Low Speed Steering Problems
Old Mar 13, 2004 | 08:48 PM
Mistryl's Avatar
Question Low Speed Steering Problems
As far as I know, when you drive at low speeds, the power assist comes on, right? I've been experiencing that sometimes when I pull up to a stop light, my steering wheel tends to want to turn either to the left or to the right...this only happens when I'm stopping. Is this normal, has anyone had this problem, and should I go get it checked out? Thanks.
Old Mar 13, 2004 | 08:50 PM
brothervoodoo's Avatar
RainMan is Back
Do you experience that on level and un-bumpy ground?
Old Mar 13, 2004 | 08:53 PM
Astor's Avatar
They Come At Night
It is the wide tires and the road. Near stop lights when a big truck stops and it has to wait, the weight of the truck makes it sink ever so slightly, over time it wears grooves into the road, when our wide tires hit these it pulls to one side. My friend's M Roadster does the same. His tires are wider than the 8's.
Old Mar 13, 2004 | 09:09 PM
TheDosDog's Avatar
Recovered Modaholic
Performance tires and a light car combined with excellent brakes magify the road feel so it's normal. People not used to driving a sports cars seem to notice this more but after a while you'll get used to it. In fact, I don't notice pulling at all anymore.
Old Mar 13, 2004 | 09:40 PM
Mistryl's Avatar
Hmm...I could've sworn that the road was in pretty good condition, but I guess it's possible. What I thought originally was that my front wheels were very slightly turned, and since I was still inching forward, a combination between the forward movement and power steering caused it.
Old Mar 13, 2004 | 11:23 PM
seikx8's Avatar
Is this title ok?
The first time I put on wide performance tires on my Teg, it scared the hell out of me since it was only semi-power assist. But when I got the 8, I was expecting it. Your arms will get all the excercise they need after some extensive driving on the road
Old Mar 14, 2004 | 01:08 AM
epitrochoid's Avatar
Riot Controller
same thing happened when i put wheels on my civic. some of the roads around where i used to live pulled like crazy, but you learn where the hot spots are.
Old Mar 14, 2004 | 10:00 AM
Rev It Up's Avatar
I may br way off but Mystryl you said it happened when you where comming to a stop, so it probably has to do with the brakes pulling not the uneveness of the road. My car does the same thing and I have assumed that its just the large rotors and calipers.
Old Mar 14, 2004 | 05:54 PM
seikx8's Avatar
Is this title ok?
If it's uneven breaking from break, car will also pull at any speed; if that is the case, it's not safe to drive and bring it to the dealer. Have a friend of mine feel his car was driving a bit funny and bring it to the dealer and find out his brake pads had worned out.
Old Mar 14, 2004 | 10:27 PM
gunit28vp's Avatar
astor is 100% right its the grooves in the road. the car tries to follow them
xAgyex
Jun 3, 2026 03:47 PM
uZu
Dec 30, 2015 12:35 PM
JakeKaminskisRacing
Aug 23, 2015 01:10 AM
D13
Aug 22, 2015 11:42 PM
Solmors
Aug 21, 2015 10:11 PM
