225/35/r18
Old Mar 23, 2012 | 07:37 PM
DestLuck's Avatar
Smile 225/35/r18
Ok i was using the robrechts miata tire chart and i was messing around with tires size and keeping in mind our stock tire are 225/45/r18. I was looking to get Low profile tires with a much smaller SideWall and i came up with 225/35/r18 but the chart tell me this might actually mess up the Speedo Reading? is this accurate if so is there a way to fix that? i dont know much about tires so let me know maybe a recalabration dunno.
Thx Guys/Girls
DestLuck
Old Mar 23, 2012 | 07:42 PM
RX8Soldier's Avatar
Time for boost...
Yes, it messes with the speed-o, as the tires are thinner.
Search around the sticky "will it fit thread". That should answer your question
Old Mar 23, 2012 | 07:44 PM
DestLuck's Avatar
ill give it a look thx
Old Mar 30, 2012 | 09:48 AM
DestLuck's Avatar
ok so i did post it in Will it fit tread and no response
need a quick reply to this must pass the order today if it fits
2005 mazda rx8:
Not moded not lowered.
Quick Specs:
18x8
Offset: 20.00 mm
Max Load: *1600 lb
Wheel Diameter:18.00 in
poWheel Width:8.00 in
poBolt Pattern:5-114.3 mm
Centricity:LugCentric / Centrée en fonction des goujons
Colour:BlackFinish:Black W/ Machined Face
would these fit on my rx8 i need to know for sure since there special order :P
also i need to know would they fit on 225/45/r18
tyvm
Old Mar 30, 2012 | 10:22 AM
DestLuck's Avatar
nah its not a prob just want to know would these Wheels fit on my rx8? or im gonna get fitting probs with the bolt pattern. Because canadiantire says it wont fit but there ******* retards too.
im looking into the Touren TR3 3130
Old Mar 30, 2012 | 10:27 AM
18 x 8 +20?
Old Mar 30, 2012 | 07:51 PM
DestLuck's Avatar
ok Here is my question i dont care if these are real close to stock. i just want better looking wheels i want :
18" x 8"
bolt pattern: 5/108 & 5/114.3
offset: 40
Will this fit on the rx8 what problems may i incounter.
i was told this setup is a bit wider then stock not sure if thats true.
please inform me and dont say you should go wider or bigger.
this is the biggest i can go because i aint going to 20'
all other size are:
16" x 7" 4/100 & 4/114.3 42 offset
16" x 7" 5/100 & 5/114.3 42 offset
16" x 7" 5/112 & 5/120 42 offset
18" x 8" 5/114.3 & 5/120 20 offset
18" x 8" 5/112 & 5/120 40 offset
18" x 8" 5/110 & 5/115 40 offset
18" x 8" 5/108 & 5/114.3 40 offset
20" x 8.5" 5/114.3 & 5/120 20 offset
20" x 8.5" 5/114.3 & 5/120 40 offset
20" x 8.5" 5/112 & 5/115 40 offset
i just need to know WILL IT FIT and will i get problems?
tyvm
Old Mar 30, 2012 | 08:12 PM
tcole6's Avatar
Your stocks are 18 x 8 + 50. Your bolt pattern is 5 x 114.3.
So 18 x 8 + 40 will fit fine. 18 x 8 + 20 is gonna be aggressive (way out to the outside of the car). The rim is not wider, the offset just sets the tire out closer to the edge. I'm not certain, but you might be close to having to roll your fenders at that setup. Either way, you need to stick with the 5 x 114.3 bolt pattern.
As far as you earlier question on the tire, a change in sidewall height is going to affect your speedo. To not affect it, you should look to keep you overall tire diameter similar to stock. This would mean increasing wheel diameter if you want to reduce sidewall height to keep an overall similar diameter.
Given your list above, if your goal is to reduce sidewall height, the 20 x 8.5 + 40 with 5 x 114.3 is gonna be your best bet. A 245/30 20 tire on that rim should keep you pretty close to your original diameter.
HTH.
Old Mar 30, 2012 | 08:13 PM
DestLuck's Avatar
there is a good response thx mate
Old Mar 30, 2012 | 10:24 PM
DestLuck's Avatar
ok so what setup you talking about? the +20 offset or the +40?
