365 day Rx8 REW build.
Old Mar 15, 2012 | 10:25 PM
Schartz's Avatar
Old Mar 15, 2012 | 10:31 PM
RX8Soldier's Avatar
Time for boost...
That's a good plan! It's how I've been planning a (hopeful) turbo build for NEXT summer
I say this with all sincerity: I hope you don't forget about this and follow through with your instal! Seen too many members either not follow through, or else just don't update.
Engine looks good. Who is doing the engine build/porting?
Good luck with your build!
Old Mar 16, 2012 | 02:41 AM
jayscoobs's Avatar
subscribed. GL with the build. Can you please document and take pics and make a build thread. Would like to see all thats involved.
Old Mar 16, 2012 | 03:26 AM
bse50's Avatar
#50
Looks like the engine was in fairly decent condition!
Good luck with the build and have fun
Old Mar 16, 2012 | 06:50 AM
EightCostsMoney's Avatar
Coolness, I willl be watching this thread. Good luck!!!
Old Mar 16, 2012 | 01:58 PM
ELI063's Avatar
Bat Mobile Driver
From: From Florida back to my home lands in MIchigan
O yea Man nice!! And what they said^^^
O and nice work stations wish I had that much room for my 8
Old Mar 16, 2012 | 02:04 PM
fastlaneracing's Avatar
Rotor User
What power level are you shooting for?
Are you going to swap out the trans and rear axle?
How are you going to tune it and mate it to the RX-8 PCM?
Old Mar 16, 2012 | 02:09 PM
Cool build. Good Luck. Fastlane, I assume he is going to run a stand alone ECU along with the stock ECU.
Old Mar 16, 2012 | 02:47 PM
Sephitrask's Avatar
Zoom Frickin Zoom
use the renesis front cover and all the sensors will work fine
Old Mar 17, 2012 | 05:36 AM
shr3da's Avatar
Nice another 13b REW swap! Can I ask what you are doing for engine mounts?
Old Mar 17, 2012 | 06:52 PM
Schartz's Avatar
http://www.rx8performance.com/products/engine-mount
Old Mar 17, 2012 | 07:20 PM
dmedz8's Avatar
Needs Boost!
Let's see where this goes ^^^
Old Mar 19, 2012 | 12:39 AM
dalen2000's Avatar
That's a good plan!
Old Mar 20, 2012 | 04:29 PM
Jake33's Avatar
Dudemanbro
subbed. good luck dude!
Old Mar 20, 2012 | 07:13 PM
dmedz8's Avatar
Needs Boost!
Originally Posted by TeamRX8
it's easier to see things without your head buried in your keester ...
https://www.rx8club.com/showthread.php?t=230173
Looks like a great part no doubt. I'm just anticipating the poop throwing.
Old Mar 20, 2012 | 11:51 PM
The poop was already thrown and we are past all that now. Try to get up to speed already ...
Old Mar 21, 2012 | 07:05 PM
dmedz8's Avatar
Needs Boost!
the mazsport thing is all in the past? I didn't know. It's not like it's brought up every time Scott creates a new company. I have noting against the guy. I've never done business with him.
/thread jack.
GL with this build!
Old Mar 21, 2012 | 08:18 PM
firecran's Avatar
Renesis out... REW in
Thumbs up
^looks good!
Heres a bit of info to help you out.
The UIM engine hoist loop and surrounding metal will have to go to clear the firewall.
It's a really tight fit back there.
Old Mar 21, 2012 | 10:13 PM
dmedz8's Avatar
Needs Boost!
Looks good! Is an aftermarket EMS needed? I'm confused by the post about "using the front cover and all the sensors will work fine"...
Old Mar 23, 2012 | 03:04 PM
just shorten the LIM ...
Old Mar 24, 2012 | 03:52 PM
firecran's Avatar
This is true but requires mucho mas work.....
Old Mar 25, 2012 | 02:51 AM
Not really. A band saw to cut out a section and then weld it baçk up, if it can't be cut straight enough then the surfaces might need to be milled to square it up. It is not that big of a job for a proper fab shop.
Old Mar 25, 2012 | 03:03 AM
$450 for shortening a 20B manifold, a 13B should be less work and hopefully cost less
http://definedautoworks.com/prod17.html
Old Mar 27, 2012 | 09:16 PM
IXC-RX8's Avatar
looks great
Old Mar 30, 2012 | 01:14 PM
akib's Avatar
is it possible to swap 13b rew engine with its tanny on rx8 without changing turbo and its ecu
i mean stock 13b rew engine, transmission and ecu
