RX8Performance Under Tray Review
Old Apr 16, 2012 | 03:42 PM
Highspeed's Avatar
2 Tone...Low Drone
Thumbs up RX8Performance Under Tray Review
Ok, I finally got around to getting this mod installed. I had a lot of things come up once I received the tray, within my family, and it delayed being able to install the tray. It is now installed and I am really enjoying it and seeing results!
First off, I received the tray packaged really well. The tray is lighter than I thought it would be with the coolers and fans on it. The material is very nice and the look of the coolers with fans mounted is pretty sweet. There is a notch cut out still for draining the radiator which was something I was wondering if it would have. There is also some vents. The screens on the bottom are nice and cleanly installed to allow air flow to the coolers. The wiring was all shrink wrapped and secured which is a nice thing to know and not have to worry about when driving in the weather or car washes. All hardware was included for the installation as well as new hose for the coolers. The holes for the side trays to mount to the under tray lined up perfectly and worked great!
The install was pretty much straight forward. You just have to decide what you are going to use the coolers for. I used one for a sec aux cooler and the other as a tranny cooler. In the pics below, you will see I had a pretty big tranny cooler in the front of the car. By using one of the coolers on the tray for the tranny, it allowed me to removed the front tranny cooler and allow better air flow into the radiator. The hoses supplied with the tray were more than enough to allow for the routing of these coolers to the parts of the car they needed to be routed to. The hardware also included the fittings needed to attached hoses as well as clamps, screws, etc. Nothing extra was needed to be purchased for this install.
One thing I noticed immediately after the install was the amount of air I could feel the fans pushing...I was impressed that the fans could push that much air for no bigger than what they are. My buddy who helped me with the install was impressed as well at the amount of air they were moving.
I have pics below through the install, the only pic I forgot to snap was one before I put the bumper on.
I have noticed a difference in the temps since the install of the tray with coolers. Before the tray install, on days with the temps in the 80's, I was seeing temps between 195-200 until the fan mod kicked both fans on. Now I am seeing temps in the 180's and havent seen it go over 192 yet. This as well on days with the weather int he 80's. As for the tranny, I was seeing temps in the 170's-185...now it ranges between 145-160.
All in all, the tray mounted up perfectly to every part of the body and side trays. The hoses supplied and hardware was more than enough to get the job done. prepping the car for what I was going to use the tray for and removing the old tranny cooler took longer than the actual install of the tray itself.
Also, I have pics showing the motor mounts I also purchased from RX8performance. The pics show them installed.
Here is the pics!
Here is the old tranny cooler I removed
Old Apr 16, 2012 | 09:50 PM
elysium19's Avatar
I'm confused.....what are the fans for? Does the undertray block the normal airflow to the radiator somehow?
Old Apr 16, 2012 | 09:55 PM
Highspeed's Avatar
2 Tone...Low Drone
No, the under tray is under the car, not in front of radiator. The cooler in the pics that is in front of the radiator is the one I removed. The fans on the coolers pulls cold air from under the car up through the coolers.
Old Apr 16, 2012 | 10:05 PM
JantzenRX-8's Avatar
Seems like you would want push fans. Wouldn't pull fans just pull the heat out of the new coolers and blast it into the stock rad? Push fans would take air entering through the bumper and push it out under the car. Haven't really put that much thought into it but it just seems like a more natural flow to do it that way. But maybe im missing something...
Old Apr 17, 2012 | 05:14 AM
MarkLinRacing's Avatar
FWD specialist
Sounds strange... If those are definitely pull fans, I would probably change them to push fans to give it a try. Even though you are seeing cooler temperatures, the setup probably isn't ideal and the temperature drop might be because of the better heat exchangers.
Old Apr 17, 2012 | 07:47 AM
lordagrabah's Avatar
Can you give us feedback on the motor mounts?
Old Apr 17, 2012 | 08:34 AM
Highspeed's Avatar
2 Tone...Low Drone
The fans are pulling so that they pull the colder air from underneath the car into the coolers instead of blowing engine heat through them
Old Apr 17, 2012 | 08:35 AM
Highspeed's Avatar
2 Tone...Low Drone
The mounts are very nice! I used to have a small vibration through high rpms's but now since I installed these mounts, its gone. Also, the engine seems smoother if that makes sense. I am impressed with them!
Old Apr 17, 2012 | 08:48 AM
paimon.soror's Avatar
^^ honestly, from an engineering perspective, I would be surprised if that setup did anything beneficial. First off, you are trying to pull a fluid running parallel to the fans, a fluid that has a velocity as your car speed increases, next, there is so much turbulance generated from the drilled holes under the radiators that it is creating so much pressure between the fan, rad and the tray and that sure as hell doesn't help the air get sucked in. The air will want to flow through the bottom of the car along the ground where there is less resistance.
Old Apr 17, 2012 | 12:32 PM
olddragger's Avatar
the fans themselves will be more of a benefit during stop and go/low speed situations. That is usually where our engines could use some help. At cruise the fan will be less useful but just the presence of an extra cooler will be of help. And you are exactly right---at speed the air is flowing faster under the car and that causes a venturi affect that will pull some air through those coolers.
I think its a good product-- I would put a thermostat on the secondary radiator though.
Old Apr 17, 2012 | 01:16 PM
It would create the venturi effect only if the fans are in a push (through rads) configuration, not if they were pull (through).
edit:
let me rephrase, it could produce the VE if the fans were on pull, but it would really only happen if there wasn't a mesh drill pattern under the rads, unfortunately the turbulence caused by that configuration would prevent any flow at speeds. Now if that mesh pattern wasn't there then yes, i could see a significant flow being pulled up through the rads, but for obvious reasons they cannot leave that exposed.
With the fans in a push configuration, during speeds you would expect the fluid air to flow around the car top and bottom, but also some air would get fed into the 'mouth' of the bumper where it would then get pushed through the rads then accelerated through venturi when the air meets with the air passing through the bottom of the car.
but regardless, like you said, it's benefits will be shown when at a stop so these assumptions are moot.
Old Apr 17, 2012 | 03:05 PM
Highspeed's Avatar
2 Tone...Low Drone
I have noticed cooler temps significantly when driving and also when sitting in traffic. We can all sit here and say "well if it did this...or if it had that...or whatever" but the proof is in the pudding...and the pudding being the temp differences shown on my scangauge of the water and tranny temps of before and after
Old Apr 17, 2012 | 03:09 PM
you haven't really proven anything except that these two radiators in particular have better cooling capacity than the oem one. If you want actual proof of how effective everything is, remove the fans and drive ... I bet you that while you are driving the temps are going to be no different than when you had the fans installed.
edit: and by "remove fans" that doesn't mean simply disconnect them from a power source.
Old Apr 17, 2012 | 03:19 PM
If you think about it...whether it is push or pull you will effect the airflow over the radiator...you either push air through the coolers that came in the front...or pull air in from underneath that will be heated a bit..and then go through the rad...either way there should still be a net increase in heat leaving the system.
From my perspective the fans will provide lots of extra cooling when stopped...and likely not do as much when driving. If there was an easy way to do it...turning them off when moving would likely be a good thing
Old Apr 17, 2012 | 03:43 PM
Highspeed's Avatar
2 Tone...Low Drone
Paimon...then with what you are saying...the fans running or not running when driving down the road makes no difference and the fans running when at a stop helps. So why are you complaining about the fans again??? The tray is working great for me and if you want a tray but dont like the fans, then guess what bud...you can order it without the fans As for my setup, I am very pleased with it and its staying like it is.
Old Apr 17, 2012 | 04:03 PM
Likes to complain
Old Apr 17, 2012 | 04:16 PM
Highspeed's Avatar
2 Tone...Low Drone
Got ya
Old Apr 17, 2012 | 07:09 PM
olddragger's Avatar
thats my point too--the fans aren't usually on while you are cruising down the interstate.
Old Apr 17, 2012 | 07:32 PM
Highway8's Avatar
Registered RX8 Nut
Dont under estimate the effectiveness and importance of the stock cooling fans for at speed cruising. Dont believe me, just try disconnecting or removing them. I have and the car overheats, even in mild tempuratures and loads.
As far as this under try with cooling fans, I would like to see them push and have louvers on the bottom side to smooth out and improve the air flow. I am sure the fans inturrupt the radiator air flow a little, but the stock cooling fans keep the air moving in the right direction.
If someone gets this without fans, you should use louvers on the bottom and some sort of scoop on the top.
Thats my 2 cents. As the OP says, it works great for him and he is very plessed. To be honest, unless you test the different setups with fluid dynamics computer research and or wind tunnel testing, we are all just guessing at what the airflow will do and what is or isn't best.
Old Apr 17, 2012 | 07:48 PM
redline86's Avatar
The Heavy Metal Scientist
I got to see one of those panels with the fans last time I was in Tampa at Scott's shop. How did you wire the fans? Did you set them up to always run?
Old Apr 17, 2012 | 07:54 PM
redline86's Avatar
I just read the product description it says they come wired plug and play. Can you elaborate on that? I wonder how well they would work as an intercooler since most block flow to the radiator.
Old Apr 17, 2012 | 08:23 PM
Originally Posted by dannobre
Likes to complain
Got ya
It has nothing to do with complaining, first off I have no reason to complain and could care less either way. No need to get uber defensive, but why bother posting a "oh this works" thread if you cannot handle when someone questions the actual effectiveness of a product.
I am not going to get in a **** throwing debate here, but I suggest taking some time to read a bit on fluid dynamics and what is really happening in that particular system.
I am not at all saying hte product works, doesn't work, was worth it, wasn't, etc, so lets chill out out for a second and actually read what I am saying:
What PART of this setup is actually providing the benefit. I can GUARANTEE you that the tray provides ABSOLUTELY no benefit to the setup, and is actually HINDERING the true performance of the radiator and fan setup. Why? The drilled mesh holes on the bottom of the tray. What I am saying is that consider what is really happening when you are at a complete stop and the fan is running ... do you guys really believe that you are getting efficient flow of air through those holes? do me a favor and take that tray, turn it upside down, place a garden hose over it, and turn on the water .... turn on the fans now .... tell me what happens and you will figure out exactly what I am talking about.
you are happy with the product that is awesome, and I am happy for you.... some of us throw parts in our car and assume that each piece of it provides a benefit and nothing can be improved in that system ....
Old Apr 18, 2012 | 12:15 AM
......You don't obviously know what the "holes" the rad sits on are. They are not some small round holes drilled in the undertray. They are holes that basically are the full size of the auxillary rad with a mesh screen to protect the rad fins.....there is very little resistance to airflow introduced by this...so you are "GUARANTEE"ing something you don't have a clue about
You also seem to forget that in the real world...results trump theory. If you actually understood what you were looking at...you could even get your theories to align with the facts. Where do you think all of the theory came from in the first place. From observations of the real world
Really...all that counts is that there is airflow over the radiator..the direction and even to a small extent the temperature of the air is secondary to the delta in temperature
So unless you have access to a lot of very high end modelling software, a very powerful computer...and a ton of money......the empirical observations are as good as it is going to get
Old Apr 18, 2012 | 08:55 AM
olddragger's Avatar
yall are forgetting one major thing. The coolant that this set up uses is NOT coolant that goes through the oem radiator. It is coolant that is supplied by the heater hose which bypass's ever going through the oem radiator. Its it fed back into the coolant system at the thermostat housing. That means if your coolant is for example 200F at the top radiator hose--it goes through the radiator and is cooled to for example 180F--right? BUT, then it mixes right before the water pump with hotter coolant for the heater supply( 200F unless the heater is on) which adds heat back into the coolant that is being circulated through the engine. So ANY cooling of that heater curcuit coolant is of big help.
Old Apr 18, 2012 | 09:54 AM
Highspeed's Avatar
2 Tone...Low Drone
Paimon, I am not getting into a pissing contest with you either and didnt mean for it to come off as if I was. And I know when you post something up, you have to expect people to try and blow holes in it. I welcome that and its fine. Like I said...the numbers dont lie and I am pleased with the product and I have seen instant results. If someone thinks the fans are hurting something, then they can always order the tray without the fans. To each his own. I know I like the tray, love the results and not changing a thing about it
yes the fans are plugged into a fuse in the fuse box and kick on when the car is on. The wiring took literally 5 minutes to connect, easy as pie
