Have a multimeter? Please take some readings for me!
Old Mar 28, 2012 | 02:47 PM
TheWulf's Avatar
My 8 looks like a Smurf
Since not many people around me have an RX8, I'm hoping a few of you guys are willing to take some readings for me.
I just need voltage readings at the following locations:
- Before the fuel pump resistor
- After the fuel pump resistor
This is the wire going to the connector under the air pump, right in front of the washer fluid tank. There are two wires on that connector. One that is before (blue/red) and one that is after (white/red). The easiest way to do this is to make a small hole in the plastic tubing covering both wires and use the multimeter probes to pinch the wire. Battery or chassis can be used as a ground here.
- At the fuel pump
Under the rear driver-side seat, take the metal plate off (4 screws) and measure that same white/red wire. Either the seatbelt bolt or the black wire near the seat edge can be used as a ground here.
If you could post these for me that would be great. I just need a few readings to establish what normal is supposed to be as I can't seem to find anyone who can give me a straight answer.
Thanks in advance!
Shankapotamus3
Mar 14, 2021 03:53 PM
mdl0209
May 23, 2019 05:46 PM
projectr13b
RX-8 Racing
20
May 14, 2016 06:25 PM
XianUnix
Sep 29, 2015 03:48 PM
Trekk
12
Sep 25, 2015 03:08 PM
