My car is shutting down
Old Mar 12, 2012 | 03:58 PM
young money's Avatar
Hello guys i have a 04 AT rx8. I live in a hot country, when i drive in heavy traffic for long periods my car would shut down and after a few minutes start. I Think its a cooling issue, not sure. HELP.
Old Mar 12, 2012 | 04:02 PM
RIWWP's Avatar
Fuel pump.
Reason:
Typical issue with our fuel pumps that they begin to fail, and as they fail they start overheating. They shut off and stop pumping fuel when the temp reaches a threshhold. Attempting to start before it has cooled down produces no results because it won't pump. Letting the car sit for a bit to let the pump cool through simple radiation of heat energy will allow you to start again.
Until you replace the fuel pump, do NOT go full throttle. I'd even keep it under 4k RPM. If the fuel pump shuts off at the wrong time while under full throttle, the sudden lean condition can destroy the engine. It has happened quite a bit. One owner I know lost their engine this way, the dealer replaced the engine but not the fuel pump, the newly replaced engine was destroyed by the fuel pump doing this within a couple hours of the install.
Old Mar 12, 2012 | 06:47 PM
Thanks a lot, that really helped.
Old Mar 12, 2012 | 06:55 PM
StealthTL's Avatar
Metatron
Can also be a plugged filter on the bottom of the pump.
If the pump itself is the prob, you just need a 'Walbro 342' type pump, there are lots of pumps that will fit, same pump as the 1994 RX7.
Old Mar 12, 2012 | 07:26 PM
will check it out
delicious_dallan
Jan 17, 2020 09:17 AM
Skyl3r
Dec 2, 2019 04:51 PM
Shnifty
23
Dec 18, 2015 12:49 PM
digitalmonkey79
Jul 29, 2015 12:09 AM
vssystemluba
Jul 19, 2015 04:16 PM
