Compression test results
Old Apr 21, 2012 | 11:59 AM
kosinagi's Avatar
Hi Guys
Just got a 05 rx8 190bhp with 68 k on the clock.
The rx8 cat is apparently broken up and the compression test results are as follows.
6.4 6.6 6.6
6.4 6.2 6.2
That is at 250 rpm for both.
The dealer says the min should be 6.8.
The dealer I bought it from is saying they will pay to fit a new cat.
Should I be worried About the compression results?
Thanks guys much appreciated
Owen
Old Apr 21, 2012 | 12:18 PM
bse50's Avatar
#50
Time for a rebuild.
It may end up being not that expensive since the compression is even amidst the rotor faces. It's surely better to rebuild it now than wait for worse things to happen.
Reading through some posts here you will also learn why these engines fail. Couple of search tips: ignition (coils) , spark plugs , catalytic converter, oil metering pump (omp) , premix .
Old Apr 22, 2012 | 01:09 AM
monchie's Avatar
I HATE SPEEDBUMPS!
You said you just bought the car, the dealership will replace the cat, how about the engine? It's better to replace it now than later, until the warranty expires on you. Anyway, those numbers are pretty low though.
Old Apr 22, 2012 | 06:38 AM
kosinagi's Avatar
Hi guys
Thanks again.
Yea I'm trying to get them to fix as much as possible of the car before the warrenty runs out. This info willl give me some more ammo to go back to them about either getting the car up to scratch or give me my money back.
Thanks guys
Old Apr 22, 2012 | 06:42 AM
bse50's Avatar
#50
Originally Posted by kosinagi
Hi guys
Thanks again.
Thanks guys
Where are you located? The extended engine warranty only applies to the US and Canada.
Old Apr 23, 2012 | 07:53 AM
kosinagi's Avatar
Thanks bse50 the warrenty I have is engine and gearbox from the garage I baught it from. I'm based in Ireland.
Cheers
Old Nov 6, 2012 | 02:20 PM
kosinagi's Avatar
So after several months I got my money back for the car it was a total lemon and the garage were eeeeh how would I put it..... Bastards. But I've been bitten now so I got another one but I had this one fully checked before buying, all is well. Thanks for the replies.
Old Nov 6, 2012 | 04:40 PM
Leonheart's Avatar
Rotary Frontier
Sounds good looks like you may have a keeper on your hands
gwailo
May 14, 2024 06:57 AM
Shnifty
23
Dec 18, 2015 12:49 PM
TJSiegrist
Sep 10, 2015 09:29 AM
rxwilly8
Sep 2, 2015 02:42 PM
