HELP with offset! thank you!
Old Apr 20, 2012 | 01:30 AM
mystik2k's Avatar
Hey guys,
gettin my first set of rims, on my stock VR rx8, i am wondering. will these following rims fit, without any guard work
http://www.prospeedracing.com.au/pro...52b-White.html
and will it be flush or sticking out too much? i want my wheels to look flush, not stick out too much.
sorry i am new to offsets etc
any help would be appreciated !
Old Apr 20, 2012 | 03:19 AM
mavictb's Avatar
Originally Posted by mystik2k
Hey guys,
first of all those are the wrong bolt patter and second and most importantly....
READ THE THREAD RIGHT UNDER YOURS OR THE STICKY "WILL IT FIT"... For christs sake take a moment out of your day and read.
Old Apr 20, 2012 | 04:29 AM
bse50's Avatar
#50
^^^Amen.
Old Apr 20, 2012 | 06:11 AM
godesshunter's Avatar
Voids warranties
I got my Rotas from wheeldude.com at the advise of tiltmode. They were great. I suggest you get in touch with them when you figure out that you are getting.
Old Apr 20, 2012 | 10:07 AM
tcole6's Avatar
Yes wrong bolt pattern, you need 5 x 114.3.
You can figure it out as such:
Stock is 18x8 + 50. So due to the width you will be adding .75" ((9.5 - 8) / 2). Due to the offset difference you will also be adding 12mm (50 - 38) which equates to nearly 1/2" (12/25.4). Add these two together and you will be roughly 1-1/4" further out than stock.
I saw some good pics from 9krpm with stock wheels and a 1" spacer that looked about as wide as you can go without getting hella (which would require rolling, adding camber, stretching tires, etc) if you are lowered.
So it looks to me like this rim (if the bolt pattern was correct) might require some work if you are lowered. Stock height, I'm not sure, others here could give you better information on that.
Old Apr 20, 2012 | 02:43 PM
bulletproof21's Avatar
I believe if he is going from an 8" rim to a 9 1/2" rim that is 1 and 1/2 inches right there. Now add in the extra 1/2" from the +38 offset and he is looking at a full two inches farther out than stock.
Old Apr 22, 2012 | 06:21 PM
J8635621's Avatar
Pew Pew Pew
You are incorrect with your first part. It's 1/2 of the difference in width as half goes towards the fender and half goes towards the strut.
hufflepuff
May 30, 2016 10:45 AM
Richard Paul
Aug 17, 2015 01:49 PM
R2D2X8
Aug 17, 2015 08:47 AM
jaehyun127
May 29, 2004 08:04 AM
