Waterless coolant vs 50/50
Old Apr 13, 2012 | 09:14 PM
Harlan's Avatar
Ok, as an experiment I switched from waterless to 50/50 coolant. I'd been running waterless since replacing the engine, and wanted to track down some indications so I ran logs for a few days on a stock tune and swapped coolant halfway through. The results for cruising at 70mph after readings were stable:
50/50 vs Waterless
Coolant temp: 197 vs 206
EGT: Negligible difference.
Short term Fuel trim: .6 vs 1.7
Running vac: Negligible
Idle Vac: 22 vs 23.5
Although I will say that I didn't leave it running long to see if idle vac changed with the 50/50. I do know it stays about the same with waterless.
These are the conclusions I've drawn:
The internal temps for idle are directly related to engine vac, so the engine internals stay cooler at idle.
The engine appears to run cooler in cruise. I say that because the fuel trims did drop 1% going to 50/50 (hotter internals), however the EGT did not change. So it's a toss up.
What I will say is that running waterless is slightly better than regular coolant for actually keeping the internals cool even with the increased temperature, and it doesn't boil over so overheating is less of a concern.
Old Apr 13, 2012 | 09:28 PM
Thank you ... most of us knew that already
the only problem with waterless coolant is that ... you have to fill it with waterless coolant, you can't just top it off with water.
Old Apr 13, 2012 | 09:54 PM
StealthTL's Avatar
Metatron
How is overheating less of a concern?
Surely if it never boils, the situation would just go from bad to worse?
Old Apr 13, 2012 | 10:38 PM
longpath's Avatar
Steam pockets in the cooling jackets act as insulators causing rapidly and uncontrolled increases in localized temperatures. In addition to this catastrophic climb, there are also the pressure and other mechanical stressors associated with this boiling.
By preventing this, and as demonstrated in GT class racing where Evan ran insanely high compression ratios and much higher than normal coolant temperatures because even those elevated temperatures were controlled.
Old Apr 13, 2012 | 10:59 PM
Harlan's Avatar
Yup, departure from nucleate boiling is the concern. As soon as a steam blanket forms the engine can quickly overheat.
If you fill waterless coolant with water and have greater than a 60/40 mix you get the worst of both worlds. Specific heat capacity of antifreeze and the boiling point of water. If you go down to 60/40 or less then you are in the realm of a normal coolant system.
The only concern is that Evans is expensive and hard to get quickly in a pinch. So I don't run Evans. If you look at the Evans NPG MSDs it is just a Ethylene Glycol/Propylene Glycol blend. They can claim magical pixie dust and the like, but it is what it is. I've been running straight EG may go to a EG/PG blend.
Old Apr 20, 2012 | 08:30 AM
olddragger's Avatar
The cooling system in this car needs help. I have finally ( after some years) developed a "package' that satisfies all my parameters. More specifically, low speed/rpms and high speed, high load, high rpms enviroments. Cruise conditions have always been ok.
Waterless cooling is one way to compensate for an inadequete system, but even it does not provide all the corrections this car needs.
If anyone is interested in my findings and results of what I have done--drop me a PM.
Old Apr 26, 2012 | 02:02 PM
Nadrealista's Avatar
olddragger please share you findings with us!
Old Apr 28, 2012 | 07:22 AM
olddragger's Avatar
PM me.
Old Apr 28, 2012 | 08:30 AM
1.3_LittersOfFurry's Avatar
Flame On!
I run 30%coolant 70% water with a bottle of redline water wetter. Temps stay at 180-183 crusing. Ever since I installed that fan kit the highest my coolant ever got was 195, and that's in summer stop-n-go traffic with the ac on. Coolant system on this car seems fine to me other than the factory preset fan turn on temps.
Old Apr 28, 2012 | 08:02 PM
olddragger's Avatar
A big part depends on where you live and how you drive. Where are you measuring your temps from? The obdII port.?
Old Apr 28, 2012 | 08:11 PM
I never had any cooling problem, NYC can go from 15 degrees to 105.
I have RB flash, Mazmart pump, and Knight Sports Rad (made by Koyo). no issues.
hottest I've seen maybe 95 Celsius ? Got those Readings from my Defi Gauge, sensor is right at the Top Radiator hose. Can't wait till Summer.
Old Apr 29, 2012 | 04:15 AM
Flame On!
Yeah, obdII, I drive slightly aggressive usually.
Prior to changing my coolant and adding the fan kit my temps were +210 in traffic, that's to hot in my opinion.
Old Apr 29, 2012 | 08:56 AM
olddragger's Avatar
another example of how important the fans are in DD.
Old May 6, 2012 | 08:33 PM
longpath's Avatar
OD, it seems your mailbox is full
Old May 8, 2012 | 09:51 AM
olddragger's Avatar
cleaned it up--just got back from the track--sorry about that.
Old May 8, 2012 | 11:02 AM
I like clutch fans better than electric fans, too bad there is no space.
Luiss7
54
Aug 20, 2019 08:56 AM
Azki23
Jun 27, 2018 03:48 PM
drlubell
Sep 26, 2015 11:58 PM
