New 8 owner - Quick Q's
Old Apr 12, 2012 | 01:34 AM
denisizzle's Avatar
So I just got my 8 a couple of months ago with a replaced engine 10k ago. Just had a couple of odd questions:
1) I found a hose that goes from right in front of the throttle body under the UIM that is not connected to anything - is this normal?
2) Also noticed that this pulley randomly starts spinning and stops spinning at idle (in picture circled in black)
and finally I've noticed that after stopping often times the car shakes gently and stops, this keeps repeating when I'm idling. It's nothing crazy just a tiny bit shaky and when it does shake the idle drops a teeny bit. Could this be the motor mounts or a dirty MAF?
Pics:
http://i699.photobucket.com/albums/v...-13-25_811.jpg
http://i699.photobucket.com/albums/v...-30-36_312.jpg
Thanks in advance!
Old Apr 12, 2012 | 08:27 AM
04Green's Avatar
Moder8
welcome,
I believe that vacuum line is for the vafd, the pully is likely the ac compressor.
there are 2 links in my signature, have a read of both. They will answer a lot of questions.
Old Apr 12, 2012 | 12:17 PM
denisizzle's Avatar
Is there any worry leaving it like that or is there somewhere it should go?
I've read both those threads before I got my car, thanks.
Old Apr 12, 2012 | 12:36 PM
200.mph's Avatar
FULLY SEMI AUTOMATIC
from your pics it looks like you have ms/aem intake? is so your vfad was removed. as long as that vac line is capped you should be fine
Old Apr 12, 2012 | 12:47 PM
denisizzle's Avatar
Yeah it is an aem intake. It actually is not capped but I will be sure to do that now. Thanks
Old Apr 12, 2012 | 12:54 PM
200.mph's Avatar
pull that hose off the bottom of the tb and push a vac cap on there
WranglerFan
Aug 21, 2022 01:29 PM
ndamix
Sep 18, 2015 03:04 PM
Randolph Alvarez
Sep 14, 2015 04:25 AM
RXBae
Sep 14, 2015 03:54 AM
LMURailsplitter02
Sep 6, 2015 10:56 PM
