2005, 10:08 PM
there is no way these struts were designed to go back in. Put them in from the top or the bottom?
cleoent
12-23-2005, 12:26 AM
half way done (just did the rears). First side took me roughly 3 hours, second side, about 40 minutes.... ha ha ha.
I would HIGHLY recommend taking off the sway bar end link completely. It makes it about 100x easier to take out the shock and put in the new one. Tommorrow i'll do the fronts.
cleoent
12-23-2005, 12:29 AM
one question, do you have to cut the bump stops in the front as well?
swoope
12-23-2005, 01:00 AM
i have been following this tonight. guess it got better. from the thread above, yes ~ 1 inch.
cleoent
12-23-2005, 11:13 AM
They key is to completely remove the sway bar end link. Pretty much just went straight in after that.
NgoRX8
03-11-2006, 09:42 PM
finally installed my s-techs today. this DIY is awesome! I'm now very close to the ground. :)
tiggerlee
03-11-2006, 09:53 PM
Ngo, did you stay with stock shocks?
When I returned home last week after mine were installed I was talking to my neighbor outside,had the car parked in the driveway. The first thing he said was how much better he thought the 8 looked lowered a bit. So far I love the S-Tech/Koni combo. :)
NgoRX8
03-12-2006, 12:53 AM
Yea, I stayed with the stock shocks. As long as it lasts me for a year, I'll be fine. So I can save up money for some tokico d-specs or just give up and go coilovers. how do the s-tech with koni ride?
I definitely like the lowered look, my only problem now is having to do full on parallel angling up driveways, dips, and bumps. cuz of my kit.
oh yea, +1 for cleoent's method of removing the sway bar endlink. really helped.
MadDashRX8
03-12-2006, 10:12 AM
Tiggerlee: What part #/model of Koni's dod you go with? Where'd ya get'em?
tiggerlee
03-12-2006, 03:53 PM
Koni yellow adjustable. If I still had the boxes I could give you a part number. Got them from Driven Performance Equipment. Phil had a group buy going here awhile back. Paid $520 shipped. Right now I've got them set at about 3/4 turn up from full soft. So far I love the combination and I'm very happy with them and the S-Tech springs. From what I've heard DPE may have another group buy in the future. Here's (http://www.rx8club.com/showthread.php?t=84309) some before and after pics.
tiggerlee
03-12-2006, 03:59 PM
Love 'em! Not a huge difference from stock IMO. But haven't tweaked anything yet. I have them set at about 3/4 up from full soft right now. I actually thought about just going with the springs then I figured hell why not save myself some headache and do them both together so I decided on the Koni's.
GeorgeH
03-13-2006, 09:55 PM
I'd like to add this thread some specific information about installing rear Tokico D-Specs. In particular, how to handle the adjustment cables. This info would probably help coilver systems which also come with cables.
The Tokico cables have to be treated with a little care, as they have a tendency to pull apart if you put too much tension on them. For example, if you get the shocks in part way, with the cables attached, and then decide you need to pull the shocks back out (or the shock falls off whatever is holding it up), it's easy for the cables to hang up on an edge while you are extracting the shock, and if you tug too hard, presto, the nuts seperate from the braided stainless cable and now you need a new pair.
And, they are a bit tricky to thread through the hole in the sheet metal. The tricky part is that you can't just stick the shocks up in the body work - the cables need to be threaded out the hole in the sheet metal as you push the shocks up. Your best bet is to get a helper and carefully coordinate your efforts - one person lifting the shock, the other trying to get the cable to come out the little hole.
It helps to tie some string on the cable and thread it through first so you can guide it. But remember not to pull too hard, or the cable will seperate.
I didn't have a helper, so I devised a method where I supported the shock on a floor jack, and used some string (well, a packing strap if you must know) to help guide the cable. Basically, I would raise the jack, check the cable, raise it some more, check the cable, etc. Raise it too far and you can get the cable through as it is too high. If you don't raise it far enough you can't get the cable through. You have to find that sweet spot where you can get the head of the cable through and then you are home free.
I attached a picture of how I used the jack, and of the cable head just peeking out the hole in the bodywork. It's not hard if you take your time, but it can be frustrating if you rush it.
Have fun!
swoope
03-14-2006, 04:24 PM
great post,
i would love to hear some feedback on these shocks.
this is the route i want to go, and my springs are
just sitting on the shelves.
beers :beer:
Have fun!
cleoent
03-14-2006, 04:33 PM
great post,
beers :beer:
What springs did you end up getting?
swoope
03-14-2006, 04:39 PM
i picked up a set of eibachs used for a really good price. i am on a budget right now... damn allergist. the specs are almost the same as what you put in.
all is going well with yours i assume... i am fighting putting the springs on first. you know how that is.
beers :beer:
GeorgeH
03-14-2006, 10:29 PM
great post,
beers :beer:
Here you are:
http://www.rx8club.com/showthread.php?p=1282822#post1282822
swoope
03-14-2006, 10:32 PM
Here you are:
thx.
beers :beer:
dying_here
03-15-2007, 09:53 PM
sorry to dig up an old thread, but Im planning on doing a DIY install on my espilr this weekend, can someone send me that DIY? the link doesnt seem to work anymore. I'm just looking for pictures for references
$lickmurf
04-24-2007, 09:58 AM
me and a friend used this DIY to install my koni shocks and Eibach springs this weekend and it took about 4.5 hours....the only time consuming part is compressing and decompressing the springs, thank God this kid had an impact wrench!!! its so easy to get them in and out though...thanks!!!
416to212
09-12-2007, 04:04 PM
Does anyone have the new links to the pictures?
BTW Sorry for resurecting an ancient thread! LOL
$lickmurf
09-12-2007, 09:22 PM
if you go to this site there are instructions with pictures for the front and rear
http://www.hi-impact.org/ryang/modify/modify.html
Tamas
09-12-2007, 10:23 PM
Does anyone have the new links to the pictures?That's why posts in the DIY section should only allow attached images... if the linked site is gone, so are the pics and the thread is less useful.
zenmoused
09-15-2007, 12:34 AM
^second that. As useful as this DIY was, I found that several of the details were a bit.. off. A couple of the bolts are listed as different sizes than what they really are, and where he refers to the "control arms" for the front shocks, I believe he means the end links. Minor typos, but without pictures it's kindof confusing.
road1will
09-21-2007, 10:40 AM
I did this install earlier this week...it was super easy probably took 4 hours or less. I'm not sure why everyone considers the rear harder to do...It was far easier. My first front took about 1 hours 2 minutes, second one took about 45 minutes. My first rear took about 45 mins-hour. Second rear spring took literally 20-30 minutes. I did use air tools which make a job like this much, much faster.
HCTR154
10-01-2007, 03:21 AM
^^^^Air tools rule, huh??:Eyecrazy: Personally, I wouldn't attempt this DIY without them, but that's just my opinion. If you don't have any, just go to a local RX-8 or RX-7 meet and ask around!
willrotary
10-06-2007, 01:57 PM
I just bought a Tein S-Tech kit for my Rx-8, ill post some pics when the job is done. i probably do the front first due to my short time of being not busy.
zenmoused
10-06-2007, 11:40 PM
Good luck man. The fronts were a bit easier for me. Just make sure you have a breaker bar for those top nuts on the hats.... took me quite a while without one. (mine was lent out...ha)
willrotary
10-21-2007, 06:30 PM
Hey thanks men, well its sunday 21st and yesterday i did just my front, i've been so busy all these day, but the car looks nice like that, can somebody tell me if one of you guys have just the front Tein S, and stock in the back???
Pictures!!!!!
109177
BEFORE
109178
AFTER
109179
NO SHOCK
109180
NEW SPRINGS ON!
109181
I'M A MEMBER OF:
THANKS A LOT GUYS
416to212
02-25-2008, 11:30 AM
Just to clarify... So we don't have to undo the lower control arm of the rear suspension to get the rear shock out?
416to212
03-27-2008, 10:46 AM
TTT - Anyone have additional info on swapping out the rear srpng without removing the lower control arm?
matthew121
04-27-2008, 02:17 AM
^^ x2
05rex8
05-12-2008, 11:18 PM
does everyone have to leave the upper control arm bolts loose before setting the car down before tightening them? or is it for just this specific spring in the DIY?
swoope
05-12-2008, 11:21 PM
has to be done.
beers :beer:
8rotor8
05-12-2008, 11:23 PM
Once you unbolt everything, get your buddy to step on the rear brake to get it low enough to swing the rear shock past the lower control arms.
Also when you go and tighten all the bolts back on, what I do is leave the car onthe jackstand, get a jack, and jack up the knuckle of the suspension until the car gets off the jack. Then you can tighten up all the bolts without worrying about settling issues.
05rex8
05-12-2008, 11:27 PM
has to be done.
beers :beer:
ok thanks. how difficult is it to loosen these bolts with hand tools?
8rotor8
05-12-2008, 11:35 PM
Use a breaker bar and some WD40 if needed, it's easy.
swoope
05-12-2008, 11:45 PM
not at all, and you can get to them by turning the wheels all the way to each side. i would drive it around the block once or twice with them loose / just snug.
beers :beer:
05rex8
05-12-2008, 11:49 PM
beers :beer:
awesome, thanks again
matthew121
05-13-2008, 02:50 PM
has to be done.
beers :beer:
no it doesnt.
a easier way is to get everything back together with loose bolts.
get a jack and place it under the rotating assembly.
and load the front suspension by jacking it up.
it will be fully loaded when the entire car starts to raise and not just the suspension.
load it all the way up, then tighten all your bolts.
unload it and slap your wheel on, then your done.
this way is ALOT easier than having to lower the car down and try and reach the bolts.
05rex8
05-13-2008, 07:15 PM
^thanks for the suggestion...now I have to try to loosen the bolts. I had a mechanic put the springs on and I'm sure he used an impact. I don't have one..so this should be interesting..........
swoope
05-14-2008, 01:41 AM
we will just have to disagree on this.. both will work. i think it is easier my way, + if you drive just a bit and hit a speed bump or two it settles..
have done it both ways. :)
beers :beer:
no it doesnt.
I8U
05-14-2008, 01:57 AM
swoope, pm sent.
BigWillieStyle
05-21-2008, 08:50 PM
Has anyone thought about redoing this DIY with pictures?
The links are no longer feeding to the pics.
DavidR
07-22-2008, 07:29 PM
Yeah, I'd actually worship whoever redoes this DIY, I have ordered and recieved my springs, and it's going to be my first time installing spring onto any car. I went all out and went out and bought jack stands, floor jack, and rented spring compressors. I'm ready as son as I'm sure of what I'm doing of course. lol. But yeah! Pictures would be cool! :)
matthew121
07-22-2008, 07:58 PM
its not that huge of a job, although I dont know what kind of mechanical background you have
DavidR
07-22-2008, 11:47 PM
Haha, none at all, except for changing the foglight bulb and installing the K&N intake, but that had detailed instructions.
shadycrew31
07-28-2008, 03:49 AM
I just started on my own springs.. Not really getting the preloading thing, sounds like I drive around with my upper control arm bolts loose go over a few speed bumps then tighten it all back up..
FYI: for the front struts break the top 17MM bolt loose first. then take out the assembly once you have compressed the spring you can stick an Allen key in the top and take off the 17mm bolt quickly and easily.
gonna do the other front spring and rears tomorrow with my roommate im freaking tired!!!.. I will post pics if I remember to take them.
NoOdLe BoY
08-11-2008, 03:39 PM
yea im also hoping someone redoes a spring DIY with pics. Lol. My GF210s are just begging to be installed.
Ryan2008
09-21-2008, 12:42 AM
I agree.
chancejat
11-07-2008, 05:33 PM
just did the fronts today with tein s-techs....but for some reason my right side is half and inch higher then my left......any ideas why?
i preloaded btw....
Riken
11-17-2008, 02:07 PM
^how long did it take you to do the front?
learycd
11-17-2008, 02:36 PM
yeah im just debating having my guy at the shop put them on to save the trouble cause its def easier on a lift.
how much u think that would run?
Ross_Dawg
11-19-2008, 05:47 PM
I've been quoted $300 at 2 different shops...
chancejat
11-19-2008, 05:50 PM
took me about 2 1/2 hours....if i did it again it would take me an hour prob....
Ross_Dawg
11-19-2008, 10:30 PM
did you have air tools and a spring compressor?
chancejat
11-19-2008, 10:45 PM
no air tools but i did buy a spring compressor...40 bucks at pep boys
Ross_Dawg
11-23-2008, 09:22 PM
well I did the fronts yesterday, took 1-1/2 hours. Doing rears tonight so we'll see how long they take...
For preloading we just thread the Control arm bolts a little bit and then drive around the block and then tighten them down right?
HockeyRX-8
11-23-2008, 09:48 PM
Or you can use a floor jack and jack the car up by the knuckle. It's much easier this way because the wheel is off, so you can tighten everything down while the floor jack preloades the spring for you.
swoope
11-23-2008, 10:33 PM
i think that is the preferred way.. as it settles things down more.. a few speed bumps helps.
and you can reach the bolts to tighten them by turning the wheels to both opposite locks.
beers :beer:
learycd
11-23-2008, 11:56 PM
i was just quoted 150 from my buddy over at this garage by me, if that helps
Ross_Dawg
11-24-2008, 03:37 AM
well I finished the rears tonight... took 2-1/2 hours :(. The front is definitely higher than it should be so I'll preload that bitch tomorrow if I have free time... thanks for all the help!
dsire4u
03-03-2009, 04:15 PM
hope all the pictures work............
rotaryPilot
03-04-2009, 03:35 AM
synthtk pics you have posted are not working ! Can you please check up the links?
moRotorMotor
03-08-2009, 09:16 PM
Lol, he is no longer active, probably doesn't have the car anymore. It's been 5 years, I think he just removed them from the site.
9krpmrx8
03-08-2009, 09:59 PM
Do a search for Robin Yang, you can download the mht file with the pics and instruction of his coilover install. I am planning on redoing his DIY and hosting it but I wanted his permission. The whole thing font and back should take about five hours with hand tools. Just remember to tighten everything up and don't forget the top bolts on the rear shocks (like I did the last time) because I had to do the rears all over again..
Footman
04-16-2009, 11:43 PM
Question...
once the car is lowered to the ground and the front is allowed to settle for a bit, how does one reach into the wheel well (with the wheel on) to tighten the bolts?
dozer
04-16-2009, 11:46 PM
footman, you dont put it on the ground, you use the jack to jack up the wheel/brake to its right location still leavinin the car on jack stands, then you tighten...get what im sayin?
redmaz8
04-26-2009, 07:45 PM
Thanks synthtk! The removal instructions were perfect. i didn't brave the spring install so i'm going to have a shop do that for me. I'll let you know how the reinstal goes.
redmaz8
05-04-2009, 12:13 PM
the install went pretty smooth. the only minor setback that i did encounter was w/the reinstall of the right rear shock. I couldn't seem to get it back into the bracket that is located in the trunk. took me about another 15 min just to get the bolts back on. other than that the total removal and reinstall was about 2 hours give or take 30 minutes.
Brian Major
06-16-2009, 09:48 PM
uhhhh... this is a frustrating install, can't get the fronts back in....
dozer
06-16-2009, 09:58 PM
^its better to have help
Brian Major
06-17-2009, 06:55 PM
woot, finished! I wish i had a camera, I would of taken pics of my process and the steps i added to the existing diy. oh well, maybe when i install my shocks.
padilla08
07-23-2009, 02:18 AM
how're the tanabe's? the ride and the drop, i mean. sorry if this is a little off topic. haha! when i search for decent springs, people always mention the tein s tech. can't get them from japan, though, so i'm checking out the tanabe. recommendable?
thanks
Spiritus Sancti
08-12-2009, 08:17 PM
thanks
Well i used to ride with NF210 and they felt very comfortable with suprisingly great handling. I ono how the GF210s ride but i say it might be a lil stiffer?
padilla08
08-13-2009, 11:05 AM
^ hmmm... good enough for me. haha! thanks for the input
9krpmrx8
08-13-2009, 12:20 PM
I have been meaning to redo Robin Yang's DIY (I have it in an MHT file) but i just have not had the time. I emailed him and he said it was cool.
csiepka
08-17-2009, 01:53 PM
We just installed the Sprint springs and I have pics if you need any....
rodjonathan
08-17-2009, 02:10 PM
mine went pretty smooth but i had a helper :)
FazdaRX_8
08-23-2009, 01:40 AM
I did mine all by myself :(
Semiazas
09-21-2009, 06:52 PM
I am trying to use this DIY but no pictures so i really dont know what im looking for.
csiepka
09-22-2009, 12:32 PM
What do you need? I have some pics
rx2kill
10-14-2009, 10:37 AM
The initial write up was helful, tho it left a few key elements out. Def checkout the pics the guy put up with the bolts circles with red, That was a great help for the rear end thanks!!! After seeing those pix the rear was a breeze, my markviii was so much easier to do than this, the rear on this car is very busy. Took me about 4 1/2 hours to complete all 4 (to tein s tech) But I had a helping hand, well he actually had two hands, Good luck everyone doing this! =)
Bigbacon
10-20-2009, 08:39 PM
You should post your own DIY with your pics so we have an up to date DIY
If the original poster is still around and has the photos still I can host them if you want. I have like 100gb of space so I can host just about anything
