Renesis powered Miata listed on ebay.
Old Apr 5, 2012 | 11:16 AM
Highway8's Avatar
Registered RX8 Nut
Came across this little rocket on ebay. Thought I would share. It is not a perfect car but a good start and improvement over a spec miata. My first concern is that I do not see any oil coolers. Of course the paint leaves a lot to be desired too.
Correction, they say it has a large oil cooler.
http://cgi.ebay.com/ebaymotors/1993-...item3cc4736eee
Old Apr 5, 2012 | 11:47 AM
Spin9k's Avatar
Momentum Keeps Me Going
cOOL.... I might bid if I was out there, need a ride first thou. Too many ???, condition of motor and history, and kind of a weak excuse for selling... I mean why did he build it anyway .. on a dare? Now saying not enough time??? Possible but weird...
Old Apr 5, 2012 | 11:53 AM
bse50's Avatar
#50
It also has crappy shocks... tells a lot on the overall build quality
Old Apr 5, 2012 | 12:35 PM
Highway8's Avatar
Registered RX8 Nut
Looks like the car was built as a toy/advertisment for the car dealership.
Motor came out of an 04 but unknown on the mileage. I am sire the seller will answer all questions.
Agreed about the megan coilovers, but thats not a big deal. They will work or can be easy changed out. Honestly a custom spring rate and valving needs to be done.
Old Apr 5, 2012 | 04:03 PM
bse50's Avatar
#50
Sure is not a big deal but if you cut corners on a car's suspension there's a huge chance you used butter to build the rollcage and tuned it with an old nintendo..
Old Apr 5, 2012 | 04:10 PM
stinksause's Avatar
The Stink w.o The Sause
I'll pass ... no engine bay shot ... but 5 shots of transmission? not feeling the hood either nor do I think it is necessary
Old Apr 5, 2012 | 05:13 PM
8 Maniac's Avatar
Senior Member
They say they have engine bay pics but couldn't post them after the bidding started...
I'm not saying this is an indication of the quality of work, but come on... engine bay pics should have been VERY high on the list when we're talking about an engine swapped car. Considering that is pretty much the single largest modification, I would expect that to follow immediately after the basic pics of the exterior. Assuming the swap was done well, you can fix a lot of the other stuff and still get a decent deal out of it if the price is right.
Old Apr 5, 2012 | 05:26 PM
Highway8's Avatar
Registered RX8 Nut
For those of you who missed the Q & A section where the seller directs you to the engine bay pics, http://www.autotrader.com/dealers/dd...er_id=55970363
Old Apr 5, 2012 | 05:44 PM
stinksause's Avatar
lol why are they still running the coolant through the throttle body???
Project has a "i don't really care for the end result" feel to it ... areas are def overlooked and rushed ... however, it is not TERRIBLE
"Approximately 300 horsepower???" Lol wut ... more like 200
Old Apr 5, 2012 | 10:44 PM
elysium19's Avatar
questions about planning or build quality aside.....there's a very good change it's faster than most of our rx8's. just sayin....
Old Apr 5, 2012 | 10:51 PM
monchie's Avatar
I HATE SPEEDBUMPS!
Could be, it looks hooked up.
Old Apr 5, 2012 | 10:57 PM
LifeAfterRx8's Avatar
Only due to the fact the car is significantly lighter than the 8.
Old Apr 6, 2012 | 03:30 PM
Roidz's Avatar
Strength/Confidence
No thanks. Looks like something Ronald McDonald would drive.
Old Apr 6, 2012 | 03:47 PM
olddragger's Avatar
pwr of over 11 to one? Its not THAT fast.
Old Apr 6, 2012 | 03:50 PM
pdxhak's Avatar
Official Post Whore
Old Apr 6, 2012 | 03:55 PM
Winfree's Avatar
From: In the hills between San Miguel and Parkfield - "up in the boonie lands", Central Coast of California, Wine Country
Wonder what kind of gas milage it gets?
Old Apr 6, 2012 | 04:43 PM
elysium19's Avatar
same engine in a lighter car = better than mine!
Old Apr 6, 2012 | 06:22 PM
stinksause's Avatar
maybe even tickles the low 30s
Old Apr 6, 2012 | 08:58 PM
yale02's Avatar
Still plays with cars
I've seen this car in person at the track. Build quality aside, the owner seemed genuine enough. I found it interesting that he hooked up an alternator switch to turn it off in the straights. I don't really know if it does anything or not but he seemed to think the engine gains about 30 hp when switched off. I wonder if having it off causes other problems though...
Old Apr 7, 2012 | 10:23 AM
stinksause's Avatar
interesting ....
Old Apr 7, 2012 | 12:31 PM
Spin9k's Avatar
In that car maybe not, but we have electric power steering, which needs some serious juice on demand. Would be sad to flatline a battery (and the car) during a track session because of a drained battery....
Old Apr 7, 2012 | 01:18 PM
yale02's Avatar
^ In my discussion with the owner he said it gets used as a sort of "push to pass" sort of thing.
Old Apr 7, 2012 | 01:56 PM
Highway8's Avatar
Registered RX8 Nut
Cutting the alternator is a bad idea. A suddon drop from 14volts to low 12's has a high likelihood of effecting the fuel injection, specifically the fuel pump.
Old Apr 7, 2012 | 01:58 PM
stinksause's Avatar
^not unless you activate an aux inline small battery at the same time to bump the voltage
Old Apr 7, 2012 | 02:42 PM
yale02's Avatar
I don't remember seeing another battery but didn't really look for it either.
