Tein S before and after question.
Old Apr 19, 2012 | 05:59 AM
SouthernSwede's Avatar
Hello
I installed Tein S last weekend and I can see the car being a little lower now. But I am wondering if it shouldnt be even lower. I did the preload thing by driving the car around the block once. But I did not cut my bumpstops. Can you guys see on the before and after pics if it looks right? The one to the left is before.
Attached Thumbnails Tein S before and after question.-mazda-inte-s%E4nkt.jpg   Tein S before and after question.-mazda_s%E4nkt.jpg
Old Apr 19, 2012 | 07:43 AM
JCrane82's Avatar
Trust Me, I'm an Engineer
Bump stops will not affect ride height. Did you take before and after measurements from center of hub to fender? Pictures lie, measurements don't.
How did you perform the preloading? Did you have the weight on the suspension when you torqued the upper control arm bushings?
Also......this has been discussed tons of times. Did you try a search?
Old Apr 19, 2012 | 08:07 AM
paimon.soror's Avatar
as JCrane said, measurements are best, but from that picture it doesn't look like the rear springs were properly preloaded.
Old Apr 19, 2012 | 08:32 AM
LifeAfterRx8's Avatar
It's defiantly lower,
If you're looking for slammed you need coilovers.
The rear should start to sag eventually and it should even out.
Old Apr 19, 2012 | 11:19 AM
I preloaded only in front cuz i did not know i could do it in the rear aswell??
Old Apr 19, 2012 | 11:45 AM
Rotary-RX8's Avatar
Girls who drive stick FTW
looks the same height. But the angle of the pictures are different. But as other ppl said, pictures arent accurate. Measurements are.
Old Apr 19, 2012 | 07:32 PM
mavictb's Avatar
rears need preloading.... will be lower after... also springs settle to get your full drop.
Old Apr 20, 2012 | 02:41 AM
Will preload the rear this weekend and see if there will be a difference. I'm happy a it is really but if it settles 1cm more ill be happier.
Old Apr 22, 2012 | 01:22 AM
monchie's Avatar
I HATE SPEEDBUMPS!
It should lower a bit after driving it a few miles or so, so be patient.
Old May 28, 2012 | 02:45 AM
gmoney's Avatar
1SIK8
Not trying to thread jack or anything but how do you preload the rears?
Old May 28, 2012 | 02:55 PM
JCrane82's Avatar
Put rear of car on stands. Pull wheels off. Jack under wheel hubs to compress the suspension enough to start to lift the chassis off the stands. Then torque the control arm bolts.
Old May 28, 2012 | 04:19 PM
g8ter's Avatar
I have stech's and koni yellows give it some time and drive around!
Old May 28, 2012 | 11:23 PM
gmoney's Avatar
1SIK8
Ahhh, thx I shall give it a try here pretty soon......
neoksk
Sep 21, 2015 12:31 PM
Wurromurro
Sep 20, 2015 05:02 PM
yankeepicker
Sep 11, 2015 05:42 PM
Nisaja
51
Sep 1, 2015 04:29 AM
TheWhiteAce
Series I Engine Tuning Forum
Aug 6, 2015 02:26 PM
