Engine cuts off during high acceleration
Old May 15, 2012 | 05:32 PM
lalinka's Avatar
Hi
i have a 2004. rx8. lately i have been experiencing sudden engine cut off during high acceleration on hot weathers. it suddenly switches off and it takes a about 5 mins or repeated attempts of cranking to start back. changed the spark plugs and ignition coils as well. what should be the cause?
Old May 15, 2012 | 06:01 PM
Arca_ex's Avatar
BECAUSE RACECAR
Is it overheating?
How many miles?
Have you had a compression test lately?
Old May 19, 2012 | 02:45 PM
Darkning's Avatar
Double check your battery clamps and voltage. Mine was randomly dying on me one time and it ended up being the clamp not being tight enough to the battery.
How does it run when it's not stalling?
Old May 20, 2012 | 11:54 PM
Are you shifting 8k or higher?
Old May 28, 2012 | 07:38 AM
lalinka's Avatar
it has done 62,000 km. their is a slight overheating issue. the obd II READS AT 101 Celcius sometimes. haven't done a compression test and checked the battery clamps as well. AND NOT SHIFTING AT 8K
Old May 28, 2012 | 07:42 AM
RIWWP's Avatar
That sounds like an overheating fuel pump, and it has to cool down in order to start pumping again.
Be advised that fuel pump failure and/or fuel pump shut-off during high load (hard acceleration) has a chance at creating a sudden lean spike that can destroy your engine. Until you get the issue diagnosed completely and a fix resolved, I highly recommend you avoid high load high RPM use.
Moving to Troubleshooting.
Old May 28, 2012 | 10:36 PM
tonik's Avatar
/\ +1 fuelpump...it happened to my 8
i replaced it with walbro
Audio Concepts ATL
Sep 26, 2021 01:59 PM
vapor2
Nov 3, 2020 03:38 PM
escapedan
RX-8 Racing
58
Feb 10, 2020 06:11 PM
Shnifty
23
Dec 18, 2015 12:49 PM
vssystemluba
Jul 19, 2015 04:16 PM
