CX-5 Diesel: Now available in Australia...REVIEW.
Old Mar 20, 2012 | 04:13 PM
ASH8's Avatar
Super Moderator
AU CX-5 Diesel: Now available in Australia...REVIEW.
http://www.goauto.com.au/mellor/mell...2579C600199A26
HOT on the heels of the release of the new CX-5 petrol range last month, Mazda Australia has launched the diesel-powered line-up, which it expects to account for 30 per cent of total sales.
Like its petrol siblings, the new diesel range features a full suite of new SkyActiv engine, chassis and body technologies aimed at improving power, economy, safety and vehicle dynamics.
The oil-burning engine – an all-new turbocharged, direct-injection 2.2-litre four-cylinder – is available only in mid-spec all-wheel-drive Maxx Sport and flagship AWD Grand Touring variants, priced from $39,040 and $46,200 respectively.
This makes the diesel $3000 AUD more expensive than equivalent 113kW/198Nm petrol versions.
There are no front-drive diesel variants available for now.
The ‘SkyActiv-D’ engine produces 129kW of power at 4500rpm and a thumping 420Nm of torque at 2000rpm, resulting in a 0-100km/h sprint time of 9.4 seconds – the same as the quickest petrol variant.
The oil-burning powertrain is matched exclusively with the newly-designed SkyActiv-Drive six-speed automatic transmission with manual mode.
The direct-drive torque converter unit features a full-range lock-up clutch for all six gears that Mazda claims makes it more frugal than a CVT and gives it less jerky starts than a dual-clutch such as the Volkswagen DSG.
The transmission is also compatible with the car-maker’s fuel-saving idle-stop system that re-starts the engine in a claimed world-fastest time of 0.4 seconds.
Fuel economy is subsequently a strong point, with Mazda claiming figures of 5.7 litres per 100km, equating to carbon emissions of 149g/km – placing it right at the pointy end of the Australia medium SUV segment.
These figures compare favourably with its larger manual-only CX-7 diesel predecessor, which recorded figures of 127kW, 400Nm, 7.6L/100km and 202g/km.
The CX-5 stacks up well against key diesel rivals including the Nissan X-Trail six-speed auto (110kW, 320Nm and 7.2L/100km), six-speed manual-only Subaru Forester (108kW, 350Nm and 6.0L/100km) and Volkswagen Tiguan (103kW, 320Nm and 6.0L/100km).
Braked towing capacity is a claimed 1800kg (750kg unbraked).
Mazda says this engine meets Euro 4 emissions regulations without having to use an expensive nitrogen-oxide after-treatment system, courtesy of its super-low 14.0:1 compression ratio – said to be the world’s lowest in a passenger diesel – and two-stage turbocharger.
As well as helping efficiency, Mazda claims the two-stage turbo improves torque delivery throughout the rev range and speeds up responsiveness, banishing turbo-lag.
A further benefit of the ultra-low compression ratio is a saving in weight because it puts less pressure and strain on engine components, opening the door to lightweight materials such as an aluminium block and lighter pistons and crankshaft.
Despite this, diesel CX-5 variants still weigh 94kg more than equivalent-spec AWD petrol models, with kerb weights of 1637kg for the Maxx Sport and 1687kg for the Grand Touring.
Standard safety equipment includes electronic stability control, ABS brakes with brake assist and brake-force distribution, hill-start assist, an emergency stop signal, six airbags (dual front, side and curtain) and anti-whiplash front-seat head restraints.
The flagship Grand Touring also offers Mazda-first lane-departure warning, blind-spot monitoring and high-beam control systems as part of the $1990 Tech Pack.
Standard features on both Maxx Sport and Grand Touring models include dual-zone climate-control, Bluetooth phone and audio streaming, USB connectivity, Tom Tom satellite-navigation with 5.8-inch touchscreen, rain-sensing wipers, cruise control, automatic headlights, push-button start and leather-wrapped gear ****, handbrake and steering wheel (with buttons), and metallic/mica paint.
The extra $7000 outlay on the Grand Touring additionally nets leather seats with eight-way power adjustment, keyless entry, slide and tilt electric glass sunroof, adaptive bi-Xenon headlights, a premium nine-speaker 231-watt Bose sound system, front and rear parking sensors, and auto-dimming interior mirror.
As part of the SkyActiv chassis hardware, the suspension and steering is new for the CX-5, being lighter, stiffer and more precise than in previous Mazdas.
MacPherson struts are used at the front and a multi-link design sits in the back, while electro-mechanical rack-and-pinion steering adjusts feedback according to speed and conditions. The turning circle is 11.2 metres.
The front brakes are 297mm ventilated discs while 303mm solid discs are used in the rear.
Operating the front wheels for the majority of the time, the AWD system employs variably controlled rear torque and slip detection technology to allocate up to 50 per cent of drive to the back wheels.
In an effort to bring its SUV in line with the compact SUV segment ‘sweet spot’ after the longer-than-average CX-7, Mazda’s newcomer is 153mm shorter than its predecessor – but also taller and more upright, for significantly increased cabin dimensions.
Exterior measurements are (with CX-7 in brackets): length 4540mm (4693mm); width 1840mm (1872mm); roof height 1670mm (1645mm); wheelbase 2700mm (2750mm); front track 1585mm (1627mm); rear track 1590mm (1622mm).
Despite being smaller overall than the CX-7, cargo volume rises by three litres to 403 litres while folding the rear seats (via Mazda’s remote ‘Karakuri’ system that can drop the centre piece independently in vehicles fitted with the 40/20/40 backrest) increases capacity to 1560 litres.
According to project manager and enthusiastic cyclist Hideaki Tanaka, two bicycles with their front wheels removed will easily fit inside, while the load length to the back of the front seats can accommodate his 175cm frame for sleeping.
A lightweight cargo barrier that lifts with the longer and deeper tailgate improves access.
Engineers took a fresh approach to cut cabin noise (a common complaint in Mazda models), using new sound-deadening material between the engine bay and dash panel, in the dashboard itself and around the wheelarches.
Other noise sources are claimed to have been diverted away from occupants’ ears via the side sills, within the engine compartment cross-member structures and beneath thick floor mats.
Maxx Sport models are fitted with 225/65 R17 tyres while the Grand Touring wears 225/55 R19 rubber, while the steel space-saver spare on both is a 185/80 R17 unit.
With a monthly sales target for the entire range of 1000 units (around 300 of which are projected to be diesels), Mazda is expecting the CX-5 to sit at the upper end of the booming compact-SUV segment alongside top-sellers like the X-Trail, Forester and Toyota RAV4, all of which regularly top 1000 sales a month.
The brand projects that Maxx Sport and Grand Touring variants will attract 30 per cent of Australian sales apiece, with the other 40 per cent made up of the petrol-only, entry-level Maxx specification.
Old Mar 20, 2012 | 04:25 PM
RIWWP's Avatar
Some good numbers. ~204lbs heavier than the gas was the big new number I was looking for.
I guess that is still reasonable.
The GT trim is probably not in our future, mainly due to the 19s. 17s are better for poor roads and cheaper wallet impact at replacement time. Once it gets to the US that is.
Old Mar 22, 2012 | 08:16 AM
Timmytimtam's Avatar
I still really don't understand why this car exists, it just looks... comical in it's stance
Old Mar 22, 2012 | 10:58 AM
Mazmart's Avatar
One reason would be: So that Mazda can continue to exist and perhaps thrive which could possibly result in the production of more fun rotary cars .
By far most people think it's a hit including it's looks but of course that's subjective.
Paul.
Old Mar 22, 2012 | 11:02 AM
RIWWP's Avatar
It's a good thing that we don't all like the same thing. Everyone would drive the same car with the same color paint, same transmission, same engine.
Old Apr 14, 2012 | 10:53 PM
Are-Ex-Eight's Avatar
Nice Rotors
Is that 40 mpg?
Old Apr 15, 2012 | 01:33 AM
RIWWP's Avatar
41, yes.
Old Apr 15, 2012 | 08:42 AM
Nice Rotors
Hmmm maybe do want.
Old Apr 17, 2012 | 07:36 AM
Mazmart's Avatar
I just saw the European Mazda vid put up by Ash with a Japanese Mazda exec stating 4.6 L 100 km. That equates to 51 mpg US. Could the difference be awd auto vs fwd manual?
Paul.
Old Apr 17, 2012 | 07:44 AM
RIWWP's Avatar
I was wondering the same thing Paul...
Old Apr 17, 2012 | 08:42 AM
Bladecutter's Avatar
Rockie Mountain Newbie
The UK has two different diesel power levels available, either 150 PS or 175 PS, depending on which version of the 2.2 diesel you buy.
BC.
Old Apr 17, 2012 | 10:21 AM
so i can call covette garbage cuz it looks almost exact same **** for the past now many years?
or should i call a 911 boring cuz its based on the same design for so long even the guy who orginially designed it has past away just days ago?
lucky we have different taste
i finally saw someone driving it last week, twice, both times i gave them a thumbs up, they probably thought im some random crazy asian dude but whatever ... the car looks really good. one black and the other is dark grey
hmm, if this diesel can get 41 mpg ... or even more, it makes the current mazda3 look pretty bad ... well i know the current mazda3 does not have the headers, compression is slighlty lower, diesel cost more than gas so that offset some of mpg advantages ...
anyway, my question is ------- when will we get this GOOD LOOKING diesel suv on US soil? i really hate waiting
Old Apr 17, 2012 | 03:00 PM
Mazmart's Avatar
You ARE some random crazy Asian dude . But we love you anyhow .
Paul
Old Apr 17, 2012 | 03:25 PM
Paul
when will you install that 20b to my 8?
i swear u said that in my dream !
ASH8
General Automotive
Dec 4, 2012 08:34 PM
ASH8
General Automotive
Oct 2, 2012 05:40 PM
ASH8
General Automotive
69
Aug 4, 2012 11:32 PM
ASH8
General Automotive
Jul 3, 2012 11:48 AM
usnidc
General Automotive
Mar 21, 2012 05:31 PM
