Mazdaspeed Shocks/Springs
Old Mar 16, 2004 | 10:55 AM
sixspeed's Avatar
Petrolhead!
Anyone any comments on these. Notice a lot of people talking about the springs by themselves, but has anyone gone for the full kit yet?
-andy-
Old Mar 16, 2004 | 11:35 AM
Omicron's Avatar
Not that I recall, but I too would be interested if anyone has them. Been thinking a bit on this myself.
Old Mar 17, 2004 | 12:25 AM
e46328's Avatar
I ordered MazdaSpeed springs and shocks last Friday. I went w/ M/S since it will only lower the car .75 inch or so.
I probably install them early next month. I will let you know how I like the set up once I have them put on.
Old Mar 17, 2004 | 10:55 AM
Omicron's Avatar
Please do.
Old Apr 19, 2004 | 02:14 PM
e46328's Avatar
I just got my Mazdaspeed shocks and springs installed last weekend and had a chance to drive around w/ new set up.
Drop isn’t too low which I like. Using the good ol’ finger gap between tire and fender method, at the front, the gap is little less than 3 fingers and little less than 2 fingers at the back. I am guessing the drop is about 0.7 inch front and back and will drop little bit more after they settle.
The ride isn’t harsh but I can feel the road surface little bit more. When I first got the car, I noticed that RX8 has more body roll than what I am used to (2000 BMW E46 328i with after market sway bars). Now the RX8 w/ M/S suspension corners flat!! The stock RX8 handles good too but now with less body roll, the car gives you more confidence! (not that I will take corners at crazy speed lol)
Old Apr 19, 2004 | 08:28 PM
cortc's Avatar
Check out this thread...
https://www.rx8club.com/showthread.p...threadid=25546
Old Apr 19, 2004 | 08:30 PM
takahashi's Avatar
My question is how much is the shock contributing the flat cornering... e46328. Do you have sway bars on yours? cortc what do you think?
Old Apr 19, 2004 | 08:47 PM
e46328's Avatar
Takahashi
I still have stock sways.
Old Apr 20, 2004 | 12:00 AM
cortc's Avatar
The two things contributing the most to reduced body roll are the springs and sway bars, and then it would be bushings and last shocks... The shocks are just damping the rebound and initial compression not much more than that... Shorter stiffer springs will by themselves always reduce body roll because there is less spring to compress and it is more resistant to compression, the sway bars will reduce this further while allowing you to not have to go to a much stiffer spring in order to maintain some comfort...
Old Apr 20, 2004 | 01:43 AM
santino's Avatar
With the Miata folk, they usually suggest upgrading the swaybars if you want to reduce roll, without giving up comfort. This is what Flyin Miata suggests....see here
santino
Kahl
NE For Sale/Wanted
21
Aug 5, 2017 02:49 AM
JAYDOH
Sep 24, 2015 01:54 PM
Turman-ator
11
Sep 22, 2015 11:22 AM
