Will 275/35/18 rear and 245/40/18 front work?
Old Mar 16, 2004 | 10:33 AM
Velocity-8's Avatar
Whuumpha!!
I'm just curious if anyone has done this combo or considered it? any thoughts?
Old Mar 16, 2004 | 11:37 AM
Omicron's Avatar
Somebody around here is running 275/35-18 Hoosiers for competition and says they fit just fine. Not sure about the staggered widths front and rear though.
Old Mar 16, 2004 | 12:01 PM
Gord96BRG's Avatar
Do a search in this forum section for "staggered" - you'll find 21 threads that mention staggered wheel/tire setups.
Several people have done it - my opinion is that they're doing it because they like the look.
For performance/handling, I seriously doubt there's a benefit - the stock RX-8 suspension is designed to be running the same size tires front and rear for the intended handling balance. By putting wider tires on the back, you WILL screw up the handling, introducing much more understeer than the stock setup. I'd suggest that is a bad idea, unless you don't care about handling. Then again, this is a sports car - why would you not care about handling?
Regards,
Gordon
Old Mar 16, 2004 | 12:08 PM
Velocity-8's Avatar
Whuumpha!!
Regards,
Gordon
This is what I was looking for. My old Z Twin Turbo had "staggered" tires but I guess that is how it was designed. I'm guessing 245/40/18 all the way around is probably the best for handling for the 8.
Billy Marcial
Mar 1, 2018 06:50 AM
stickmantijuana
29
Mar 25, 2016 09:58 AM
Brandonien
Jul 30, 2015 12:33 PM
AussieGray
Jul 16, 2015 03:58 AM
