Greddy help in hawaii
Old Mar 11, 2012 | 12:55 AM
Avnmedic's Avatar
So I'm new to the forum and the rx-8 and realize I seriously need help. I just purchased a 2004 with the greddy turbo kit on it. However I know very little about turbos. I have read a few threads addressing the issues I am having but still it seems like they are speaking another language. I am having what seems like some typical tuning issues with my car and desperately need help before I lose my engine. If there is anyone in Hawaii that has the greddy or knows about them please let me know.
Old Mar 11, 2012 | 05:47 AM
AWJay's Avatar
Haole
Who did you buy it from?
What are the symptoms?
Old Mar 11, 2012 | 08:17 AM
emoximuu's Avatar
You either bought the silver one or the hidious one. Along with jays questions hows it tuned? Where you located?
Old Mar 11, 2012 | 03:51 PM
Avnmedic's Avatar
I don't know how it is tuned. It is running through the e manage from greddy. It has lurching and bogging down during moderate acceleration around 4-5k rpm. It seems like all it wants to do is run full throttle all the time. Also the acceleration is not consistent. Sometimes it takes off like a rocket and sometimes it seems slow. I would have thought it was just tuning issues but from what I read it's a problem with the greddy kit itself. All my problems seem to have happened to others here. Btw I'm on schofield. Any help is appreciated
Old Mar 11, 2012 | 04:07 PM
WingleBeast's Avatar
HAVOC
Hey I found your problem: Your running it with the GReddy E-Manage.
Old Mar 11, 2012 | 04:58 PM
Avnmedic's Avatar
Ok. So what's the alternative?
Old Mar 11, 2012 | 05:16 PM
bse50's Avatar
#50
cobb accessport
Old Mar 11, 2012 | 07:06 PM
MazdaManiac's Avatar
Click on the SIG.
Old Mar 11, 2012 | 07:34 PM
Avnmedic's Avatar
Maniac. You seem to know the most about all this so far that I have read. What about the other fixes you describe in other posts?
Old Mar 11, 2012 | 10:46 PM
HAVOC
with the AP, the only MM fix you need is the different location for wastegate input.
Old Mar 14, 2012 | 01:00 PM
Chris's Avatar
Turbo Member
well all three are good to do
Old Mar 14, 2012 | 07:34 PM
HAVOC
umm you kinda cant...
Fix #1 is the pump problem and since the AP doesnt mess with it there is no need to cut the wire; Fix #3 also deals with the E-Manage harness, which obviously the AP does not have...
Old Mar 15, 2012 | 07:53 AM
Chris's Avatar
Turbo Member
this guy is currently on e-manage...
Old Mar 15, 2012 | 09:06 AM
Chris's Avatar
Turbo Member
a few more things I would make sure to do:
1. be sure to have your maf in the appropriate size tube
2. make sure the maf gets good readings by using a screen in the intake tubing
3. use a good BOV, and make sure you recirculate it
4. make sure jet air is either hooked up post turbo or if you go pre turbo, install a check valve in the hose.
... there are more to double check but this is a good start
Old Mar 15, 2012 | 04:32 PM
HAVOC
even if he does the fixes, the turbo still wont run well
Old Mar 15, 2012 | 05:45 PM
RotaryMachineRx's Avatar
SPOOLN8
^ +1... switch to the AP and ditch that E-Manage. I went with the AP from the get go and an MM tune and I really have nothing bad to say about the performance of my system
Secondly... Did you not test drive the car before you bought it?
Old Mar 16, 2012 | 07:50 AM
Chris's Avatar
Turbo Member
I agree... switch to ap, but if, for some odd reason he cant, then at the very least he needs to do the fixes
Old Mar 16, 2012 | 08:07 AM
stinksause's Avatar
The Stink w.o The Sause
Recirculate that BOV!
JimmyBlack
273
Feb 10, 2020 10:23 PM
yurcivicsux
192
Sep 12, 2017 10:54 PM
05rx8mazda
Nov 28, 2015 09:42 AM
jDt!
Oct 2, 2015 04:04 PM
